Decided to restart this Tup bomber.being iCM, it will be neither easy or quick with much body work ahead.Progress thus far;it does kind of resemble a shark !
ok!Dealt with seams and will soon commence with wing construction.
ICM has included a good instrument panel decal in the kit.
The seperate fuselage panels fit quite well.
The tail planes fit well also..Engineering is much better than expected.
There will be gaps at the wing roots.
Looking good ,off to a nice start!
gif creators
Yes!unlike the TB-3 this one should not prove to be nearly as difficult!
Wing clampage is essential.
Decided to resume this one after it took an unfortunate dive to the floor splitting the fuselage open.I threw it in a box in disgust!I feelmuch better after how well my Spitfire came out so I decided to repair the damage.Updates to follow.
Engine nacelle assembly.
Canopy masking.(Not fun)!
The glass came put pretty well.
Mounted up the landing gear and decided to paint the vertical stabilizers white.The white will make the red stars "pop"since the instructions do not call for red stars on the topside wings.
Glossed it with Future for the decals and mounted up the prop blades.
Ok she is about finished.ICM is known for their complex kits but it was not too bad.the plane is much heavier than a typical 1/72 kit due to the high parts count.I am pleased with the result.
