1/32 Hasegawa - Nakajima Ki-43-II Hayabusa (Oscar) - 59th Sentai, 2nd Chutai, Captain NANGO 1943
Hello everyone, just finished off this one. It is OOB except for scratch built harnesses, brass tubing added for guns, wiring inside cockpit and landing gear, and some wiring on the engine.
No decals used, all painted including the Hinomaru, fuselage bands and tail markings.
Interior is Gunze H63 metallic blue/green. I used Vallejo silver as base coat, then did pre-shading. After this I sparayed AK heavy chipping fluid where the Hinomaru would be underwing and all over on top where the green would be. After painting the green, (xf-61) I used a cut off brush and water to do "chipping". Although where the yellow leading edges and Hinomaru on top were it was very hard to break through, so I used silve on a brush for chipping effect on these areas.
Antenna wire is EZ line.
I am pretty happy with how it turned out, I wanted a real worn aircraft and I think I achieved that effect.
Thanks for looking.
