1/32 Boomerang - WIP
    January 2004
Posted by ChrisJH666 on Monday, June 27, 2022 6:21 AM
My new project just arrived in the post. I contacted Alleycat to see if this kit was still available, but unfortunately it wasn't. However, Alec had a look around to see if they still had sufficient parts, and he was able to put together just one more kit for me, for which I am eternally grateful
In the queue: 1/48 Beech Staggerwing (RAAF), P38 (RAAF), Vultee Vengeance (RAAF), Spitfire Vb (Malta), Spitfire VIII x2 (RAAF), P39 x2 (RAAF), Martin Baltimore (Malta?), Martin Maryland (Malta), Typhoon NF1b, Hellcat x2 (FAA)
Chris
Posted by Rob Gronovius on Monday, June 27, 2022 10:40 PM
It will be interesting to follow along!
    January 2004
Posted by ChrisJH666 on Thursday, June 30, 2022 3:37 PM
Issues! Firstly, there is no cockpit floor (in reality the upper surface of the wing centre section), which means seeing daylight through the wheel wells. Not a terribly hard thing to fix. Secondly, the canopy, including the window panel behind the pilot, is a vacform moulding, which is going to be a right pain seeing as I wish to model it with the cockpit open so you can see all that lovely (improved) detail. this is going to take a little extra work!
Chris
    January 2004
Posted by ChrisJH666 on Friday, July 15, 2022 4:47 AM
Started the build with ......... the electrical box! Doesn't everybody? Before and after pics.There are a couple of errors on the finished article. It's one switch short, and it wasn't until after I finished that I realised the two leftmost switches should not have been under the switch guard, but that willbe very difficult to see once the cockpit is completed.
Chris
    July 2015
Posted by MR TOM SCHRY on Friday, July 15, 2022 12:17 PM
Great aircraft!  I've always had a thing for these short, stubby WWII fighters like the Boomerang, the Brewster Buffalo, and then F4F-Wildcat.  Good luck with the build.
tjs
TJS
    August 2020
Posted by Dodgy on Monday, July 18, 2022 7:20 PM
G'day Chris. The Boomer is one of my favourite aircraft. I have the FM Models 1/32 vacform. I was going to build it for Lost Again's 100th aniversary of the RAAF GB, but decided to wait untill I had a few more aircraft under my belt. (Recently returned to the hobby after a 20 plus year break).
If you don't mind I'm going to tune in and watch your build because of my interest in this subject. I also have a lot of reference photos which I'm happy to share.
All the best,
Dodgy.
I long to live in a world where chickens can cross the road without having their motives questioned
    January 2004
Posted by ChrisJH666 on Tuesday, July 19, 2022 3:37 PM
You are more than welcome. Currently I am scratchbuilding a new cockpit frame as, being a resin kit, I am not convinced as to the roundness and consistency of the kit frame, and I wish to add a host of extra detail, which will be far easier if the bulk of it is styrene.
Chris
    January 2004
Posted by ChrisJH666 on Monday, July 25, 2022 4:21 AM
The photo shows a scale drawing of the fuselage frame (dotted), overlaid with the right side cockpit frame from the kit. As can be seen, there are a couple of places where the kit frame has errors, the most important being the angle of the diagonal at the front of the frame. So, scratchbuilt replacement required, using copies of the drawing as the template.
Chris
    August 2020
Posted by Dodgy on Monday, July 25, 2022 6:26 AM
A big job ahead of you Chris.
Cheers
Dodgy
    January 2004
Posted by ChrisJH666 on Wednesday, August 3, 2022 3:35 PM
Slow progress, but here is the new starboard cockpit frame. There's still an awful lot of detail to go on it before attaching the various boxes to it. Speaking of boxes, I offered up the kit electrical box which I had put so much effort into ...... and realised it was entirely the wrong size and shape! It should be a much squarer rectangular shape, so into the bin and build a new one. A friend at the Temora Aviation Museum offered to measure the actual item on their Boomerang, which will be much better than scaling it up from photographs, and for which I am most grateful.
Chris
    August 2020
Posted by Dodgy on Friday, August 5, 2022 5:44 AM
Looking good mate.
    January 2004
Posted by ChrisJH666 on Friday, August 5, 2022 7:14 AM
Thank you. Alot of the detailing depends upon the replacement electrical box in order to get the correct positioning, so I'm currently making the port side frame, which is pretty much identical.
Chris
    January 2004
Posted by ChrisJH666 on Thursday, August 11, 2022 3:53 PM
Just a taster of what's to come. The first two bracket clamps on the cockpit frame. The front one is one of the hangers for the electrical box, which will be completed once the new box is in place, and the other is a fuselage shell mount, which still requires the rod to be fitted once I get to the fitting of the completed cockpit into the fuselage stage. There are a lot of these bracket clamps in the cockpit!
