Airborne refueling scene.....
    May 2013
Posted by Blairy on Monday, October 27, 2014 2:16 AM
G'Day
I had a thought the other day and I am quite interested in following though with ambitious task somehow..... My thought was an airborne refueling scene, either from fighter to fighter, or tanker to fighter...... There are a few concepts running through my head such as whether I model a portion of a wing with the hose running from there to the jet, or whether I model a cut out section of the fuselage, wing root, a portion of the wing, hose and jet, or even model just the hose alone coming down to refuel the jet, oooooor I model two full jets together.....
The only Issue I can see, is that I can not seem to find a model of a 'tanker'....... or a civil aircraft I can modify in the right scale (i was thinking around 1/72 for a decent display).
My question to everybody is, have you seen anything like this before and do you have pics? and what issues you think I would encounter? and what your thoughts are in general?
I appreciate all input, and thanks for stopping by.
Eli
    March 2005
Posted by TarnShip on Monday, October 27, 2014 3:49 AM
Here are some 1/72 choices for a Tanker.
DC-10 with the basket trailing behind (for USN aircraft and some USAF), with the probe for USAF Phantoms and later USAF aircraft
C-130 Hercules with the basket or baskets
KA-3B Skywarrior
A-3B Skywarrior with the the tanker package (different than the above)
A-1H or A-1J Skyraider with refuelling store (Douglas D-704)
A-7 Corsair II with refuelling store (D-704)
KA-6D Intruder (with or without an extra refueling store on the centerline)( D-704)
A-6A or A-6E with the D-704
A-4 Skyhawk with refuelling store (D-704)
FJ-4 Fury with a different earlier refuelling store
F/A-18 Super Hornet with yet another different newer refuelling store
Aircraft receiving the fuel from baskets are all Navy types that served during the same years as each of your tankers, except for the Skyraiders.
The USAF probe fits in receptacles in the spine of the jet, such as the Phantom, the A-7D, etc, right up to the Stealth and F-22. (the Phantom and Corsair II were somewhat unique, the USAF couldn't refuel theirs from a Navy basket, and the Naval versions couldn't refuel from a USAF probe)
hope this helps you with search terms to find photos with
Rex
almost gone
    March 2005
Posted by TarnShip on Monday, October 27, 2014 3:52 AM
oh, I forgot,,,,,,,,,you can get the D-704 in resin, or in the Fujimi KA-6D tanker kit, there is a resin late Super Hornet refuelling store coming soon from Modern Hobbies,,,and the KA-3B is a kit from Hasegawa
I think it is Flightpath in the UK that has the KC-130 refuelling pods and conversion, but someone else may have to chime in to clarify that,,,,,,,I am not positive.
Rex
almost gone
    May 2013
Posted by Blairy on Monday, October 27, 2014 5:51 AM
Thanks for the info Rex, there are a few options out there for me to try and it seems most of the options you provided there are the fighter to fighter type refueling. And if I go down that path I really like the look of two 1/72 F-A-18F's because I can get the detail in there.
I think I am leaning towards a tanker somehow because it sounds like quite a challenge (which I seem to enjoy, don't ask why though LOL) I have found an interesting thread here, http://www.britmodeller.com/forums/index.php?/topic/234942741-kc-30a-conversion-raaf/ which turns a REVELL thai airlines A330-300 into a KC-30A which are currently in service with the RAAF.
Or another option is a 1985 Heller 1/72 707 kit.... Which would be biiiiiiiiiig, but fun :-)
Eli
Posted by Don Stauffer on Monday, October 27, 2014 9:04 AM
I bought a pair of A-6s (1:144)  with the idea of turning one into a tanker and then posing them in flight.  Maybe this thread will finally get me going on that.  Biggest problem for me is coming up with a way to build that drogue on the end of the hose.
    September 2005
Posted by richs26 on Monday, October 27, 2014 12:25 PM
Rex, you forgot the F-104 in your list.  Here is also an interesting tidbit of refueling history:
1967 MackayTrophy
http://www.mccookgazette.com/story/1158157.html
http://www.pacaf.af.mil/shared/media/document/AFD-090602-136.pdf
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    September 2005
Posted by richs26 on Monday, October 27, 2014 12:35 PM
The KC-135 has a smaller fuselage than the 707, but you could use that 707 for the engines and tail fin on an Italerei KC-135R to backdate to an A or E model, depending on the engines.
