- Member since
Posted by berny13
on Friday, January 23, 2004 8:50 AM
The first one I built, I closed it up. On the second one, I opened it up. That was a mistake. The aft section has very little detail inside and will have to be added. Any picture showing the aft section removed also shows jacks under the wings and center fuselage section to level the aircraft. These will have to be scratch built. I also plan to show the guns removed and positioned on a work bench, as if they were being reconditioned. I started this project almost two years ago and still haven't finished it.
It is on my list of things to finish, which keeps getting longer and longer.
Berny
Phormer Phantom Phixer
On the bench
TF-102A Delta Dagger, 32nd FIS, 54-1370, 1/48 scale. Monogram Pro Modeler with C&H conversion.
Tamiya F-4D Phantom II, 13th TFS, 66-8711, 1/32 scale. F-4 Phantom Group Build.
