FUTURE FLOOR WAX
FUTURE FLOOR WAX
Posted by kayajeep on Saturday, March 8, 2003 9:53 PM
I keep hearing about useing Future. I was kind of wondering if someone could explain just what this does and how it works. Do you airbrush it on or use a brush, Do you buff it out or just leave it, and do you use it after the decals are on or before?
Normally I spray a coat of clear sealer after puting the decals on and before putting the canapy on. Sometimes I get a major shine from doing this but it allows me to brush the dust off with no problems. Any info would be great - Thanks - I build em and she won't dust em.....Smile [:)]
Posted by weebles on Saturday, March 8, 2003 10:44 PM
There's been a lot written about it. Some very good threads. Do a search of this site for "Future". You'll get a book load of information.
Posted by Anonymous on Saturday, March 8, 2003 10:45 PM
Future is the "wonder household chemical" that many of use to give the model a glossy surface in preparation for applying decals. It's relatively inexpensive, smells pleasant, and does a terrific job of giving your models a shine.
I've never tried buffing it. I usually apply Future with an airbrush, but it can be readily brushed on too. If the plane is supposed to be glossy (e.g., P-61 night fighter), you can just leave the Future. Otherwise, cover with your favorite flat coat medium. Have a good one!
Posted by Woody on Saturday, March 8, 2003 11:13 PM
Just dip canopy into Future and hang it up to dry in a dust free place. It makes the the canopy shiny, but also makes it look thinner.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
Posted by Anonymous on Monday, March 10, 2003 2:17 PM
Don't forget!!! Let it sit for at least 36-48 hours. It must cure fully, once cured there is no better topcoat.
Posted by Anonymous on Monday, March 10, 2003 7:50 PM
Future is the all-purpose work horse of the modelling hobby! It is great as a clear coat, can be airbrushed without thinning it, makes an excellent coating for your canopies (makes 'em appear crystal clear!) It is also a great sealant for your decals and weathering, and it is pretty cheap compared to Tamiya clear and other similar products.
Go to your nearest grocery store or supermarket, and pick yourself up a bottle of this ubiquitous stuff. You'll not regret it.
Cheers and happy modelling!
    January 2003
Posted by Keyworth on Monday, March 10, 2003 7:58 PM
The only caveat is that Future can degrade if left in sunlight. Usually takes about a year in the bottle once it's opened. Just keep an eye for any discoloration or "floaters" in the solution. Otherwise, have a great time with this stuff.!
"There's no problem that can't be solved with a suitable application of high explosives"
Posted by BlackWolf3945 on Monday, March 10, 2003 9:04 PM
Future is good stuff, as all these other fellas have said. It's very flexible and forgiving, as well. You can spray it, or brush it. You can use it for to spruce up a canopy, or as a base for decals.
If brushing, most brush marks will work themselves out as Future is "self-leveling". Also if you brush it, it may take on a milky appearance. DON'T WORRY! That should go away.
If spraying it, thinning is not necessary. But if you ever have a need to do so, water will work fine. Alcohol does funny things to Future, so I'd steer clear of it. I haven't tried any other thinners for it because, as I said, it doesn't really need it.
Future is way-cool in another respect. I'm a brave builder sometimes and have been known to try some weird things now and again. Tongue [:P] When I'm laying down a clear for decaling, I sand the model to get rid of any high spots, dust or other "schtuff", using the finest grit available. (Usually the coarsest part of a tri-grit sanding stick such as the one Squadron offers) This will, of course, mar the finish as well as taking out the dust. Good news is that when you spray or brush over the sanded area, it will still look nice and smooth when dry. Speaking of drying...
This is the bravery part I mentioned and is true, not BS. I've sprayed the stuff on and been able to sand it within 5-10 minutes, respray and still have a smooth finish with no blemishes. I spray rather dry, so if you spray wet you will not be able to do this. In any case, it takes practice and I'd recommend this be tried only by the brave Black Eye [B)] or crazy! Tongue [:P] Seriously tho, it can be done.
The key thing to remember is this: build up several layers of the stuff before sanding, if you choose to do this at all. Future may "look" thick when it's applied to the model, (especially if brushed) but it's really a rather thin coating. Not as thin as some model paints, but you'll sand thru one coat of the stuff in a flash. Build it up some, then sand.
Fade to Black...
Posted by kayajeep on Monday, March 10, 2003 9:30 PM
Thanks to ALL - Great Information - Got a bottle and will give it a shot !!!!
