1/32 Horten 229 Build. ZM's new kit
    November 2004
Posted by snapdragonxxx on Wednesday, December 3, 2014 5:28 PM
Here I go with Zoukei Mura's Latest release. This is a much anticipated kit for large scale modellers and doesn't disappoint at all (not me anyway) and is a challenge. To start with I would like to show you just what is in the box!           This next photo shows a part that hasn't moulded correctly in the centre. ZM on their website tells you about this and another problem in the kit (see later) and gives details on how to either fix this problem with a drill, or to contact them and they will send a new part out with the problem solved. I contacted them via email and they sent it out registered EMS and sent me the consignment number and it only took a few days. If you look inside the red circle you can see that the centre hasn't a hole in it so it won't fit correctly. They made a new mould just for this one part.    Again on the website there is an apology for this next sprue which has parts incorrectly numbered. They have a diagram on the website with the parts correctly numbered. In actual fact, these parts are (mostly) for the underside of the fuel tanks. Kudos must go to ZM for sorting this out and admitting to the mistakes and fixing them. Not every manufacturer does this!      A close up photo of the wing connection detail.   A close up of the wheel detail   A close up of the Mk 108 Cannon (or part of it!)      One of the instrument panels in the kit. There are two with a choice of which one to use.   The photo below is of the engine sprue. There are two in the kit and the entire sprue is just for one engine.  Detail shots of the compressor fans etc for the interior.Each fan is just slightly different and the instructions (see photo below)tells you in minute detail just how to assemble this part. They are the best instructions you'll get for building!    The decals look great.  They have a complete instrument panel  or individual dials... your choice  Here's the start of the assembly - not for the faint of heart!!!!  ZM have thought long and hard about this kit and how to go about it and listened to what their customers would like and then did it. Full frame and clear skin. There are many ways of display for this kit. ZM have done this Horten proud and the engineering in this kit is just out of this world. If you don't get one you are missing out on a kit that just has to be the best one this year! Next post... the build starts!
    November 2014
Posted by CaptainBob on Thursday, December 4, 2014 6:25 PM
Great pics. Good luck with this project. I hope you will post progress notes and more photos.
Captain Bob
    March 2005
Posted by philo426 on Thursday, December 4, 2014 7:02 PM
Yes the tricky part will be to paint and install the parts without fogging the clear plastic .
    November 2004
Posted by snapdragonxxx on Saturday, December 6, 2014 10:29 AM
The first thing I did was jump in at the deep end and fix a problem that ZM posted about on the boss' blog on their website and that is the problem with the R sprue and the numbering. After downloading the PDF correction document I decided that it would be a good place to start and get this problem out of the way so it wasn't nagging on in the back of my mind. I had an idea for how I wanted the fuel tanks to look and tried Mr Hobby Metal color on them with a primer coat of matt black. The polishing phase didn't produce the glow I quite wanted, as I wanted a polished Aluminium look which didn't quite happen, but a nice part polished glow resulted which in actual fact I was happy with. Getting the right parts together made a huge difference and without ZM's correction sheet I could have been scratching my head for some time. Still, I went my own way with some of the paint directions and decided to keep the wing frame and control surfaces RLM 02. Once out of the paint shop with all the tanks fitted and parts in place they look good.   After a nice start I went back to the start and got to grips with the two engine sprues. I decided that I would use stainless steel from Alclad for the rear portion of the engines and after sitting a while with the instuctions on my computer screen (I do like their manual download option. It helps keep the build area a bit less cluttered) I started in the paint shop with some of the parts from the front and rear engine(s)  An extra bit of assembly brings this.  The rear assembly parts was done with Mr Hobby Color Steel Red. It didn't seem to have the reddish tint the bottle top has, but on top of Vallejo grey primer with a gloss varnish over it the paint came out ok and had a nice sheen to it, but not too much. The other parts were done with Vallejo Aluminium on a matt black primer. I moved on to the compression chamber and after building it all up in the separate parts for the rotating compressor fans to the static stator rings those two were sprayed Aluminium while the exterior was painted RLM 02.    I then fitted the two sections together  I turned my attention to the rear section. Time to get to grips with Alclad. I primed inside and out with Alclads own gloss black base, but couldn't seem to get a proper smooth black gloss shine. Still, the stainless steel from Alcad adds a different tone to the engine so I must look at working out a proper gloss base that lets aclad sit properly and gleam. This is a product that although I have had for some time I have shied away from because I knew it to be a "hot" product and tends to melt plastic. In the end I found it to be a quite easy product to work with and with different primers etc the nuances of different shades and finishes. of the same colour from the bottle are endless. I wonder what stainless steel would look like on a black primer with a silk finish! Hmmmm. This photo shows my first "brush" with Alclad!  I gave everything a few days to cure etc before getting to grips with all the piping, doing everything twice. Vallejo Brass and copper were used for the piping rather than ZM's paint guide as I wanted some colour change and for the pipes to stand out a bit. Everything else on the detail front was brush painted with either gun grey or steel. The finished engines to me look nice.    Both engines on the stands that form part of the sprue. The only thing not on are the rear heat shields. That's next and I have a decision to make as they are clear parts. - leave them clear or paint them matt black. Hmmmmm! :?
