primer
    January 2014
primer
Posted by riptide on Thursday, January 23, 2014 10:40 AM
is it better touse primer prior to painting.?
    January 2006
Posted by RedCorvette on Friday, January 24, 2014 10:56 AM
It's certainly not manditory, really more of a personal preference.
I use primer most of the time to check for problems with glue seams and to give a consistent base for color coats.  I use Testors gray primer most of the time, but also use flat white if the if the final coats are going to be lighter colors like gloss white, yellow, etc.
There have been lot of  in-depth discussions on this subject in the past.  It might be helpful to use the search function to look up some of the older threads.
Mark
FSM Charter Subscriber
    March 2005
Posted by Devil Dawg on Friday, January 24, 2014 9:12 PM
I don't use primer for painting. I do use it sometimes to see if a seam is still present, but I mainly just fill the seams & blemishes (if needed), sand til smooth, give it a good wipe-down with denatured alcohol, let it dry, then paint whatever colors the model calls for. Oh, and I mask before I paint it.......... Forgot that very important step.
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
