Hasegawa 1/48 F-22 Raptor - painting disaster!
    March 2005
Posted by oakleyposterboy on Saturday, August 16, 2014 1:01 PM
I've been building Hasegawa's 1/48 Raptor and its been a giant exercise in frustration.  I usually use MM & Tamiya Acrylics but because of the special colors there's just no analogs in those paints.
The base gray, a 50/50 mix of Mr. Color 314 (FS16440 gray) and super stainless, doesn't seem to stick to plastic.  I've tried sealers and gloss coats but if I try to mask it then it peels right off.  We originally tried mixing Tamiya X-11 with MM 16440, but it did not look good at all.
The afterburners are burnt iron and steel, but again, the burnt iron doesn't seem to stick to the plastic either.  I've been trying to use liquid mask and it just takes the paint right with it.
I'm about ready to throw the whole thing in the trash and start over, which is really a shame because I did a great job on the cockpit and gear bays.  Any suggestions for how I can salvage my model?  Is there at least a good way to crack open the fuselage so I can save the good bits?
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” -George Carlin
    March 2010
Posted by mach71 on Saturday, August 16, 2014 1:38 PM
It's probably just the stealth skin!
But seriously, what did you prime with?
    July 2014
Posted by dscri001 on Sunday, August 17, 2014 3:33 PM
I actually just finished the same kit and used the mr color paints with super metallic as well. I've heard that mr color paints play well within their own system. What did you thin with? I spray tamiya's fine primer and then mixed the mr color paints according to the manual. I thinned it pretty well with mr color thinner and had great results. Hope this helps! Its a great kit and the metallic finish is awesome!
    December 2013
Posted by Raymond G on Sunday, August 17, 2014 10:56 PM
Yeah, sounds like you didn't prime it.  My understanding is that X amount of times you can get away with not priming, but...  it will come around and bite you in the buttocks eventually.  You may have to clean all the paint off, wash the model down with a little mild soap and water, rinse it gently, let it dry 24 hours, PRIME it with some Tamiya primer, and let it dry, then start painting again.  Just my amateurish 2 cents worth.  I'm sure others will chime in...  Good luck!!!  Raymond
On the Bench:
U.S.S. Arizona (Revell)
P-51D Tribute (Revell)
57 Chevy Bel Air
