1/48 B-25 Group Build! All Invited to Join!
    July 2007
Posted by troublemaker66 on Wednesday, September 7, 2011 4:41 PM
Hans von Hammer
The Vals they used in the movie were B-18`s I think....
BT-13s..
The CAF Tora Squadron operates the Vals, Kates, and Zekes... There's also the one authentic Zeke airframe we have as well, although it's been re-engined with a P&W mill..
Yep..BT-13`s....got a bunch of pics of one of the Val`s at the Milleville airshow...I knew someone would correct me...Big Smile
Len Pytlewski
    July 2011
Posted by icer22x on Thursday, September 8, 2011 8:25 AM
So I finished my first paint last night. I am doing the bottom in a neutral grey. But I cannot for the life of me get a smooth coat. This is the second plane I've used an airbrush on and when I paint large areas, the paint always goes on slightly grainy. I end up letting it dry for a few seconds and wiping the grain off with a cloth. It makes it pretty smooth and gives a cool wear effect, but what am I doing wrong? I can spray small pieces just fine - silk smooth. But larger areas are tough.
I spray at around 25 PSI and the paint is mixed well. I wonder if I am doing the strokes too fast and not letting the first coat dry enough? Still pretty new to airbrushing.
Posted by VanceCrozier on Thursday, September 8, 2011 10:07 AM
icer22x
Not sure of the pressure, but if I get that rough texture it's usually because I haven't thinned the paint enough; or I'm spraying from too far away. (Or it's very dry & hot where I'm spraying) Either way, the paint is starting to dry before it hits the surface. I'd say dial the pressure back a little, use a little more thinner, and work a little closer to the surface. (I suspect your small parts are fine because you hold the airbrush closer to them to lessen the overspray - I know I do!)
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    February 2011
Posted by Reasoned on Thursday, September 8, 2011 1:45 PM
VanceCrozier
 icer22x:
Those are excellent tips , I also have that problem with certain colors (e.g. yellow, white)
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    July 2011
Posted by icer22x on Thursday, September 8, 2011 4:35 PM
Thanks Vance. All that makes perfect sense. I probably was too far away from the surface. I spray with a Badger Velocity, so it's a fine stream... sometimes I try to overcompensate by backing away too far. I need to be more patient when I airbrush large areas.
Also, can someone post a picture of their seam between the wing and the cowling? I don't think I will every be able to get that perfect. lol You can always tell they're two separate parts. How do you guys get it perfect?
    June 2008
Posted by Hans von Hammer on Friday, September 9, 2011 11:38 AM
Even North American didn't get it perfect... The cowls are, after all, separate form the wing... You are refering to the intake scoop area, right?
There's a couple ways to go about it though.. Either the "putty & sand" or "caulk and wipe" method...
 I prefer using a stryene strip and shimming it though..
    February 2011
Posted by Reasoned on Friday, September 9, 2011 2:33 PM
Okay Hammer or somebody, where in the heck do the following "little" decals go on the B-25J?
1)  "Fuel Sump Drain"
2) "Boost Pump Drain"
3) Battery Locator Forward Position Wheel Nacelle"
Edit: BAH never mind, just saw on the instruction sheet where they goEmbarrassed, there is an inset on the "Jaunty Jo" version (which I'm not building).
    June 2008
Posted by Hans von Hammer on Friday, September 9, 2011 2:36 PM
Depends on what decal sheet and kit instructions you're using, R-man.. They're just letter call-outs..  No way I can read the stenciling itself.. Not that I use it anyway.. Battle-damage, sheet-metal touch ups, all that stuff ya know...
    February 2011
Posted by Reasoned on Friday, September 9, 2011 2:46 PM
Hans von Hammer
Heck I had to use a magnifying glass to make it out, amazing they can print that lettering so small.  Have you ever used "battle-damage", "sheet-metal touch ups" as an explanation to the rivet counters at a contest? Big Smile
Not that this is going in a contest.
