Eduard 1/48 Fokker DR.I (finished)
    February 2006
Posted by ruddratt on Tuesday, March 20, 2012 1:29 AM
Please allow me to present my latest build for Marc's (wingnut's) "Great War" group build. This is the Eduard kit from the dual combo pack, modeled after Ltn. Hermann Frommherz' mount in the spring of 1918. Frommherz served in the infantry on both the eastern and western fronts before being transferred to bomber duty over the French and Macedonian lines. In 1917 he was assigned to Jasta Boelcke where he got his first air victory in April. July that year he succeeded Hermann Goering as CO of Jasta 27. He finished the war with 32 victories, afterwards going on to serve as an instructor in both the Soviet Union and China. At the start of WWII, he was assigned CO of I/JG 134.
The kit is pretty much OOB, with the exception of the guns, where I used brass cooling jackets and turned brass barrels from Ultracast's master set. For the streaked camo, I wanted to paint my own instead of using some of the AM decals available for that effect, and I'm pleased with how it turned out. They began with a base coat of MM RLM65 (which I also used for the underside color) and a generous coat of Future. This was followed by thin random angled streaks of three primary colors, titanium white, burnt umber, and olive brown (which I made by mixing black, yellow ochre, and a touch of purple to cut the green a bit). All were thinned slightly with japan drier, which reduced cure time to about a day, yet made them even easier to blend together. Tamiya weathering powders and panel line accents helped give it a more used look, and the minimal rigging is a combination of stretched sprue and .005" stainless steel wire.
In real life, this was a tiny aircraft (the kit wingspan is about 6" in length) but it was a blast to build. I hope you enjoy the pics, and thanks for looking. Comments and critiques are always welcome. Yes
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    December 2011
Posted by Luft Modeler on Tuesday, March 20, 2012 1:45 AM
Wow! The engine shot with the prop look like its real.. weathering looks great and I like how the whole thing doesnt even look like its a plastic model. Great job!
    June 2008
Posted by Hans von Hammer on Tuesday, March 20, 2012 1:53 AM
Outstanding build of the diminutive Dr 1... You're right about it's size.. It's a small bird.. Your Fokker factory streaked finished is outstading and just as good any decals would be, plus it's YOURS and like a fingerprint, unique..
 Frommherz started with the Infantry eh? Sounds like a "real world" Bruno Stachel, lol..
Talk to me about using the brass barrel cooling-jackets... I bought a pair of 1/28 scale Dr 1 (The old Revell kit that comes and goes every few years, ever since it's first release in 1958, which makes it a year older than me, lol) offa Ebay and both have the brass P/E detail sets for German machine guns with two Spandaus and two Parabellums, and rolling the cooling-jackets was a killer, so doing it in 1/48th escapes me as the "how to"..
    October 2004
Posted by StephenLawson on Tuesday, March 20, 2012 1:59 AM
Nicely done!
Stachel...unconfirmed by Armee means unconfirmed!!!!
    November 2004
Posted by Bronto on Tuesday, March 20, 2012 8:43 AM
Very well built.
    October 2010
Posted by peterjb on Tuesday, March 20, 2012 10:38 AM
Nice build  Yes
    March 2010
Posted by Hercmech on Tuesday, March 20, 2012 11:07 AM
Very nice build...love the paint job!
13151015
    March 2010
Posted by stcat on Tuesday, March 20, 2012 11:35 AM
I've never seen biplane weathering as good as yours.  Awesome job!
    February 2011
Posted by Reasoned on Tuesday, March 20, 2012 12:11 PM
Wow! That is one cool looking build.Beer  You did an amazing job on the camo and fantastic wood look to the prop.
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    December 2011
Posted by Luft Modeler on Tuesday, March 20, 2012 1:15 PM
Reasoned
And also the wood skids on the tail and bottom of the wings! This looks like a museum piece!
    February 2006
Posted by ruddratt on Tuesday, March 20, 2012 8:49 PM
Gentlemen, I simply cannot thank you all enough for the amazing comments. Coming from modelers of your caliber, they certainly do mean a great deal to me. Yes
Hans, when I ordered that AM set for the guns, I was a bit surprised when the jackets came pre-rolled. At least that's what I thought at first, but I couldn't find a single seam on 'em, which then lead me to believe they may have actually been machined from a single piece of round stock. Impressive pieces nonetheless, but I always roll my own (cooling jackets, that is). Sometimes they need a bit of annealing, but the rolling process is always the same for me. I lay 'em face down on my cutting mat and roll & press progressively smaller diameter drill bit shafts back & forth over them, making the curl tighter and tighter until the ends almost meet. The final step is to slip 'em over the exact size rod required for the ends to touch, pick the assembly up, and roll it back and forth between my thumbs and index fingers at each end until the ends touch.
Stephen, that is a great pic of Ltn. Frommherz! Thanks so much for posting that. It's a wonderful piece of history and really ties it all together. Yes
    October 2004
Posted by StephenLawson on Wednesday, March 21, 2012 2:47 AM
Glad you liked the image.  Its from my Jasta 2 file.  He was also aflight  instructor at Lübeck- Travemunde.
Also Air Master sets are seen - here.
Also Aber has them -   here.
The service record of Ltn.d.R. Hermann Frommherz
Coming from Kampf Geschwader 1 (Bombing unit one) he arrived at Jasta 2 on 22 March, 1917. On 1 May, 1917 he was received minor injuries in a crash but stayed with the Jasta.
On 24 October, 1917 he was transferred to the DFW operated Flieger Schule at  Lübeck - Travemunde and served as a flight instructor.
He was transferred from Lübeck - Travemunde on 18 May, 1918 back to Jasta 2 (Boelcke.)
On 29 July, 1918 he was transferred to temporary command Jasta 27 in the same fighter group as Jasta 2 (Boelcke.)
On August 7, 1918 the position was made permanent and he served as the Jasta 27 commander until the end of hostilities.
    December 2004
Posted by panzerpilot on Wednesday, March 21, 2012 2:58 AM
Very nicely done! Impressive! Beer
-Tom
    June 2008
Posted by Hans von Hammer on Wednesday, March 21, 2012 6:07 AM
DRILL BITS! Damn, that's the ticket.. Hadn't thought of that... I'd been rolling them around a paintbrush handle, and trying to get them close enough..
Drill bits... So simple..
Thanks, man..
    February 2012
Posted by Thecat40 on Wednesday, March 21, 2012 7:27 AM
That's an AWESOME looking Fokker DR.I.... GREAT job!!
Posted by jeaton01 on Wednesday, March 21, 2012 10:37 AM
Well done, Mike, Well done!
John
    April 2005
Posted by wing_nut on Wednesday, March 21, 2012 3:07 PM
Another beauty from the master of the string bags.  Even if is very few stringsWhistling
Marc
    February 2006
Posted by ruddratt on Wednesday, March 21, 2012 8:03 PM
Gentlemen, once again, many thanks for all the wonderful comments. I can't even begin to tell you how much they are appreciated.
Hans, more than happy to help, & I'll be keeping my eyes open for those builds!
Stephen, you are an encyclopedia of knowledge when it comes to these birds and their history, and your many kit reviews are an invaluable reference when it comes to doing justice to these amazing machines. Thank you! Yes
    October 2008
Posted by bsyamato on Thursday, March 22, 2012 5:57 AM
Excellent piece Toast just other day makin a sufin in the great war GB and see lots of great build !!
