F-86 Shiny or not
    September 2012
F-86 Shiny or not
Posted by Squatch88 on Saturday, September 27, 2014 10:52 PM
Hey guys. Got the Revell F-86F Sabre kit this weekend. Looks pretty straight forward and I'm looking forward to knocking this one out fairly quickly. The last build of an A-10 I did dragged on too long. I've been looking at a few pictures and some have the fuselage shiny and wings dull, and other have all shiny or all dull. I was wanting to do it all shiny but also hoping to do an actual plane. Yellow towards the tip of the wings and yellow band around the aft fuselage. Any knowledge on the sheen of the wings/fuselage would make my painting easier.
    July 2004
Posted by stikpusher on Saturday, September 27, 2014 11:19 PM
Sabers in Korea operated in a pretty harsh environment. Summer monsoons, winter blizzards, no hangers, etc. Add in a high op tempo and there was not much time for polishing them up. Do an image search for some good ideas on how they appeared.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    June 2004
Posted by seasick on Sunday, September 28, 2014 1:31 AM
Shine it up nice for a new plane, for one that has been in theater for 6 months dull aluminum. Repairs will be shiny.
Chasing the ultimate build.
Posted by Texgunner on Sunday, September 28, 2014 1:36 AM
Here's how I did mine:
Big Smile
"All you mugs need to get busy building, and post pics!"
    December 2004
Posted by panzerpilot on Sunday, September 28, 2014 5:44 AM
I guess it depends on opinion. I just built one, but made it really shiny. More out of artistic license, than what a line bird would have had. However, it had to be bright, shiny and new at some point!
It didn't take them long to get worn, though. I understand they flew as many as 8 missions a day sometimes.
-Tom
Posted by Don Stauffer on Sunday, September 28, 2014 11:07 AM
Depends on environment and the care it recieves. In wartime there are far more things to do than clean and polish the airplanes.  So they start looking a bit grungy.
In times of peace, there will be at least one plane that is really shiny, the squadron commander's plane :-)
    July 2004
Posted by stikpusher on Sunday, September 28, 2014 11:57 PM
Don Stauffer
Very true... so at the time of the cease fire in 1953 there were 4 Fighter Wings equipped with F-86s....
4th
51st FIW
18th FBW
8th FBW
None are exceptionally shiny...
       - Plankton
LSM
    November 2008
Posted by plasticjunkie on Monday, September 29, 2014 7:18 AM
If you plan on using Alclad, try some gloss black enamel as a primer then use Alclad Polished Aluminum. It will be very shiny as is. But when Alclad Aqua Gloss clear is sprayed over, the shine will be dialed down to a slightly weathered finish.
 GIFMaker.org_jy_Ayj_O
    September 2012
Posted by Squatch88 on Monday, September 29, 2014 11:55 AM
I've been bouncing around on google and for the most part here is what I've seen. Time period photos most of them were grungy.  Modern photos have the fuselage shiny and new while the wings have a flat sheen to them. That's how I'm going to do mine.
Gloss black enamel-Alclad aluminum- Alclad clear coat. The kit has the yellow decals for the band around the mid section and wing tips, but for that big of an area I think painting would look better. Whats the best paint (since I'm doing the enamel-alclad combo) method of doing it? Stick with enamel or can I use acrylic on top of the alclad?
    December 2004
Posted by panzerpilot on Monday, September 29, 2014 12:33 PM
I had to paint the underside of the Sabre I built, since the decal would not look good over some of the raised detail. I used Yellow Tamiya acrylic, cut down with a bit of orange, but only to the match the decal on the side. I carefully cut the black decal outline out from the decal, for the border. Since Yellow goes well over silver, I was able to get a decent finish.You could use enamel as well, though acrylic is a bit more tame.
I have read various techniques to cut down the shine. One was floquil old silver (if you can find it) misted over airframe aluminum. I suppose you could use others. Alclad Dull aluminum? misted over the high shine, just enough to cut it down?
-Tom
    January 2014
Posted by Silver on Monday, September 29, 2014 12:38 PM
Complete the shiniest NMF job then hit it w/testors flat ..Let dry 24hrs then polish lightly and you will be on target w/the results.Trust me.
    November 2008
Posted by plasticjunkie on Monday, September 29, 2014 2:57 PM
You only use gloss black with the High shine Alclad colors, Chrome, Polished Alum and Airframe alum. The black is the key ingredient for the depth in the high shine Alclads and is not necessary if you use the non high shine Alclads, The reason for sealing High Shine Alclads is because the decal setting solutions may damage the finish as recommended by the manufacturer.
It's not necessary to seal the finish when using the regular Alclads. Some modelers spray Future over the plastic as a primer and then (after curing) spray the regular non high shine Alclad for a light to med oxidized look.
This explains it: http://alclad2.com/