Chris
    January 2004
Posted by ChrisJH666 on Thursday, August 18, 2022 4:12 PM
Joining the two halves. The two side frames are now joined. Getting the two halves perfectly square and aligned was a real pain and took ages! I'm still not convinced it is 100% right, but it is as close as I can get it. Once the glue is well and truly set all the cross braces will go in, then the real fun starts.
Chris
    August 2020
Posted by Dodgy on Thursday, August 18, 2022 6:17 PM
Very impressive. You've only just begun and that's a lot of modelling right there.
Cheers,
Dodgy
    January 2004
Posted by ChrisJH666 on Wednesday, August 31, 2022 4:01 PM
Good news, and not so good news. The basic cockpit frame is now complete. Now for the hard bit. I'm sure I will find bits I wish I'd fitted earlier due to restricted access, as the Boomerang cockpit is a very cluttered beast, where many other aircraft had all the gubbins hidden away under pretty covers! The not so good news is a fairly major fit issue. It appears the Starboard side is the problem. Does anyone have a remedy for out of shape resin other than brute force?
Chris
    August 2020
Posted by Dodgy on Monday, September 5, 2022 7:01 PM
The cockpit frame looks great. As for the resin problem I use very hot water and gently push it back into shape.
Dodgy
    January 2004
Posted by ChrisJH666 on Thursday, September 8, 2022 5:58 AM
Thanks for the advice. I was thinking along those lines, but it's great to have it confirmed.
Chris
    June 2014
Posted by BrandonK on Thursday, September 8, 2022 12:07 PM
The resin venders always tell me to apply hot water and reshape warped parts. The frame work is excellent.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    January 2004
Posted by ChrisJH666 on Sunday, September 11, 2022 5:49 AM
Thank you
Chris
    January 2004
Posted by ChrisJH666 on Thursday, September 29, 2022 3:22 PM
Progress has been slow due to one particular part. I have decided the oil cooler duct in the cockpit is a right royal pain in the butt! I have two surfaces which sit at 90 degrees to each other, but which I cannot join for some time yet, and an object which changes direction in all three axes to meet two very specific points on those surfaces, whilst being hollow at one end where it has to match up precicely with a hole in the fuselage side. I also realised I was going to have to take into account the thickness of the fuselage sides. It took three attempts to get it right, the final solution being to cut the kit part in half, and graft a new fuselage end onto the kit firewall end. The photo shows all three. This is a fairly critical part to get right as so much in this area of the cockpit depends on it.
Due to the thickness of the fuselage sides, I discovered after I had opened out the hole for the duct exhaust, that the hole on the inside face was the wrong size and the wrong place. This meant fixing microstrip into the upper and rear faces of the hole, and then chamfering the edge as shown in the pic. Final filling, filing, and fettling will be done once the cockpit is installed.
Chris
    January 2004
Posted by ChrisJH666 on Tuesday, October 18, 2022 12:37 AM
For some strange reason, especially for a large scale kit, there does not appear to be a control locking bar, or the cockpit ventilation tube, both of which sit roughly between the pilot's feet. Here is the vent, which took around half a day to get right, and is only slightly larger than an Aussie 5c coin.
Chris
    August 2020
Posted by Dodgy on Friday, October 21, 2022 6:04 PM
Awesome work mate.
Dodgy
    January 2004
Posted by ChrisJH666 on Friday, October 21, 2022 11:58 PM
Thank you. It's now painted and installed.
Chris
    August 2020
Posted by Dodgy on Saturday, October 22, 2022 1:53 AM
Cool! Can you post a pic of the whole frame?
Dodgy
    January 2004
Posted by ChrisJH666 on Saturday, October 22, 2022 4:06 PM
If you go back a couple of posts there are a couple of photo's of the frame. The only difference between those shots and now is the area around the footboards at the front of the cockpit. The plan is, finish footboard area, fuel tank and radios, control rods, electrical box, rudder pedals and controls, finish right side of cockpit, fit out left side of cockpit, control column, instrument panels, then seat, in that order. I rapidly figured out that if I didn't do it in a fairly specific order, access issues would mean I couldn't get stuff in!
Chris
    August 2020
Posted by Dodgy on Saturday, October 22, 2022 4:48 PM
Understand and totally agree.
Dodgy
    January 2004
Posted by ChrisJH666 on Monday, November 7, 2022 5:48 AM
After a couple of false starts, I finally got the control locking bar built. Shame I couldn't find this in the kit! Believe it or not, there are 34 individual pieces of styrene to make this. The other photo shows it installed between the footboards in the unlocked position (it was far too much of a challenge to get it right for the locked position!)
Chris
    October 2019
Posted by Tanker-Builder on Monday, November 7, 2022 10:23 AM
ChrisJH666;
   A Boomer in a decent size. I always wonder, When our fliers don't care for a plane, Folks like your Aussies and the Germans with the F-104, fly the heck out of them. Good on you and I like the work you're doing!
    August 2020
Posted by Dodgy on Tuesday, November 8, 2022 4:00 PM
Excellent work mate, but you might need to start taking sedatives if you keep this up! Bow Down
