Hasegawa 1/32 P-40E
    February 2014
Hasegawa 1/32 P-40E
Posted by dflu78 on Tuesday, March 11, 2014 12:22 PM
So this will be my first build log here. The first victim will be the following kit:
Aftermarket (minimal):
* CMK Instrument Panel
* Montex Mask
*HGW Seatbelts (the cut yourself variety - N. E. V. E. R. A. G. A. I. N.)
I'll be doing the Box Art scheme, but will be using the Montex Masks for theinsignia and tail codes.
Pretty easy pickings so far. Got the cockpit tub finished up. Modest scratching of IP cables since they are visable under windscreen and a makeshift O2 hose from some wire. Artistic license in some of the detail color. That's how I roll.
9E28FA0C-4EB9-49EC-8E44-7B5576CDC7E6_zps
BF7BE512-CFA1-4E8F-9ECA-61E1F77E7593_zps
389E7319-8EBE-4FE6-8C44-D40616C813C3_zps
9C4411B3-87E9-4D87-AD77-92A505BCB36B_zps
Got the fuse closed up and decided I'd test fit the wings. Oh the horrors:
FA9C7DFE-7DD1-4605-8C88-FCB6EF53705B_zps
Doing some some fiddling I kind of figured out that the wings weren't anywhere near proper dihedral which was contributing to the ugliness. Then I realized that the wing spar that joins the wheel wells together could be used to pull the wings into place. When I glued that down I was much happier:
D5BFFBE3-5D0A-4B1F-BF8E-806C0AF88CC0_zps
P. S. Photobucket is &%$* I edited these pictures...making them smaller and cooler...and for some reason they are coming up as original...even though PB shows them in edited form.
    March 2010
Posted by Nathan T on Tuesday, March 11, 2014 12:51 PM
I like how you roll. Nice looking seat belts and instrument panel. This is gotta be Hasegawa's most perfect kit, in both 1/48 and 1/32 scale. Did you try adding a spreader bar of sprue to widen the fuselage to close the wing root gap?
...a what O2 hose??Whistling
    February 2014
Posted by dflu78 on Tuesday, March 11, 2014 1:21 PM
I'm going to look at that as a possibility tonight. All four hours of my bench time yesterday went to those darn belts. I'm thinking that with some Tenex that I'll be able to get the wings to hold, but will probably put a sprue spreader in there for good measure. The spar for the gear bays really helped close it up a lot.
Edit: Re: O2 hose....Hahahaha....thanks for pointing out the typo there ;) I missed it at first, and I generally actually proofread my posts.
    April 2009
Posted by Cadet Chuck on Tuesday, March 11, 2014 1:23 PM
Great job on the cockpit!  Too bad one can't see much of that stuff when the fuselage is closed up.  I, too, like to wing it with the colors.
I recently built a 1/32 P-40 from Trumpeter.  It was a nice kit and turned out well,  but I think it had less detail inside than yours.
I only paid about $30 for it, as the LHS was clearing out some old stock and offered us IPMS members first pick of the litter, for an additional 35% off the marked-down clearance price- I could not resist that!
(Re the oxygen hose- just carefully review how you spelled "makeshift" !  Har har!)
    April 2010
Posted by Theuns on Wednesday, March 12, 2014 12:51 AM
Very nice! I included your build on the P-40 GB roster :-)
Theuns
    February 2012
Posted by lawdog114 on Wednesday, March 12, 2014 3:14 AM
I like how you roll as well.  On Hasegawa kits, its best to Tenax  the upper wing to the wing root first.  When dry, add the lower wing.  If its too late for that, you could also stretch masking tape from wing tip to wing tip to force the roots together, then Tenax the joint.  When dry, release and it will return to the proper dihedral.  I've used this one many times with success.  I look forward to your progress.
Joe
    February 2014
Posted by dflu78 on Wednesday, March 12, 2014 11:31 AM
Thanks everyone for the encouragement.
Modest progress last night. Managed to get the wings glued up...first I had to remedy this silliness...really? Closed up ejection slots in 1/32?
Threw in a spar to spread things open a bit.
So with the spreader at the wing root I was able to get a near flawless join. I used Tenex to attach all the other points first and once those were situated I ran Tamiya Extra Thin down the root seam and it welded up beautifully. Managed to clean up most everything and attach the vertical stabs. Few places I had to dab some Mr. Surfacer to clean up some bubbles. Should be able to wrap up major construction in the next couple of days.
    February 2011
Posted by Reasoned on Wednesday, March 12, 2014 3:03 PM
Excellent progress.
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
Posted by Tojo72 on Wednesday, March 12, 2014 3:31 PM
I know you,looks good here too,great details and painting in the pit
Posted by 7474 on Wednesday, March 12, 2014 10:17 PM
Awesome job so far
Posted by Bish on Thursday, March 13, 2014 2:38 PM
very nice work so far, the pit looks great.
What don't you like about the HGW belts, everyone else I have come across who use them love them.
    February 2014
Posted by dflu78 on Thursday, March 13, 2014 3:00 PM
Well they were the uncut versions which I didn't know at the time of ordering. They have laser cut ones now. Cutting them out was the biggest hassle. After that it wasn't too bad they are just really fiddly. I'm not convinced the time they took me was worth it say over painting resin molded ones. I'll use the laser cut ones probably, but after I use the other set on my P-47 I won't get the cut yourself kind
    February 2014
Posted by USMC6094 on Thursday, March 13, 2014 7:48 PM
great progress, I'm enjoying the progression
    August 2009
Posted by JOE RIX on Thursday, March 13, 2014 7:59 PM
I'm loving the work you have done on P-40, dflu. Your cockpit is simply excellent.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    February 2014
Posted by dflu78 on Sunday, March 16, 2014 11:08 PM
Things were going so well...I thought I'd begin the painting process three days ago, but when I masked up and glued down the glazing behind the pilots head the trouble began. Hasegawa molded the pieces in such a way that they create panel lines that aren't supposed to be there. I had a heck of a time eliminating the seams. Putty, CA, more putty, more CA. It took three nights of bench time. Finally, today I got them where I wanted and was able to begin painting.
