gregers wrote: |
The later night black was a gloss colour. it's available in Xtracrylic if you can get hold of it where you are. For the early matt black finish I have used matt black primer auto paint rattlecans with good results, this has the scale rough finish and accepts weathering very well. Hope this helps. All the best. Greg |
What Greg said. However, the black used on RAAF Catalinas was a semigloss shade, so any sort of satin black would do. In any event. won't you be starting with a glosy finish, because of the three coats of Future (Pledge one Go or whatever) that you applied to your model in preparation for the decals, and the fourth coat which you applied to seal them in? In 1/72 or 1/48, I achieve this degree of satin-ness by spraying two light coats of matt varnish over the Futured model, which sufficiently takes the edge off the glossiness.
There were two versions of RAF Night Black. One, introduced from January 1940, and referred to as RMD 2A Special Night, was a very rough, matt colour, with a high lamp black content. Some reports have it as more of a very, very, dark grey than a black.
However, when applied to nightfighters, the results were unimpressive. Trials showed that, compared to standard matt black paint, it slowed down a Mosquito nightfighter by as much as 26mph, or, for an early Mossie nightfighter, more than 7% of its max. speed. Not good. With bombers, the effect would be not so much on max speed, but on fuel consumption to maintain cruising speed.
Therefore, by the time that the RAF's night bombing campaign had really got underway, and certainly by the time that Lancasters were available in quantity, the black undersurfacs were just standard matt black, referred to in terchnical orders as Smooth Night. There's therefore no need to over-do the mattness. This is all the more so, when you consider that you're working in 1/48 or 1/72.
Towards the end of the war, many squadrons had taken to polishing the undersides of their bombers, since it was thought that a semigloss or gloss surface was better for reflecting searchlights. Indeed, there was a post-war RAF colour called Anti-searchlight Gloss Black. This was used on some aircraft, mostly tactical transports, well into the 1970s.
For weathering the late-war colour on aircraft exposed to salt water, I suggest streaks of very, very, dark blue or green. Think black with just enough dark blue or green added to be able to motice the difference. Certainly darker than 'standard' very dark blues or greens, such as USN Glossy Sea Blue or Luftwaffe RLM70. Avoid dark grey, since it can give your model a zebra effect. You can, however, use very light grey, or even white, for exhaust staining.
Cheers,
Chris.
Cute and cuddly, boys, cute and cuddly!