    February 2014
Posted by CN Spots on Saturday, December 6, 2014 11:29 AM
That's insane!  Are there enough parts to build the internal structure by itself and then build the outside to display separately?  Wheels up on a stand above the internals for example?
    June 2013
Posted by RobGroot4 on Saturday, December 6, 2014 2:47 PM
Those are some really sweet engines and your detail work on them really makes them look like an actual engine.  I can't wait to see the rest!
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    November 2004
Posted by snapdragonxxx on Saturday, December 6, 2014 5:59 PM
The only thing missing in the engine interior is the combustion chamber internals. This kit is designed to give the builder a complete overview of the frame, skin, internals etc and there are several ways this kit can be displayed.
It is designed to have it's wheels down and to sit on them like most models and you would have to do some scratch building and alteration to have the wheels retracted.
I have an idea that I might put this on a mirror when finished, but at this moment I am just now concentrating on the fuselage airframe. This will be on my next post in a couple of days.
If now you are beginning to see just what ZM offers builders then now is the time (Christmas) to ask SWMBO for one!
James
    November 2004
Posted by snapdragonxxx on Monday, December 8, 2014 5:44 AM
I want to start with a recap. I wasn't happy with the last engine photos I took. It was late at night and under artificial light and even my flash didn't produce an outcome I liked. So in the light of day I retook the photos of a completed engine in the hopes that the colours would come out at the correct natural colours I painted on.... and it worked :clap: Here are three photos of one of the engine. The front intake is painted Vallejo aluminium. The compression chamber, RLM 02. The combustion chamber Vallejo primer matt black and the exhaust is Alclad II steel over a semi-gloss black base. Detail work is Vallejo silver, gunmetal grey, Copper and Brass.    All the time I have my eye on what I want the finished model to look like and have several ideas. I decided to mask and paint the ribs that are moulded on to the lower wing skin.  An entire afternoon and 2 movies was devoted to this. I then went into the paint shop and got to grips with Vallejo's RLM 02 and the parts that I had built plus the masked wing.  on removing the masking tape I realised that I hadn't masked enough space and there had been some overspray. The lesson has been learned - mask off more than you think is needed! This wing skin will go back in to the paint shop and the entire of the interior will be painted RLM02 and the undersurface RLM76. I still have a wing to play with!!! :laughing-rolling: The bottom of the fuselage frame was removed and cleaned up, There are some tiny bits of flash on it as well as supporting nubs etc. The flash is only to be found where the mould seams are and a quick scrape fixes this. Once done it went into the paint shop along with the masked wing.  After a building session....   back into the paint shop and a couple of touch ups. Some of the detailing will have to be done by brush. I don't trust my airbrush skills to that finer depth! once back out and cured some more assembly and brushed detailing work and....    Now it's 1:30 am Eyes have ceased to function and it's time for medication (heart) and bed. Above photos taken in proper daylight!!! Next time I add more detail work and linkages Comment and questions welcome. James.
    June 2014
Posted by BrandonK on Monday, December 8, 2014 10:58 AM
That has to be one of the most complicated kits I've ever seen. It looks to be coming along nicely. Can't wait to see the rest of the build. Nice job.
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    September 2013
Posted by AdeB on Monday, December 8, 2014 11:18 AM
Bloody hell!  That's some work mate. Kudos
    March 2005
Posted by Devil Dawg on Monday, December 8, 2014 3:11 PM
Wow!! All you need is to add some glow plugs to the engines and crank 'em up!! Very impressive.
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    July 2014
Posted by modelcrazy on Monday, December 8, 2014 3:23 PM
Whaaaat? Compressor blades and everything? Does it come with the combustion chamber burners as well? Fire 'em up brother. Just don't melt anything.
Steve
    April 2014
Posted by B_one fixer on Monday, December 8, 2014 3:51 PM
One of the guys at my club brought that kit in to show us. It is very impressive !
Posted by waikong on Wednesday, December 10, 2014 7:56 PM
I love this plan and built the old Dragon 1/48 kit.  Great progress so far and great build pictures.  Can't wait to see more.
    November 2004
Posted by snapdragonxxx on Thursday, December 11, 2014 5:19 AM
    June 2013
Posted by RobGroot4 on Friday, December 12, 2014 6:37 PM
This is really sweet, could we trouble you for a close-up of the painted cannon, the bits I could see looked really nice?
