Revell 1:48 Stearman PT-17 Build
    March 2005
Posted by philo426 on Sunday, April 20, 2014 8:34 AM
The prop looks great!I think this one should win its fair share of awards!
Posted by Don Stauffer on Sunday, April 20, 2014 10:59 AM
Bearcat57
My Stearman arrived the other day. Looking it over, I haven't decided whether to rig it with EZ-line or very thin piano wire cut to length and pop the ends into holes drilled with a micro bit.
As I believe was previously alluded to, it would've been handy if Revell would have provided guide holes or notches for the rigging.
Oh well, all part of the "I built it myself" experience I s'pose.
The problem with stainless steel wire is that in a size that is reasonably close to scale, it is very flimsy and floppy. It will not stay straight unless you get to nearly 30 mil, and that looks to big.  I intend to use mono thread, which is about what the EZ-line is.  I find it can be colored with a silver marker pen.
    February 2014
Posted by USMC6094 on Sunday, April 20, 2014 11:58 AM
I know all about the new Revell decals, I ran into the same problem with the CH-53 I don't know what they're using for decal film but its impervious to everything I've tried too
    November 2006
Posted by Bearcat57 on Sunday, April 20, 2014 4:52 PM
been doing a little experimenting and I think you're spot on about the wire being too flimsy, Don. Guess I'll be going the EZ-Line route. Not really looking forward to that part of the build I must say.
    November 2008
Posted by plasticjunkie on Sunday, April 20, 2014 7:14 PM
Why not use Wonder invicible Thread?  Comes in different thicknesses.
 GIFMaker.org_jy_Ayj_O
    February 2006
Posted by ruddratt on Sunday, April 20, 2014 9:47 PM
Actually, stainless steel would work fine if you used bus wire. It's very stiff and perfectly straight. I've purchased it in two widths, .005" and .007".  However, it has no give in it whatsoever, and any slight torquing of the wings can cause it to pop out of one of its mounting holes.  To eliminate that, I make sure the mounting holes are sufficiently deep and only glue one end, thus allowing the line to 'slide' a bit should the wings twist through handling of any kind.
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    February 2013
Posted by ZYates87 on Sunday, April 20, 2014 11:44 PM
Beautiful work so far! The prop decals look amazing.
All my best,
Zac in New Zealand
    July 2010
Posted by docidle on Monday, April 21, 2014 1:46 AM
Alan,
Thanks for posting your build.  I purchased mine last week due in part to your thread.  You are doing a great job, although you are building the Army version (3rd generation Navy here).  My plan is to build every plane my dad flew during his 25 year career, and this is what he started in.
Steve
    December 2009
Posted by ww2psycho on Monday, April 21, 2014 5:12 PM
I'm going to agree with Alan and say that this kit needs PE seat belts or some resin seats, Maybe I'm just not a fan of hand painting seat belts, but I really don't like them.
Posted by Don Stauffer on Tuesday, April 22, 2014 8:51 AM
I'm going to try leaving the lap belts, but I have already filed off the shoulder straps from the seats, and will use masking tape straps.  The molded-in straps just do not look convincing.
    October 2010
Posted by AlanF on Tuesday, April 22, 2014 1:21 PM
Sorry for the lack of posting, but I haven't made a lot of progress. It's been so nice out that I've been doing a lot of hiking and nature/landscape photography (and of course processing those photographs) during my off time. Thank's for the kind words regarding the prop.
I would love to see what you do with the belts Don.  I was going to do some masking tape ones but just went with painting them.
On rigging, my first rigged plane was done using wire and it was way out of scale so I went with thin EZ-Line here. The main problem is that in some places there aren't any locator holes or depressions to show where the rigging goes, so it's some guess work. When I make another one of these, I will drill out some holes for the rigging, but on this one I decided to try just superglue and EZ-Line.  The stretchy nature of EZ-Line can be a curse or a blessing - I'm not sure which one it is.  Call me crazy but I decided to start the rigging with the top wing off, which I think, this plane lends itself too.
