Hi guys
Further to some postings on the NMF Group Build thread here are some pics of NMF finishes tried so far. All have been carried out using Alclad with only the addition of some smoothed on metal powders in a few areas. All have been put on over Alclad's grey Micro primer and all coats were smoothed with Micro Mesh 6000 which I have found is the optimum grade for the job. Hope they will be of interest and benefit to someone.
This was my first attempt about ten years ago. It's an Academy Mirage 111c. Very inexpensive kit with good surface detail that went together well. This was the first model I tried painting on the markings using commercial masks. The fin flashing and engine intake area were masked and sprayed too.
Pleased with the result I tackled an F86 next, another Academy kit but this time using a CMK cockpit. At the time we had an ex F-86 crew chief in our club so I had some first hand advice. I opened the panel and scratch built the inside. It's perhaps a little over weathered but it is meant to portray an aircraft at the height of the Korean war when these aircraft were flying as many as eight missions a day.
All the insignia and colour bands are masked and sprayed - 'USAF' being cut from Tamiya tape by hand.
It would be a long time before the next one was tackled - several tanks got in the way - but the B-26 Marauder is a particularly favourite aircraft though I was put off for a long time by those raised lines of the kit and the thought of rescribing them. In the end the model was primed first then all the lines rubbed down leaving just a hint. The lines were then accentuated by paint alone. Lot's of masking of small areas at a time but satisfying. It's all painted, there are no decals on this model.
Last one done was another all time favourite the F100 Super Sabre. Again I'd had a Monogram version going, gradually re-scribing it when Trumpeter announced their 1/48 version. This is the 'C' - the 'D' sits under the bench. Apart from the small stencilling and the legends around the cockpit the markings are all masked and sprayed.
Well that brings it up to date - next up is the 1/32 F-100D that I'm doing for the Group Build. I've decided to do that in French service as many of those aircraft exhibit some very colourful heat stains.
Hope these are of interest
Regards - Tug
