dose this kit exist
    August 2013
dose this kit exist
Posted by pws73703 on Wednesday, March 19, 2014 1:45 AM
Posted by Bish on Wednesday, March 19, 2014 7:26 AM
Don't know if you have a scale in mind, my search only found this one.
www.1999.co.jp/.../1
    March 2005
Posted by Devil Dawg on Friday, March 21, 2014 9:19 PM
Seems to be two different airframes. The first picture is a two-seater with regular afterburning engines, and the link in Bish's posting shows a single-seater with thrust-vectoring nozzles on the engines. I always thought only one of these STOVL/MTD aircraft were built. Shows you what I know!
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    March 2005
Posted by Devil Dawg on Friday, March 21, 2014 9:23 PM
Well, after researching it a bit on-line, seems I was correct - only one of these was built, and was converted three times to demonstrate different technologies (one of these conversions involved it being converted to a two-seater), and, in the process, three different tail numbers were used on the same airframe. Cool stuff. Hope you get to build one of these kits, pws!
Devil Dawg
    August 2013
Posted by pws73703 on Friday, March 21, 2014 10:51 PM
Yeah im looking for a 1/48th or 72nd scale and by the looks of it I could almost just use f18 horizontal stabs
    March 2005
Posted by Devil Dawg on Saturday, March 22, 2014 6:30 PM
Probably wouldn't be too hard to just cut them from sheet plastic and use a standard F-15E kit for the one in your picture.
Devil Dawg
    August 2005
Posted by Phil_H on Saturday, March 22, 2014 6:49 PM
It was always a 2-seater, being built originally as the first F-15B.
As such (being an early-build), it had the "short" airbrake and this would need to be backdated if starting from an F-15E kit.
PS: The aircraft as depicted in the top pic also has thrust vectoring nozzles, only not the squared-off type. I believe these ones only translated in the vertical plane.
The "short" airbrake and nozzles can be seen here: http://upload.wikimedia.org/wikipedia/commons/f/fb/F-15-vector.jpg
    August 2013
Posted by pws73703 on Saturday, March 22, 2014 7:57 PM
Ive always liked these ac to bad they never went to front line service
