HELP NEEDED: Accurate miniatures TBM Avenger instructions
    June 2009
Posted by kermit on Thursday, April 1, 2010 12:32 PM
Hi all,
For the Anti Submarine Warfare GB i am currently building Italeri's 1/48 TBF/TBM Avenger, which actually is a reboxed Accurate Miniatures version.
The instructions by italeri however are a nightmare, leaving you with alot of stuff to figure out on your own.
My question is wether the Italeri instructions are the same as Accurate miniature's instructions and if no, could someone PLEASE make a high res pic of the parts concerning assembling the rear gunner station and ball turret assembly? I would be so greatful.....
Thanks in advance to owners of the AM kit in their stash...Wink
Richard
"Success is the ability to go from one failure to another with no loss of enthusiasm." - Sir Winston Churchill
    April 2005
Posted by T_Terrific on Thursday, April 1, 2010 12:49 PM
I have no idea how their instructions compare, but AM's instructions are more of a written booklet then a lot of diagrams, and it is by carefully following their written directions I was able to assemble mine.
Tom T Cowboy
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
    September 2006
Posted by the Baron on Thursday, April 1, 2010 12:53 PM
kermit
Hi all,
Richard
I will check tonight when I get home.  I have the kit, but I can't remember if it's the AM boxing or the Italeri rebox.  If it's the AM boxing, I'll gladly scan the instructions and email them to you.  I'll PM you with the results.
Regards,
Brad
Posted by rjkplasticmod on Thursday, April 1, 2010 1:11 PM
Also go to the AM web site & under Support you'll find a tip on installing the gun turret, which is one of the tricky part of assembly.
Regards,  Rick
    September 2009
Posted by B17Pilot on Thursday, April 1, 2010 1:41 PM
Go to AM website and download the instructions.  Here's a link:
http://www.accurate-miniatures.com/instructions/TBM-3D_0121.pdf
Its for the TBM-3, for the -1C go here
http://www.accurate-miniatures.com/instructions/TBM_1C_0120.pdf
    June 2009
Posted by kermit on Thursday, April 1, 2010 1:48 PM
Thank you all so much and so fastWink
From the look of it, italeri has just copied all the drawings for their own instructions but the extensive texts might be useful to me. I am really grateful for this community to be so helpful every single time. I salute you all.
Thanks again, appreciate itWink
Richard
    September 2006
Posted by the Baron on Friday, April 2, 2010 12:13 PM
Good thing for the other responses, my kit is also the Italeri boxing, D'OH!
I'm going to check out the AM copy, too, and compare them.
    July 2011
Posted by Doug B on Friday, July 15, 2011 9:22 AM
Hi Richard,
First time posting on this site.
I am currently building the same kit as you, the Italeri reboxing of the AM TBM/TBF1 Avenger, a brilliantly engineered kit, and I am having trouble with fitting the ball turret. The Italeri instructions (if that is what they call them) call for the construction of the turret at number 8 in the list of proceedings, of course by now the fuselage halves are well and truely joined together and it seems the turret should have been fitted before joining the fuselage. Can you or any body else reading this post tell me if this is so, if it is I have just blown AU$55.00.Angry
Cheers Guys
Doug B
    November 2010
Posted by Bigb123 on Friday, July 15, 2011 9:37 AM
the Accurate Miniatures website no longer exists, and the links previously provided are dead.  I may have a pdf copy of what you need.  PM me your email and mailing address and I'll find them in the meantime.
    June 2009
Posted by kermit on Friday, July 15, 2011 10:19 AM
Doug,
I am afraid that the website did go down, so nomore dedicated page about this fitting of the turret. It is the hardest thing about the entire kit but i assure you it WILL fit.
The italeri instructions are in fact a copy of the AM ones but italeri neglected to also copy the text that goes with it. I agree that the instructions at times were a bit vague as i recall itSmile
Anyways.... the turret....
I got mine in by slightly tilting it and carefully insert it by twisting and tilting untill it works itself inside. Takes a bit of careful twiddly work and a colorful expression or two but you will get thereWink You did not misread the instructions; it is supposed to go in afterwards.
Richard
Posted by waikong on Friday, July 15, 2011 11:16 AM
Follow Richard's suggestions.  As a matter of fact, the AM website use to have a whole page devoted to this very issue, as many people followed the directions and thought 'how on earth am I suppose to get the turret in now?'  The webpage recommended patience, and via a series of photos on how its done.
    February 2011
Posted by Reasoned on Friday, July 15, 2011 1:12 PM
Wow, yet another great thing about this site (and the net as a whole).  I think I have both the AM & Italeri TBM kits in the stash and would have probably had a TBM in flight "wall collision" following extreme frustration if not having read this.Smile
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    March 2012
Posted by molthemackem on Saturday, March 10, 2012 4:37 AM
hi ..just found your post...I know its a few months ago but did you sort with  problem.?.. I have a spare set of instructions for the AM kit if you need them which if the toolings the same as the AM kits thats all i suspect you would need..
Cheers
Mol
    June 2009
Posted by kermit on Saturday, March 10, 2012 4:44 AM
Mol,
Welcome to the forums!Yes
Thank you for your reply. The Italeri Avenger has since then been completed to my satisfaction:
And the reason for this thread was installed succesfully as wellBig Smile:
Great great kit. Certainly in my top three ever and i will certainly build it again in the future! Highly recommended.
Richard
    February 2011
Posted by Reasoned on Saturday, March 10, 2012 6:33 AM
Top job on that kermitYes, I've been watching "Battleground 360" on Netflix and have a greater appreciation for the TBM plane, very cool build.
