Washes?
    February 2007
Washes?
Posted by Buckeye on Friday, August 29, 2014 7:31 PM
Have been out of the saddle for a while and wanted to pick a quick project so I could actually complete something.  I picked the 1:48 Tamiya FW-190A3.  Far from my best effort but it feels good to get something close to done.  I should add some more mottling and the canopy and windscreen haven't been glued on yet.
I was just starting a pin wash but haven't been happy with the results on my last few models.  I know there are some premixed washes on the market now and was wondering what everyone is using these days.
Thanks, Mike
    August 2009
Posted by TREYZX10R on Friday, August 29, 2014 7:55 PM
I've been using Citadel and Game Color all water base products BTW that Butcher bird is looking great.
Posted by Texgunner on Friday, August 29, 2014 10:16 PM
I've used this stuff on my last 2 or 3 builds.  It's clay-based and works really well and quite easy too.
http://www.florymodels.co.uk/washes/
"All you mugs need to get busy building, and post pics!"
    June 2013
Posted by RobGroot4 on Friday, August 29, 2014 11:11 PM
If that's far from your best, I give up!  Looks great from this angle.
I've used the citadel and it dries really quickly, so I personally have to work in small sections.  I've also had a little more success with thinned oils as they seem to be more forgiving and they give you time to actually make some progress before you have to come back and start wiping up.
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    February 2012
Posted by lawdog114 on Friday, August 29, 2014 11:28 PM
Awesome work Mike.  I second Gary's suggestion.  I use the Flory on all of my panel lines now.  Slop it on, let it dry, then wipe it off with a slightly damp paper towel .  It does a nice job bringing out all of the other details too, such as rivets.  I mix the Dark Dirt and Black to varing degrees.  You can get it at Sprue Brothers.
Joe
Posted by Bish on Saturday, August 30, 2014 2:49 AM
I am another Flory wash user, I love that stuff.
    September 2013
Posted by AdeB on Saturday, August 30, 2014 3:08 AM
I have tried a few but find my own method works best.
I use odourless thinners and add Black/brown oils until i get a nice thin mix.
Maybe give it go along side the commercial stuff and see how it goes.
Posted by Don Stauffer on Saturday, August 30, 2014 9:24 AM
If you do want to make your own, it has to be very thin.  If you are trying washes in panel lines, go very easy. It is too easy to overdo black or super dark panel lines.
    February 2007
Posted by Buckeye on Saturday, August 30, 2014 9:40 AM
Thanks guys!  I've been using oils but I just can't seem to get the mix right, either too thin or too thick.  Will get the Flory wash ordered and see how I like that.
Here's another pic but it's a bit washed out from the bright sunlight.  I think I'll add some more mottling.  Everything was done freehand with the airbrush except for the hard edge on the wings and horizontal stabilizer.  For that I cut masks from blue painters tape.
Will post more pics when I get it washed and add some silver chipping in wear areas and a little exhaust staining.
    November 2008
Posted by plasticjunkie on Sunday, August 31, 2014 10:04 AM
I mix my own with store bought thinner and artists oils. I do find that Flory product interesting. Is that available locally or only across the pond?
 GIFMaker.org_jy_Ayj_O
    February 2007
Posted by Buckeye on Sunday, August 31, 2014 10:22 AM
Sprue Brothers carries it but most are out of stock right now.
    November 2008
Posted by plasticjunkie on Sunday, August 31, 2014 10:29 AM
Thanks Buck. I may just get a couple of bottles to try it out. I got a couple of bottles of Vallejo wash but don't like how it behaves so I keep using my thinner and oil paint mix.
Posted by Don Stauffer on Sunday, August 31, 2014 10:33 AM
Also, I should have recommended checking out a couple of other forums that often have "washes" threads, the Techniques and the Painting and Airbrushing forums.
These are in the Tools, Techniques and Reference Materials area, the last area in the forums list.
    February 2007
Posted by Buckeye on Sunday, August 31, 2014 10:37 AM
Thanks Don, I always come to Aircraft first and try to make it "down there" when I can. LOL
Posted by Tojo72 on Sunday, August 31, 2014 10:50 AM
That Flory Wash is great stuff for sure.Great looking camo on your 190
    June 2014
Posted by BrandonK on Sunday, August 31, 2014 11:18 AM
I've been using odorless turpentine and artist oils. Black and burnt umber. I mix one bottle black to the look of coffee and the other bottle with burnt umber and small amount of black for a more dirt like affect. Again, it is as thin as coffee. Using a fine brush I dot it where I want it and use the turpentine with a Qtip to remove the areas I don't want after it has dried. Then seal it with my final coat. I am curious about the products listed above and may give them a try, but I am happy with my oil so far. The great thing about it is if you make a mistake or don't like it you can completely remove it and start over with no harm to the paint or decals.