Here's my start:
I'll probably paint the rigging a neutral/dark grey or maybe NATO black.
I hope to finish soon.
    March 2013
Posted by patrick206 on Tuesday, April 22, 2014 2:14 PM
Alan - Airplanes that used flying and landing streamlined bracing, incorporated stainless steel I think. The round stock was reshaped in a streamlined appearance, except at the outer attachment points where it would thread into a clevis. Rarely have I seen any that were of highly polished appearance. Perhaps a medium gray or steel would replicate actual bracing color, my wife gave me a colored marker set that has dozens of colors, metal included. I've used them on a number of different rigging jobs and I was pleased with the results, they build up less material than paint does, so the lines retain proper thickness.
The job is coming along beautifully, thanks for all the photos, it looks great.
Patrick
    April 2014
Posted by kestrel0222 on Tuesday, April 22, 2014 3:24 PM
Alan,
Model looks great!!! I am seriously considering building one of these very soon.
Tom
Posted by jeaton01 on Tuesday, April 22, 2014 11:51 PM
Alan there are four additional wires that go from the center of the fuselage to the top of the front cabane struts, two on each side, close together.  The instructions don't show these.  You can't see them with the layer of paint on, but in most every case there are little raised spots where wires terminate on the model.  It takes an optivisor to see them and it doesn't hurt to rub over them with a pencil lead to highlight them either.  I drilled holes part through on mine.
John
To see build logs for my models:  http://goldeneramodel.com/mymodels/mymodels.htm
Posted by Don Stauffer on Wednesday, April 23, 2014 9:02 AM
patrick206
Patrick
This is a problem of whether to build a model as a restored object or in its original service condition.  I see a lot of restored  Stearmans with highly polished flying wires, kept very clean.  However, even in original service stainless does not weather to too bad an appearance. It may not have looked like chrome, but as I remember older unpolished flying wires, they look like quite mildly weathered aluminum, no duller or darker than that. I personally find those aluminum or silver markers do a very nice job of representing the forged stainless flying wires.  For the older, stranded wire used in WW1, I do use a medium gray, but for stainless I like it a little brighter.
Posted by Don Stauffer on Wednesday, April 23, 2014 10:59 AM
Okay, got my fuselage interior sides masked and painted. Lots of fancy masking but I hope it is worth it.  The bare painted fuselage side has some big variations in stringer width, but with the tubing framework sitting over it I think it looks okay.
That is the bare painted fuselage side.
This is after the frame structure laid over it. I think it looks okay.  The light whitish color represents the covering, the green the formers and stringers.
Posted by jeaton01 on Wednesday, April 23, 2014 11:15 AM
Nice effect, Don
John
    September 2006
Posted by the Baron on Wednesday, April 23, 2014 11:56 AM
Beautiful build!  I really like the wood effect on the prop, too.
Regarding the rigging, has anyone ever thought of using Evergreen strip?  I think in this scale, the thinnest strip in the catalog gives you a good look of the aerodynamic cross-section of the steel RAF wire used for rigging.  That came to me, after I first saw Accurate Miniature's F3F kit, back in the day, with the PE rigging, and after I took a good look at Stearmans at the Mid-Atlantic Air Museum in Reading.
Oh, and a bit of trivia about "Tora! Tora! Tora!" and the scene with the civilian trainer.  In the movie, they used a Stearman, but the actual incident involved an Interstate Cadet, if I'm not mistaken.  The lady instructor was Cornelia Fort, who went on to join the WAFS.  She died in a mid-air collision, sadly.
Posted by Don Stauffer on Thursday, April 24, 2014 9:05 AM
I believe there were several light planes and  trainers on training flights during the attack- including both the Stearman and some other plane which may have been the Interstate.  Air and Space magazine ran an article about this several months to a couple of years ago- I don't remember the issue.  But, it had the names of all the people involved. If I remember correctly the Stearman and its crew survived, the Interstate did not.