Posted by VanceCrozier on Friday, September 9, 2011 2:46 PM
Reasoned
I really wanted to say "near the fuel sump drain...", but you already found them!! Wink
I had a few minutes last night, didn't want the hassle of setting up & tearing down the a/b so I brush painted the interior of the fuselage with good ol' Testor's Zinc Chromate. Looks too yellow to me though, I'll have to add some green to the wash I'll be doing.
    February 2011
Posted by Reasoned on Friday, September 9, 2011 2:53 PM
VanceCrozier
Vance, as you may know, not sure you're using acryilic or enamel but testors enamel makes a
green zinc chromate
and yellow zc
    June 2008
Posted by Hans von Hammer on Friday, September 9, 2011 6:17 PM
No... I only enter dioramas, so I glue on little strips of .010 styrene, then sand them down even thinner to represent the patches, then paint then a different shade of the base color, depicting "new paint", as Shep Piane did on his B-17 diorama.
I figure even the densest rivet-counter can understand that much... And they ain't so bright as to know where EVERY stencil is on EVERY plane...
I also use parts form "newer" planes to depict the repairs..
    February 2011
Posted by Reasoned on Friday, September 9, 2011 10:33 PM
Hans von Hammer
http://img.photobucket.com/albums/v233/HansvonHammer/Screenshots/Models/B17/b17g_4-a.jpg
Indifferent   Wow!  I had never seen that before, that looks awesomeBeer.  Was that inspired by a specific photograph?  I have seen pix of 17's making it back chewed up by flak or fighter canon, your's looks VERY real.
    January 2010
Posted by CallSignOWL on Saturday, September 10, 2011 7:19 AM
Reasoned
 Hans von Hammer:
thats not Hans' dio, that one belongs to Shep Paine:
http://sheperdpaine.com/monogram/B-17_sheet.pdf
Now that I'm here, where am I??
    February 2011
Posted by Reasoned on Saturday, September 10, 2011 7:47 AM
CallSignOWL
 Reasoned:
 Hans von Hammer:
Thanks Owl Embarrassed (learn something new everyday) , that is some very impressive work, I can hand it to builders who not only build skillfully..... but create.
    June 2008
Posted by Hans von Hammer on Sunday, September 11, 2011 12:35 AM
Yeah, that tail pic is Shep's.. The bottom pic is my (now destroyed) B-17..
    February 2011
Posted by Reasoned on Sunday, September 11, 2011 7:48 AM
Hans von Hammer
Why "destroyed", I thought it looked cool w/ladder and parted out stripping.  Was that the theme?
BTW, hope to have some pix by tonight of an almost complete 25...... with any luck.
    June 2008
Posted by Hans von Hammer on Sunday, September 11, 2011 11:06 AM
Well, it had crash-landed in Scotland, where it was about to be salvaged... However, a 9-lb tomcat named Chewy destroyed for good, forcing it into a power-off dive from the top shelf in the War Room to the floor before I could finish the diorama...
The diorama was one of my "behind the scenes" stories... The USAAF in England had Aircraft Recovery Teams that would go about the British Homeland in search of crippled bombers and fighters that had made it back to England, but not to a base...
Once they located an aircraft, they would survey it and determine if the aircraft was repairable or needed to be scrapped.   If it was deemed repairable, and there was sufficient room for a take-off, they'd get it back into nominal flying condition, and sky it back to a base for further repairs.  In this case, they determined that the aircraft was flyable if it had a couple of engines changed out and some flight-control damage repaired...
On the diorama, I also had a couple of Tamiya 2 1/2 ton trucks planned, as well as a towed air compressor, portable engine hoist, and team tent (This mission would take a few days to accomplish, so they need a place to live).  The teams first priority was to get the big bomber back on its wheels.
They'd have pushed/pulled inflatable rubber jacks under the wings using the air compressor to inflate them, which would raise the Fort up high enough to get the wheels down.  Then the engine change could begin.  This was the "action" I had planned...