Primed with Mr. Surface 1500
Since stupid Sprue Bros was out of the black Mr. Surfacer, so I had to hit it with some black...I always prime with black..helps with the blending process during painting.
This is how I've been tackling painting as of late. Begin with the base color (Azure Blue) and work it in to centers of panels in a patchy way.
Next I just start building up HIGHLY diluted coats of the base color. The patchy work above helps to provide an uneven worn paint look I like.
1st go:
My stopping point on the bottom:
That's where I am at now. Next up I will go in with some slightly lightened base and add highlights...then do the same with slightly darkened base.
(Side note: Finally stopped being lazy and bought 6 clip on desk lights, so my pics should get a little better :))
    February 2014
Posted by dflu78 on Monday, March 17, 2014 11:19 PM
Ugh, I feel like I'm having a hard time keeping up having come in when I did. Great looking work all around. I really am enjoying seeing everyone's build.
Got some more work done tonight. Hopefully I'm getting the underside near completion.
First I darkened the base color of Azure blue with some black. I got it a little darker than intended, but that's ok it can be compensated for with the follwing step. I use this mixture to highlight panel lines and details.
Next it's back to the base color for a blending coat. Heavily thinned passes to blend it back in. I stopped here. It's a little more stark than I'd like the final look to be. However, I've found that after weathering and clear coats etc when I've toned it down more than this I've come close to loosing the effect. So even though I'm really wanting to hit it some more, I think I'm leaving it here.
Next was some work on the exhaust. I generally paint them Alclad Steel and then hit them with AK Interactive "Track Wash." Plain steel on the left and with the wash on the right. It gives it a nice oxidized look.
Been working on the landing gear legs too. Sprayed with Alclad Airframe Aluminum and Dull Aluminum
Washed with AK Dark Brown
    February 2014
Posted by dflu78 on Thursday, March 20, 2014 11:36 PM
After taking last night off from the bench it was back to paintwork tonight. Nothing special, did shading on the Dark Earth color:
Then it was time to use some poster tack and get the green down. I know a lot of people do the whole subject at once, but I work in sections...makes it easier I think.
All done
Of course it looks goofy with the Earth shaded and the green opaque...so some shading:
Had to do a few touch ups of both the top and bottom colors, but now it's time to move on to masking and painting insignia and markings.
As always, thanks for looking in.
    March 2010
Posted by Nathan T on Friday, March 21, 2014 8:57 AM
Those are some really nice camo lines.
Posted by Tojo72 on Friday, March 21, 2014 9:05 AM
making real nice progress
    November 2011
Posted by Newtothis on Saturday, March 22, 2014 12:32 AM
Really very nice.  A 1/48 or 1/32 P40 is on my to-do list also.
    February 2014
Posted by dflu78 on Sunday, March 23, 2014 10:53 PM
Ok. Two nights masking, painting, drying, repeat and all the painting is done (minus a small touch up). Insignia courtesy of Montex Masks (also tail number, but it's not visible in the pics here).
Alclad Gloss. Nice stuff. Performed much better than Future after the second coat.
    February 2014
Posted by dflu78 on Wednesday, April 2, 2014 11:45 PM
ALL DONE!!!
What a blast this one was. My second completion of the year, but the other one having been mostly completed before moving, this one is special.
No issues with the kit at all really. The seam where the tail section attaches needed some love, as did the seams in non-panel line locations around the rear canopy glazing. Time consuming, but not challenging particularly.
Aftermarket:
HGW U.S. Seatbelts (not pre-cut)
Montex Masks
Paints:
Upper surfaces: Gunze Lacquer
Under-surface and Interior: Model Master Enamel
Alclad where needed
Vallejo for detailed brush painting
Weathering:
Oil dot filters
Flory Promodeler Wash (Dark Dirt)
AK Interactive Dark Brown Wash, Streaking Grime, Track Wash
Silver Artist Pencil
    December 2006
Posted by Fly-n-hi on Thursday, April 3, 2014 12:15 AM
Excellent work!  I really love the P-40.  It has such great lines!
Posted by Tojo72 on Thursday, April 3, 2014 7:07 AM
Finished up real nice,great job
    June 2013
Posted by bvallot on Thursday, April 3, 2014 10:40 PM
On the bench:
Tamiya F4U-1  Kenneth Walsh
    February 2014
Posted by dflu78 on Friday, April 4, 2014 12:04 AM
Thanks kindly gentleman.
I agree re: the lines of this aircraft. It's always been one of my favs for sure.
This one is sitting next to a 109 on my shelf and wow...it really gives an idea of how big it is...or how small the 109 is...lol.
    December 2013
Posted by Raymond G on Friday, April 4, 2014 2:53 AM
Sweet looking bird!  I'll start on mine in the next few days, I only hope I can do half as good a job as you did!  Thanks for sharing with us, Raymond
On the Bench:
U.S.S. Arizona (Revell)
P-51D Tribute (Revell)
57 Chevy Bel Air
Posted by Bish on Friday, April 4, 2014 4:28 AM
Great looking build, really nice job on the paint scheme, nice to see one of these on here. Nice work.
    February 2011
Posted by Reasoned on Friday, April 4, 2014 11:43 AM
Yes Terrific build!
Posted by jeaton01 on Saturday, April 5, 2014 10:29 PM
Very nice!
John