    September 2006
Posted by the Baron on Thursday, April 24, 2014 12:05 PM
I think you're correct, Don, but I think it was destroyed on the ground, after Fort had landed and as the Japanese fanned out to attack the outlying airfields and installations.
There's a good question--was the Cadet ever kitted by any maker?
Posted by Don Stauffer on Friday, April 25, 2014 9:08 AM
Don't know of a plastic kit, but there was a balsa flying model that was quite detailed and close to scale, though horizontal empennage was likely larger than scale.  I think it may have been a Sterling kit.
    April 2014
Posted by RBEARON on Wednesday, April 30, 2014 12:52 PM
Hi Guys, I have been reading with a lot of interest here and I am overjoyed to see a new model of Stearman hit the market.  Just a couple of quick notes:  The McCauley is NOT ALUMINUM but is a ground adjustable STEEL prop.  TIn the past they have been chromed, but this is no longer legal.  They should be painted black with Yellow tips.  Also, the PT-13 used a Lycoming 9 cylinder, the PT-17 used the Continental, and the PT-18 was powered by a Jacobs.  The model looks great!
    October 2010
Posted by AlanF on Friday, May 2, 2014 1:02 PM
Sorry for the lack of posts, April was a busy month.  Last night I wanted to make a major push to get this build done so I finished the rigging. However, I ran into a snag. Somehow, I lost a few decals. (I'm blaming the dog. He ate my decals. LOL).  Anyway, if anyone here is building the all Yellow Stearman and wouldn't mind taking pity on me, I could use the #21 (small 456 for engine cowlings) and #24 (tail registration numbers) decals that are specific to the Army version.  If not, I'll go ahead and complete the model without them and add them when I get another Stearman because I plan to build the Navy one with what I learned during this build.
    October 2010
Posted by AlanF on Wednesday, May 7, 2014 5:21 PM
DONE!  I made it through the final push to finish the Stearman.  She is a bit dirty. Indifferent
It wasn't a bad build but there were (are) problems.
The struts don't fit quite right. It may have been my doing as I rigged it before applying the top wing but they are bent a bit. I didn't see this during test fitting so the rigging might have done it.
I'm not happy with the rigging. Next time I'll drill some small holes and insert the rigging in them and then seal with a drop of superglue.  I don't like the effect with the glue on top. It didn't come out the way I hoped. While more painful, I think I'll rig the next one after putting on the upper wing.
All that nice engine detail is hidden. I'll probably open up the next one so it can be seen.
I definitely plan on building another.
Posted by jeaton01 on Wednesday, May 7, 2014 8:47 PM
Overall it looks pretty good, Alan.  Every time I do rigging I do it a little better but I have yet to do the job I see in my mind's eye.
John
    December 2009
Posted by ww2psycho on Wednesday, May 7, 2014 8:52 PM
That looks really good! I'm scared to do the rigging on mine. I realize after looking at your picture that the styrene rod I bought is going to be too thick but maybe It will be better for me since I've never done rigging before.
    June 2003
Posted by allan on Wednesday, May 7, 2014 9:48 PM
10/10!!
She's a stunner!  Thank you for sharing that.
The fuselage frame reminds me of an OH-13.
Impressive work Revell did on this kit.  I wish theyd make a 1/72.
No bucks, no Buck Rogers
    July 2010
Posted by docidle on Wednesday, May 7, 2014 11:25 PM
Allan,
She looks great!  As I had said in an earlier post, I have this model in my stash, so thanks for doing a build log.  I am a ship builder mainly so all the help I can get is greatly appreciated.
Steve
    February 2006
Posted by ruddratt on Thursday, May 8, 2014 1:26 AM
That's some nice stuff Alan !  Really enjoyed watching this one come together.  Yes
Posted by Don Stauffer on Thursday, May 8, 2014 8:53 AM
Very nice.  I like the weathering.
