Fw190D-9 air intake question.
    April 2005
Posted by wing_nut on Sunday, November 9, 2014 12:43 PM
Did the D-9 ever have a dust filter fitted over the air intake the 109 F & G series had when they where in the desert?  Not having been in the desert and being so late in the war, were there forward areas that were dusty enough to warrant one?
Marc
Posted by Bish on Sunday, November 9, 2014 1:04 PM
To the best of my knowledge there were no tropical variants of the D-9. Trop versions of any aircraft seem not to have been built from early/mid 43 onwards, I think the G-6 was the last 109 with the filter.
    April 2005
Posted by wing_nut on Sunday, November 9, 2014 3:16 PM
Thanks Bish.  That's what I figured too but wanted to be sure. Now I don't need to fashion an exact configuration.   doing, or will be soon, a what if of a D-9in N. Africa based on a divergent time line.  Monty wasn't just wounded in WWI, he was killed asond Rommel's campaign was more successful, at least for a time.  And when Marseille bailed out of his new 109G-6, he was not struck by the tail plane and was not killed so it will his mount.
Marc
Posted by Bish on Sunday, November 9, 2014 3:24 PM
I wasn't sure what you were intending, but I did think about mentioning a what if build. Sounds like a good idea, will be looking forward to seeing it. Are you thinking of using a 109 trop filter. I know the intakes are the same shape but no idea if they are the same size.
    April 2005
Posted by wing_nut on Sunday, November 9, 2014 3:38 PM
Yeah I figured the the shape can be the same assuming some sort of standardized parts.
Marc
Posted by Bish on Sunday, November 9, 2014 3:40 PM
Very likely. Do you have the necessary kits to do a comparison. If not, I have a 32nd 190D and 109F Trop I can check tomorrow.
    April 2005
Posted by wing_nut on Sunday, November 9, 2014 3:52 PM
Thanks but I'm good.  I have a Zvesda 109F-4 that I think has a filter I can scrounge... If it fits the intake.
Marc
    December 2004
Posted by panzerpilot on Sunday, November 9, 2014 4:17 PM
Pretty cool idea. Yellow 14, in desert camo? I just got done reading "star of africa". By the time the dora came out, he could easily have had 400+ kills, at the rate he was going. One of the countless "what -ifs" from the war. There are also aftermarket filters out there, if your kit doesn't have one.
-Tom
Posted by Bish on Sunday, November 9, 2014 4:25 PM
No worries. And that's a good point, how many kills will you be giving him.
    April 2005
Posted by wing_nut on Sunday, November 9, 2014 5:38 PM
Thanks Tom.  I too was wonder what his kills would be had he survived longer. 400 works for meBig Smile
Marc