But the cat had other ideas...
    June 2008
Posted by Hans von Hammer on Sunday, September 11, 2011 11:08 AM
I plan on doing the dio still.. It's too good an idea to not.. I'm stupid with 1/48 Monogram Forts .. Think I have four, plus the Revell "F"...
    February 2011
Posted by Reasoned on Sunday, September 11, 2011 2:05 PM
Hans von Hammer
What a shame.  Curious, was that its' 9th life or did you relent? Smile
    June 2008
Posted by Hans von Hammer on Sunday, September 11, 2011 7:07 PM
Actually, someone stole him... He used to sit out front of our apartment, "guarding HIS hallway"and he really loved EVERYbody that would come by.. Guess someone thought that that meant they could keep him...
Hope he wrecked their house...
    January 2003
Posted by p38jl on Monday, September 12, 2011 7:34 AM
Cats...Whistling
[Photobucket]
Posted by VanceCrozier on Monday, September 12, 2011 8:00 AM
The cat was stolen... or was retrieved by his handler after years of spying on your operation?!?!
Reasoned - I'm using enamels inside as I prefer them for brush painting and I am indeed using the yellow ZC. (the "local" didn't have the green in stock) To be honest I was thinking "how yellow could it be?!", so I'll either mix it greener for the top coat, or a wash with a great deal of green in it. I didn't touch the cockpit areas yet. I wonder if a few drops of blue will green it up enough? Hmm
    February 2011
Posted by Reasoned on Monday, September 12, 2011 2:45 PM
Vance, I've said it before, it's really a shame the interior has the detail it does because SO much of it will never be seen!  Sure the canopy and nose (if it's the glass version) will be seen but otherwise not much of fuselage section.  I will attempt to attach a group build attachment that has several takes on this kit, some actually painted it Yellow Chromate, while others Green.  Check out the "Terry Miesle" build.
http://modelingmadness.com/reviews/allies/us/usaaf/48b25.htm
    July 2011
Posted by icer22x on Monday, September 12, 2011 8:50 PM
The instructions say the interior is olive green. How accurate is this?
Also, on the back of each nacelle, there are two antennas? Most finished kits I see of these Js, they are sanded off. Why is this?
Posted by VanceCrozier on Tuesday, September 13, 2011 7:16 AM
Reasoned
Thanks for the link! Yep, I think I'll leave the fuselage interior as-is & expect to green it up a little with the wash. The brighter yellow ZC may allow a little more to be visible than the green ZC anyway. I think I do want to have the greener shade on the cockpit & tail gunner's area, as he did in that build review you noted.
    May 2006
Posted by Shipwreck on Tuesday, September 13, 2011 8:38 AM
Reasoned
 >>>it's really a shame the interior has the detail it does because SO much of it will never be seen!  Sure the canopy and nose (if it's the glass version) will be seen but otherwise not much of fuselage section.  <<<
Has anyone seen or tried a cut away on the J kit?
On the Bench:
Revell 1/96 USS Constitution - rigging
Kinetic 1/48 YF-104A 5-2957
Trumpeter 1/350 USS Hornet CV-8
Revell 1/48 B-1B Lancer Prep & Reasearch
Posted by VanceCrozier on Tuesday, September 13, 2011 8:48 AM
Hmm I keep looking at mine thinking about it - does that count!?
    June 2008
Posted by Hans von Hammer on Tuesday, September 13, 2011 8:56 AM
Check that link, Icer..
Posted by hutchdh on Tuesday, September 13, 2011 7:48 PM
She's coming together.....
Hutch
 On the Bench: 1:48 HobbyBoss Ta152-C; 1:48 & 1:72 Hasegawa F-104G NATO Bavaria
In queue: 1:48 Academy F-4B & a TBD Eric Hartmann bird
Recently completed: 1:32 Trumpeter P-51B
