Dullcote on canopies
    August 2005
Posted by Surface_Line on Thursday, December 25, 2014 10:55 AM
Does anyone have a good method to remove Testors Dullcote Lacquer from canopies?
Or at least to neutralize its effect?
Thanks,
Rick
    March 2005
Posted by TarnShip on Thursday, December 25, 2014 12:03 PM
if you can't get it off of there, and you probably can't, you can minimize the damage by polishing with toothpaste, cleaning it thoroughly, and dipping it in Future (Pledge)
If you dip it and it isn't clear enough, just strip the Future off with Windex, polish some more, and dip it again
If this is a warplane, remember that those canopies sometimes had swirls in them right after being polished by a ground crewman, and could/did take on a milky looking effect in certain light reflections
so, you can get it pretty good, and stop there and call it weathered (a lot of people pile on the weathering and give us a crystal clear canopy to look at,,,,,which wouldn't be realistic)
Just some thoughts that I hope are of help
Rex
almost gone
    March 2013
Posted by patrick206 on Thursday, December 25, 2014 2:47 PM
Several years back a kit had some sort of coating on the canopy from the manufacturer, it was sprayed on and looked awful, lots of orange peel on one side. I imagine it was supposed to make the canopy look really clear. No cleaner was effective at removal, so I just started sanding through to the plastic.
I started with wet, well used 600 grit, when all of the material was gone I started sanding with finer grades, ending up with 12,000. Final polish with Novus left it looking really good, then a dip in future. Just enough of the framing was left to allow masking. If you're concerned about losing the framing details, you could lightly score beside them for masking locations. If the framing is not raised, you're home free.
Patrick
    April 2013
Posted by Greatmaker on Thursday, December 25, 2014 3:35 PM
I don't know if this would help on a canopy but at times I've gotten an orange peel on my final finish and I have used isoproply alcohol to take the dullcoat off
    February 2011
Posted by Raualduke on Thursday, December 25, 2014 4:19 PM
You can always  eject. Ha! Mike
Posted by Don Stauffer on Saturday, December 27, 2014 9:00 AM
If it is an older plane, like ww2, the canopy plastic was not well stabilized against UV, and went dull pretty quick.  If it is a heavily weathered bird, just coat the rest of the canopy :-)
    August 2013
Posted by Straycat1911 on Saturday, December 27, 2014 1:50 PM
Or make it a bird parked at AMARC.   :-)
    December 2004
Posted by panzerpilot on Saturday, December 27, 2014 4:51 PM
Try some micromesh sandpaper. I've had luck with blemishes on canopies using 6000, 8000 and 12000 micromesh.
-Tom
Posted by gregbale on Saturday, December 27, 2014 7:24 PM
I've used denatured alcohol in the past for just that issue, and it worked well
Greg
George Lewis:
    January 2014
Posted by Silver on Wednesday, December 31, 2014 9:59 PM
Try finger nail polish remover w/ cotton swabs..
    March 2009
Posted by wolfhammer1 on Sunday, January 4, 2015 8:37 PM
Try soaking in Pine-Sol for a while and then scrubbing with a swab or rag.
Posted by Don Stauffer on Monday, January 5, 2015 8:31 AM
We used to have to sand and polish with ridiculous high number grits to polish a canopy.  Now, just a coarse sand with about 600 or 1000 to remove the dullcoat, and then a coat of Future.  Future is a real boon to working with transparencies.
    September 2006
Posted by Banshee1000 on Monday, January 5, 2015 12:23 PM
Goo Gone should take it off with no problem.  I'm guessing it's already on the plane, so just apply it carefully with a small cotton swab (like the kind Tamiya makes).