Groot
    November 2004
Posted by snapdragonxxx on Monday, December 15, 2014 4:37 PM
Time for another update. I have had this weekend away from my bench to go and overnight in Leeds at the Metropolitan Hotel and go to see Andre Rieu and the Johann Strauss Orchestra. I had a fantastic time. I could have gone home afterwards, but I don't like being out on the motorbike in December in Leeds at the time when all the drunks are staggering about. I also don't like being out at night on the bike, so I booked the hotel for a night. For Groot I have this. It is the best I can do without stripping the model down. I have not modified the kit weapons at all, but just built them up and painted them metallic black.  But now... the cockpit. We have to remember that this aircraft was not operational and a bare bones experimental test aircraft and the kit does this justice as those building it will agree. There is not much to do in the cockpit, but what there is does take a little time to bring out good results.            The instrument panel was the clear one included with the kit. I used Vallejo liquid mask to mask off the clear dial glass and the complete decal Instrument panel on the back followed with painting over it black. I think I will try the etched version when I get another. I do need to repair paintwork and just finish off a tiny bit of detail work in there, but the only thing to my mind that could be added is some extra wiring to the IP. Next up... it is wheel time!!
    June 2013
Posted by RobGroot4 on Monday, December 15, 2014 4:44 PM
Thanks for the photos of the guns, they really look excellent.  This whole build is really impressive!
Groot
    November 2014
Posted by CaptainBob on Tuesday, December 16, 2014 6:52 PM
This is an incredible job! Waaaay above my humble talents. I'm glad I didn't buy this kit. I think I'd rather cut and bend PE parts that are almost invisible.
Bob
Posted by chukw on Tuesday, December 16, 2014 9:02 PM
Great job on what may be the ultimate model kit!  ;)
    November 2004
Posted by snapdragonxxx on Wednesday, December 17, 2014 11:23 AM
Don't be fooled by the amount of parts and the complexity of this kit. If I can build it and do a good job then anyone can.
ZM's engineering of this kit makes it go together easily. You just have to understand what you are doing and what the instructions are telling you which is why if you want to build this... and you should for the experience... spend lots of time with the instructions first before starting.
It looks hard, but really once you understand how it goes together it's easy!
coming later... the wheels!
    June 2013
Posted by RobGroot4 on Sunday, December 21, 2014 4:48 AM
Wow is that nose wheel huge.  I don't think I've ever seen anything quite like it.  This is really shaping up to be an incredible build!
Groot
    March 2005
Posted by philo426 on Sunday, December 21, 2014 6:28 AM
Yeah he is really trucking along on that thing and apparently has encountered no serious problems thus. far!
    February 2011
Posted by knox on Sunday, December 21, 2014 9:33 AM
 This thread is a real blast to follow.  Your model looks ready for desert speed trials.  Thanks for posting your build.                       knox
Posted by Texgunner on Sunday, December 21, 2014 9:46 AM
RobGroot4
Groot
I believe the nose wheel on the prototype was a "donation" from a Dornier 17 or 217.   I'm too lazy this morning to look it up though.    Can someone confirm that?Big Smile
Gary
"All you mugs need to get busy building, and post pics!"
    November 2004
Posted by snapdragonxxx on Tuesday, December 23, 2014 3:29 PM
I am sorry to say that the nose wheel wasn't a donation. It was a design alteration as during scale model trials they came to a conclusion that there was a problem with weight/thrust angle on take-off and landing and raising the nose at an angle by a large nose wheel and altering the angle of jet thrust solved this. IMHO if they had moved the engines back to the trailing edge and fitted them under the wing instead of the top then that wouldn't have happened. but it has produced a very distinctive shape that did fly and fly well. The problem with this aircraft was the reliability of the engines. Here we go with another update. It has been both an infuriating and successful day in the workshop as upper and lower panels have been stuck on to the fuselage frame. Replacement 0.2 and 0.5 needle and nozzle sets arrived. the 0.2 nozzle is split and useless and during cleaning the 0.5 pinged off into the distance as did one of the speed brakes during painting. This understandably has caused a temper outburst and a string of unmentionable words and gestures. Tomorrow I will phone the company and complain about the 0.2 useless nozzle! On the success side, the fuselage panels are painted and on. masking tape and RLM 82 were used on the upper panels and RLM 76 on the lower. It has taken a couple of days to get things right and now it looks good.             There we are. Now it is beginning to look like the Horten. I have masked off panels around the left engine and left the cowling clear, but painted the intake area. There are so many ways of presenting this model that the brain gets close to exploding! Once all the exterior wing panels and control surfaces are on and painted with the base RLM 82 upper surface I will mask off a splinter pattern RLM 81 rather than a wavy one, just to be a little different!
cnq
    March 2013
Posted by cnq on Tuesday, December 23, 2014 4:16 PM
looking very nice already. Are you going to cover all that incredible interior detail ?
    November 2004
Posted by snapdragonxxx on Tuesday, December 23, 2014 6:14 PM
wait and see ;-)