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    August 2013
Posted by Jay Jay on Sunday, August 31, 2014 11:54 AM
Brandon,
i just bought the black and burnt umber oils and some Turpenoid but have yet to try them.
Will the oils affect NMF while Pin washing panel lines ?
    November 2008
Posted by plasticjunkie on Sunday, August 31, 2014 12:58 PM
Jay Jay
Brandon,
If the paint is acrylic no, if it's enamel or Lacquer yes. Regular thinner will dissolve Alclad or any solvent type base coat unless you top coated with an acrylic barrier coat.
You can get away at very light washes without disturbing the finish but why risk it?
    June 2014
Posted by BrandonK on Sunday, August 31, 2014 6:36 PM
This is where I learned my technique. The other methods my be better but I haven't tried them yet. I am very happy with my results thus far.
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    November 2008
Posted by plasticjunkie on Sunday, August 31, 2014 9:33 PM
Same method I use and works every time. I have to mention that I do not use all those expensive products featured in the video. I use regular turpentine from Home Depot and a set of Reeves artists oils from Hobby Lobby that was about $11 for 24 small tubes.
    February 2007
Posted by Buckeye on Monday, September 1, 2014 10:00 AM
BrandonK
This is what I have been doing, you may be able to see it better along the ailerons and elevators.  Maybe I just need more patience........................not one of my strong suits.Bang Head LOL
    May 2013
Posted by Greg on Monday, September 1, 2014 10:36 AM
Another Flory fan here.
Have tried other methods including artist oils and Vallejo, can't seem to get the hang of them.
I also lack in patience, making the Flory perfect for me. Slop it on, wipe away at my convenience. You can leave this stuff on forever and come back and wipe it off anytime. Or wash it all off and start over.
Highly recommend watching Flory's own 'how to" video on their site.
One word of caution, I find the clay-based pigment ever so slightly abrasive. On my first go with it, I got too aggressive 'scrubbing' over a too thin clear coat and did a tad bit of damage. My bad, the product isn't meant to be 'scrubbed' off, rather gently wiped.
Your 190 is looking awesome, Mike.
    February 2007
Posted by Buckeye on Monday, September 1, 2014 5:17 PM
Thanks Greg.  I have watched their how to video and thanks for the heads up on the abrasiveness.
    May 2013
Posted by Greg on Monday, September 1, 2014 8:36 PM
You're certainly welcome, Mike.
If you have trouble finding the Flory in stock somewhere, I seem to recall looking at their direct pricing and shipping charges across the pond, I think they were reasonable. But then my memory ain't the greatest.
Posted by Texgunner on Monday, September 1, 2014 11:17 PM
Greg
You're exactly right Greg.  I bought my set of washes directly from Phil Flory through his website and he was a really good guy to deal with.
Gary
    February 2007
Posted by Buckeye on Tuesday, September 2, 2014 7:19 AM
I think I may go that route myself if I can't find it over here this week.
    June 2003
Posted by Duke Maddog on Tuesday, September 2, 2014 10:17 AM
Jay Jay
Brandon,
Another product to use that is better than turpenoid is Mona Lisa thinner for oils. It is the most inert thinner on the market. I've mixed my oils with this thinner for my washes and placed it directly over enamel and lacquer finishes and have had no ill effects. You can find it in the paint section of any art supply store at a very reasonable price for the size of the container you get.
That being said, I've also used the Flory washes and enjoyed them as well. I never truly mastered the technique so mine were a bit slipshod. I ran out of supply before really learning how to do it well and I never knew where to get it again... until now.
    May 2013
Posted by Greg on Tuesday, September 2, 2014 10:26 AM
Gary, thank you for confirming my buying direct from Flory memory. Guess I have some (memory) left after all.
Duke, appreciate the post about Mona Lisa thinner. I keep meaning to buy some to see if I have better luck with oils using it. I think your post will be the one to send me over the edge and just do it.
    June 2014
Posted by BrandonK on Tuesday, September 2, 2014 11:43 AM
The only trouble I have had using them was my fault as they didn't cause the issue. If you clean or rub an area too much or too hard with the turpinoid you can rub through the clear and damage decals and paint underneath. I was able to see it happening and stopped before it was very noticeable and prevented further damage. If you thicken it a bit you can actually hand paint panel line shading if you want. I am curious about using the other method and will give it a go also so I can actually have a full opinion on what I prefer.
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    May 2013
Posted by Greg on Tuesday, September 2, 2014 12:17 PM
BrandonK
That's probably the best video tute I've seen for oil washes. Thank you for posting it, Brandon.
Makes me want to give it a go again, for sure.
