Hey all. I have been wanting to build an A-10 for a while now. This is the first kit that I have used after market parts on and it's some trial and error in that area. Progress will most likely be slow and I will upload pictures as they are taken.
Kit is a Revell 1:48 A-10 Warthog. Aftermarket parts include a Verlinden electronics bay and a few other open panels (photo etched metal is a first for me as well). I also picked up a True Details cockpit for it. The verlinden kit came with a cockpit, but I liked the TD one better. I have been looking for an AM set for the gun but the only one I found was out of stock and its been about 2 weeks with no word if the company will get more, so if you know where I can get one let me know! So, without further ado, lets begin with pictures.
This is what I have done so far, the cockpit and the Verlinden products. Also drilled out the panels for the electronics bay and the like...
Close up of main console, sorry for blurriness
Some of the cockpit, one had a flash on the other didn't and then a side view just so you can get the back part of it.
The True Details cockpit really is a great kit to add to this plane and it was only about $9. Next is the photoetched parts of what I have so far...
Ok so this is the first kit I've cut up and all I can say is thank God for dremel tools. Made quick work of the panels. Only 2 parts glued to the kit and I have already learned a few things about PE parts. They bend easily and can get glued to your fingers quickly too! Ouch. You will see some scratched paint, I had painted the forward part of the plane because I was painting something else and didn't want to waste the paint and couldn't put it back in the container. So it will all get taken off before the real painting occurs.
So my first lesson was be careful with the glue! Obvious I know but in my excited frenzy to work on it I got sloppy. Second lesson was that when I removed the kit plastic I should have left a lip for the PE to get glued to, it's fragile in its current state. The photo below has the panel door open, it won't be glued on till painting of the fuselage is done, and the actual resin part is just taped inside so I could test fit everything.
Next two pictures are of the electronics bay on the other side of the plane. I took the lessons I learned so quickly and left a lip of plastic for it to sit on, and was careful with the glue. I actually taped off the section so any glue that did run over would hit tape and I could lift it up quickly before it started eating away at the plastic.
Let me know what you guys think! Any and all comments are welcome! Also, I'm not doing a super accurate model, I'm not too concerned if the ILS antenna or GPS is in the right spot. I will be painting it in a grey scheme though.
Looks good so far. Good to see you diving into the AM world. Beware, though, because once you do it its hard to build without it. Start saving $$$ now!
[URL=http://picasion.com/]
Keep this coming dude. Watch those dremels man....,it's only plastic. Lookin' good
Forum | Modelers Social Club Forum (proboards.com)
Nice work Squatch - i still haven't taken the plunge into A/M or resin upgrades - but I do want too.
Good on you for jumping in - the effort is paying off. I guess i'll need to add a dremel to my list of "must have tools to sit in my drawer for 'one day'" :)
Looking forward to further updates.
Chris
cmli still haven't taken the plunge into A/M or resin upgrades - but I do want too.
CML you can get a cheap dremel from Harbour Freight if you have any near you. If you want to get into the AM try just a resin kit that doesn't have a ton of pieces, that's what kept me away because I thought it was too far past my level. And as Mustang said it opens up an entirely new world!
I found a more detailed gun for the A-10! Should be here in 7-10 days. I'll do what I can till I get it but I don't think I'll be able to close up the halves before I get it.
Looks great so far! I too haven't tried AM yet, and I have this same kit so I'll probably end up getting the true details cockpit, at $9 I figure if I screw up I'll just use the kits cockpit. Anyways, keep up the good work! I'll be watching this one closely
-Josiah
SO glad to see someone on here doing an A-10. LOVE these jets. Good luck on your endeavor to chop the hell outta that thing. I've been waiting to do the same thing. HobbyBoss has a kit that comes with the GAU-8 to build up. I've been drooling over that for about 3 years now. I'll get around to it one day I keep telling myself.
It's lookin' good so far. Don't sweat the PE stuff. I had a hard time with it too at first. The right tool for the job has saved me a lot of headache and frustration. I might suggestion you pick up a couple of different tweezers and precision tips for the CA you'll use on them. That's a good start for you if you haven't put them in your toolbox already.