    March 2005
Posted by TarnShip on Monday, October 27, 2014 1:17 PM
I didn't forget any aircraft,,,,,,,,there are almost 20 or 30 more, both Naval and USAF that needed to be refueled, I didn't intend to type out a complete list. (I would have had to describe the two unique ways the Banshee and Skyray received fuel, and then included the F-5A, etc)
And that first article is wrong when it talks about that Tri-level being the "first in history". (if they had said "first in USAF history" or "first time in Vietnam conflict" they might be correct)
There are quite a few photos in print of USN tri-level refuellings,,,one is Skyhawk to Skyhawk to Demon, one starts with a Skyraider, another starts with a Savage,,,,,,,,there are even a few "four-level" pics out there. They all pre-date the start of Vietnam,,,,,,and in some cases, the aircraft are still designated by the pre-DoD combined system.
Side note, I left the Savage out of the list of tankers, because of the expense or difficulty of the available kits,,,,,,,,one kit is expensive resin, another is difficult to fit plastic, another is a really great Vacuform,,,,,,,and another is a reallllly bad Vacuform. The Savage was turned into a tanker after the jet engine was removed from the tail, turning it into a two engine prop plane.
almost gone
    August 2005
Posted by Phil_H on Monday, October 27, 2014 6:24 PM
richs26
Or he could do an RAAF 707 tanker. These were ex-Qantas 707's which were used in the tanker/executive transport role. If I recall correctly, they only had the wing mounted basket pods and no boom.
http://www.clubhyper.com/reference/707raafsmudge_1.htm
Another possible, if you can find one, is the Matchbox/Revell Victor K2
    May 2013
Posted by Blairy on Tuesday, October 28, 2014 3:45 AM
Phil_H
Precisely what I was thinking, it is just hard to find that kit. And it is not cheap.
    August 2013
Posted by Straycat1911 on Tuesday, October 28, 2014 10:25 AM
Blairy, I recall seeing somewhere someone did an AMT KC-135A refueling a AMT B-52. They mounted them both on brass rods on a single long rectangular base, IIRC. It was an AWESOME diorama. I "think" it was featured in FSM but it's been a few years. Maybe someone else has more memory cells than me. :-) If you're in need of a 1/72 KC-135 or KA-6 kit, let me know. I've got a few extras in my stash I'll never get to.
Personally as a 410th BW alumnus, I've been kicking around the same idea but using an F-106 as the receiver. Like to see Hobbyboss or Trumpeter come out with a new mold Six in 1/72; REALLY don't want to mess with that old Hasegawa again!
Posted by Melgyver on Tuesday, October 28, 2014 5:55 PM
I believe it was at the 1992 IPMS Atlanta Nationals.  It was amazing!
Clear Left!
Mel
    March 2010
Posted by mach71 on Tuesday, October 28, 2014 7:20 PM
Go big! model a KC-10 fueling a C-5.
I think both are available in 1/144 scale.
    August 2013
Posted by Straycat1911 on Wednesday, October 29, 2014 10:14 AM
Don, in 1:144 scale, would the tip of a Bic pen work? Cut it via the LAR method, trim the inside to scale thickness?
    August 2013
Posted by Straycat1911 on Wednesday, October 29, 2014 10:15 AM
I used to have that C-5 model; sold it off to a guy needed it more than me. It was an excellent kit, but very hard to find anymore.
Posted by Jim Barton on Wednesday, October 29, 2014 4:22 PM
You'll probably need a decent amount of space to display the finished models, even in 1/72-scale, but it sounds like a different idea!
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
    June 2013
Posted by RobGroot4 on Thursday, October 30, 2014 12:40 AM
If you are interested in fighter-fighter, Wolfpack makes a 1/48 refueling pod for an F/A-18E/F as an AM resin piece.  It looks like they are planning to do one in 1/72 (towards the bottom).
