Regia Aeronautica Hasegawa 1/48 ME-109G-6 finished!
    September 2003
Posted by Daywalker on Friday, July 31, 2009 7:29 PM
This is my recently completed 1/48 Hasegawa ME-109G-6, built for Luftwoller's Regia Aeronautica Group Build.  Paints used are Tamiya and Gunze, with kit supplied decals.  The decals have a bit of silvering, but I snuggled them down as best as I could.  Also, I think the pitot tube is bent a little too much, but trying to straighten it meant possibly breaking the wing seam so I left it as is.  Built as a machine flown with 365 Squadriglia, 150 Gruppo Autonomo in July 1943.  The Hasegawa kit included parts to convert the G-6 in the box to a G-4, but the resin parts looked like they were designed for an entirely different model. Confused [%-)]  So, I built it as a G-6 figuring the G-4 in the squadron was replaced with a G-6 at some point. Wink [;)]  This kit was graciuosly given to me by sfcmac, thank you Aaron!  I enjoyed it immensely, bet you thought I would NEVER finish it! Big Smile [:D]
This also marks the very first time I have finished a model in markings other than those from the country of origin. Approve [^]
Comments and constructive criticism welcomed!
Frank
    March 2006
Posted by simpilot34 on Friday, July 31, 2009 7:36 PM
Frank she looks beautiful mate!!!! Always a pleasure to see one of your builds get finished!!!! The workmanship is off the scale!!!! Stunning Build!!!! WELL DONE!!!!Thumbs Up [tup]Bow [bow]Make a Toast [#toast]
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
Posted by Butz on Friday, July 31, 2009 8:27 PM
Howdy Frank,
 Simply stunning my friend!! Simpilot said it all..Make a Toast [#toast] What psi did you set your AB at and what method did you use for the weathering?
 And as for the silvering of your decals, it's hard to tell!
 Thank you for sharing!
Flaps up,
Rangers Lead The Way
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
    July 2004
Posted by mucker on Friday, July 31, 2009 8:31 PM
Absolutely Superb, Frank! Amazing. the oerspray on the markings is fantastic.
    April 2005
Posted by wing_nut on Saturday, August 1, 2009 6:20 AM
Frank molto piacevole. Mi piace molto la camo molto.
Marc
    March 2006
Posted by simpilot34 on Saturday, August 1, 2009 7:06 AM
Sign - Ditto [#ditto]Confused [%-)]
    April 2005
Posted by wing_nut on Saturday, August 1, 2009 7:11 AM
Don't worry... you said a good thingBig Smile [:D]
Marc
    March 2006
Posted by simpilot34 on Saturday, August 1, 2009 7:37 AM
Laugh [(-D]Make a Toast [#toast]
    October 2007
Posted by Summit on Saturday, August 1, 2009 8:41 AM
Frank-  What a Fantastic job. The "Mottle" is some of the Best I have ever laid eyes upon. I would have to say my most Favorite part of this build would be the Balkenkreuz's painted over. Well Done my Friend Approve [^] Thumbs Up [tup] Thumbs Up [tup]
Sean "I've reached nearly fifty years of age with my system." Weekend GB 2008
    October 2007
Posted by jmabx on Saturday, August 1, 2009 9:32 AM
Shock [:O]  B.. E.. A.. U.. T.. I.. F.. U.. L..
Absolutely amazing! Everything is perfect (except the pitot of course Wink [;)])! I really like your antenna rigging... weak spot for me but maybe I can learn something from you sometime!
Why are you afraid of breaking the wing seam to fix the pitot tube? Did you use something other than the kit supplied pitot?
BTW, I really like the Hasegawa 109's... nice kits!
Once gain, amazing work... I absolutely love it! You are truly a master of your hobby! Big Smile [:D]
Jeremy    Propeller
    February 2007
Posted by Luftwoller on Saturday, August 1, 2009 9:54 AM
Frank, ive said it once and it deserves saying again, Beautifull build. You are definately one of the best, my friend. Do you think if i stand close enough to the screen, it may rub off?
...Guy
..'Your an embarrassment to the human genus, makes me ashamed to call myself Homo'.
    September 2003
Posted by Daywalker on Saturday, August 1, 2009 10:37 AM
Many thanks all!  This was a fun build, and the comradiere (did I spell it right? Confused [%-)]) of the Regia Aeronautica Group Build was second to none. (shameless plug for Guy, hoping I get special privileges now!)  Stop by and have a look, and build one too if you can!