On the bench:
Tamiya F4U-1 Kenneth Walsh
Nice start, good work on the cockpit. Which is the gun you were looking at.
Fly-n-hi Looks good so far. Good to see you diving into the AM world. Beware, though, because once you do it its hard to build without it. Start saving $$$ now!
I'll second that. Now when I get a kit that there is no AM for, I get the shakes, I have to start looking through the spares box. Its more addictive than GB's.
Well, almost.
Master Model A-10 Thunderbolt II GAU-8 Avenger Gun Tip & Pitot Tube is the gun I wanted, the site I was looking at it though had it out of stock, so I went elsewhere and found it for the same price. So it'll be here in about a week. Thanks for the comments guys!
I was wondering if that was the one you meant. I got the 72nd one a few weeks back, looks really nice. Glad to hear you got hold of it.
In looking at reference pictures (google) I have a few questions maybe someone can answer. Since I'm having panels open what color would the inside be? I've seen a few with white panels and a few with yellow. I'm partial to the white. Same with the spoilers, they are molded open and I've seen either red or white or gray. I know I have other questions but I cant remember them right now ha
Alright well I liked the white panels, so I think I'll go with it. I haven't painted them yet but I did get the electronics bay painted up. I searched for a while online and couldn't find any pictures of the open electronics bay, only other modelers works that they had completed. I like the first picture because it shows what gluing with paint does and how sloppy the first PE piece was put down haha
I think it turned out fairly well. I used a toothpick to get some random dials and I dry brushed some white as well. It will eventually get a pinwash when I weather the plane, but thats another day!
Can't see the pics :'(
There seems to be something wrong with the link to PB.
Ya I posted the pics here then tried to organize my PB account into different folders for different builds and such. Are the previous pictures still showing up?
Ye, the other ones are ok, just those last ones.
ok these are the last 3 pics I posted here before I messed up the photos. If anyone has any issues with photos not showing up let me know and I'll just repost all the pictures I have put up so far! Sorry for the mess up! Stupid technology ha
Now that's better. That is some really nice detailing in there. Is all of that part of the AM set.
Yes thats the verlinden electronics bay. I think it looks great and am going to paint the panels white. I see the first 3 pictures in the original post are fine, but when I pull it up it has the "sorry this link is no longer working" for the rest of the pics...anyone else having issues?
I see the pictures and they look quite well, keep up the good work
BishNow when I get a kit that there is no AM for, I get the shakes, I have to start looking through the spares box. Its more addictive than GB's.
Details look really good dude. Really good!
Looking good. I can only see the last three pictures though. :( Bob
Looking good! I actually just picked up this kit and the verlinden set. I just finished an A-10 from tamiya and saw this at Michael's when I was getting some other things. Just thought, hmm what can make an A-10 kit nicer? Another one! Except it'll be in the USAF grey scheme.
ok guys, I think I fixed the picture issues that were at the beginning of the post, they should all be showing up now. Also my gun finally arrived and I have a few pics to upload! Slow progress since I had some extra shifts at work and then a bachelor party this weekend. So these pictures are the kit gun and the AM gun unassembled and on the putty getting painted
I put all the parts on a string of putty, painted them with vallejo dark grey and just a drop of blue since I've heard of a couple other guys doing it, and I must say it looks pretty good compared to just straight black.
I can defiantly see why you wanted to replace that gun.
This is fun to watch. You're doing a great job.
Those brass gun parts look cool! That nose gun will look great!
Neat idea, a drop of blue in black to simulate gunmetal. Thanks for the tip.
The gun is painted and I test fit it on there. I couldn't get my camera to focus so only 2 pictures. I'm not very happy with the paint job on it, but it is what it is, and it's still miles ahead of the kit gun. It still needs a little more fidgeting to get the fitting right, and the tiny parts are a pain in my butt! I glued the gun to my fingers twice haha