[The links look like they may not take you straight to the items, if not, go to resin at the top, and then select 1/48 or 1/72 and just hit ctrl+F and search for "refuel," they also offer probe kits that will be useful to you.]
It is worth noting that the pod itself is shaped differently (the little propeller thing at the front which would be easy to scratch) and the flared end at the back for the drogue (not so easy to scratch).  Wolfpack's drogue is in the closed/stowed position, but I imagine one could be pretty easily scratch-built with a little wire.
I've got one of these for an F/A-18E in my stash and it looks nicer than the pictures on the website.  Good luck!
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    May 2013
Posted by Blairy on Thursday, October 30, 2014 1:52 AM
Thanks for all the ideas. I think I have made a decision on what exactly i want to do, and it is a combination of a few of all your ideas. When i get to a proper computer I will whip up a quick blueprint and post it up. I am thinking of a 1/144 KC-135A and C-17
    September 2005
Posted by richs26 on Thursday, October 30, 2014 10:08 PM
That should be a KC-135R to be compatible with a C-17 as A models were long gone by the time the C-17 arrived.
    May 2013
Posted by Blairy on Friday, October 31, 2014 1:05 AM
I stand corrected. More research i shall do.....
    December 2006
Posted by Fly-n-hi on Friday, October 31, 2014 1:14 AM
Blairy
Minicraft is coming out with a 1/144 KC-135R pretty soon.  t sounds like its gonna be a nice kit!  That might be exactly what you need.
    September 2012
Posted by GMorrison on Friday, October 31, 2014 4:21 PM
Go For broke!
Matchbox Victor K2 refueling an Airfix Vulcan during Operation Black Buck.
Academy makes a really cool KC-97G and the -97L with jet engines.
    March 2010
Posted by mach71 on Sunday, November 9, 2014 7:49 PM
I found this while searching the web.
www.boxartden.com/.../Revell-SAC-Refueling-Team
I hope that was a real kit! I'm guessing it was a small scale. Maybe 1/200?
    September 2005
Posted by richs26 on Monday, November 10, 2014 12:46 AM
That is more likely Revell's old boxscale models, meaning that the model was designed to fit a standard-sized box with scale being not a standard scale like 1/200th. It could be something oddball like1/153rd or some such scale.
    August 2005
Posted by Phil_H on Monday, November 10, 2014 5:16 AM
richs26
Definitely oddball - if the source kits are the ones I believe they are, the KC-135 is 1/139 scale and the B-58 is 1/94
    March 2010
Posted by mach71 on Monday, November 10, 2014 6:35 AM
After a further search it appears they are 1/240 scale.
I've found the KC-135 with a B-58 and a KC-135 with a B-47.
    June 2004
Posted by seasick on Monday, November 10, 2014 10:28 PM
For the Super Hornet my source says the Buddy store setup as follows: A total of four 480 gallon tanks on stations on the two inboard hard points under each wing. On the centerline station its the same 330 gallon unit used for the buddy store on the Classic Hornet, and S-3. The E and F can both do it but the E carries more fuel.  One thing, if you want your Super Hornet to carry a heavy load of ordinance but are bumping in to your maximum launch weight, Cat with low fuel, and top your tank once in the air, and you are on your way. Smile
Chasing the ultimate build.
    September 2012
Posted by GMorrison on Monday, November 10, 2014 10:37 PM
I don't think that refueling kit is real. Asked around a bit never seen by my friends.
Hustler was 1/94
    March 2005
Posted by TarnShip on Tuesday, November 11, 2014 1:15 AM
here is an OOB kit that does what you want, it is a Legacy Hornet with the newest refueling store
www.zone-five.net/showthread.php
you get one to do the decals and the pod, and any other 1/48 to do the receiving aircraft.
It is a bit large,,,,,,,,but two 1/48 Hornets might take up less space than two of the larger jets.
Rex
almost gone
    August 2005
Posted by Phil_H on Tuesday, November 11, 2014 2:55 AM
If you want to go small-scale (1/144), there's also this set, if you can get your hands on one.
http://www.dragon-models.com/d-m-item.asp?pid=DRA4595