Richie- You are to kind, but thank you very much! Blush [:I]
Mike- Sorry, I do not recall exactly the psi I used.  Just turned down the pressure until it seemed "right".  I would guess about 12-15 psi?  For the weathering, I gave her a flat coat with PollyScale flat and then gave her an overall raw umber oil wash.  Some black oils for oil leaks, and a light overspray of Tamiya buff to blend it all together.  Some light gray pencils for scrathes, and sme Mig Productions pigments for the tires/wheels. Thumbs Up [tup]
Charles- Thank you very much!  I appreciate that. [6]
Marc- I don't know what you said, are you insulting me?!? LOL  OK, really- what did you say? Confused [%-)]
Sean- Thank you very much my friend.  Mottle effects are some of my favorite to paint, but tricky to get it right!
jmabx- Thanks,  I really appreciate that!  I used wire and tube for the pitot, and it is glued very firmly to the model.  I tried some gentle bending, but it is quite strong so the plastic of the wing would probably give first.  I'll try to think of another way. Thumbs Up [tup]
Guy- Thank you, I wouldn't have built one of these if it wasn't for your GB!  A lot of fun for sure. Thumbs Up [tup]  Don't stand too close to the screen, it freaks me out a bit when people stand too close. Smile,Wink, & Grin [swg]
Frank
    October 2007
Posted by jmabx on Saturday, August 1, 2009 10:58 AM
Ahhhh... I see! I don't think the pitot detracts from your build one bit! Just curious as to why it couldn't be bent.
My wife, her family and 3/4ths of the population in this little state are Italian... knowing the way that they drink (home made) wine, I'm sure someone backed the fuel truck into your pitot! Tongue [:P]
Jeremy    Propeller
    September 2003
Posted by Daywalker on Saturday, August 1, 2009 11:30 AM
Thank you for that, and I am definately gonna use that excuse reason for the bent pitot! Big Smile [:D]
Frank
    December 2004
Posted by luftwaffle on Saturday, August 1, 2009 2:05 PM
Sheeez, I thought you were never gonna' finish that thing! Smile,Wink, & Grin [swg]
Frank, it's always a treat to see your work, what a beauty!  Mottling is perfectly done, along with everything else.  The white theater markings really help break up the the grays and add an interesting visual element, one of the reasons I love Axis Med aircraft.
Don't sweat the pitot tube, it looks about right.  A factoid that most people miss when they build a 109 is that the pitot tube was actually angled downward a few degrees.
aka Mike, The Mikester My Website
"He has all the virtues I dislike and none of the vices I admire."   -Winston Churchill
    July 2003
Posted by KJ200 on Saturday, August 1, 2009 3:05 PM
Frank, you wait years for a non-Luftwaffe 109 to come along, and then...
..BANG!! Two in a week.
Great looking build, love the painted out Balkan Kreuz.
Karl
    April 2005
Posted by wing_nut on Saturday, August 1, 2009 4:37 PM
What I said was, "You are the biggest mothexxxxxxxxx"
OOPS sorry that's what I was THINKING.
What I SAID was that it is very nive and I realy like the camo.
Marc
    January 2003
Posted by el_jere on Saturday, August 1, 2009 10:56 PM
Wow Frank!!! what a beautiful model! I think is one of your best.... The pain job look fantastic! whaw AB and paints do you use? a flawless finish my friend... like the overpaintd balkan cross on the bottom. I don´t like muh the 109 or 190, or spit, mustangs, zeros and so one... not for the planes, but because i´m tired to see those models... but yours man... I like it! (nice scheme you choose)
congratulations and best regards
 Jeremias
Res non verba
    September 2003
Posted by Daywalker on Saturday, August 1, 2009 11:55 PM
Mike- Thank you very much!  That is very high praise coming from a fellow 109 aficionado like yourself!  Also a relief to hear that the pitot isn't TOO bad. Smile,Wink, & Grin [swg]
Karl- I'm with you brother!  Can't wait to see your finished "Karl" for the 109GB.
Jeremias- Thanks my friend!  I know that you are not a 109 fan, but I appreciate the feedback on this one.  Means a lot! Approve [^]  I use a Badger 100LG with a fine needle, and Tamiya and Gunze paints exclusively. Thumbs Up [tup]
Frank
    July 2003
Posted by sidure on Sunday, August 2, 2009 12:40 AM
Hey Frank, I have enjoyed watching this one get built and your finish is just top shelf my friend, your work with the A/B is just fantastic. Great skills. Job well done
Steve
