F-4D Phantom questions
    March 2010
Posted by Nathan T on Saturday, January 17, 2015 7:09 PM
Getting ready to build a ND ANG F-4D and have a few questions. It will be a later phantom in Hill Gray similar to this:
First off, no chin pod? Whats the story behind that? There are other ND phantoms that do have them:
Also, you can see the noticable variations in The HIll gray scheme. Is this lighter bird just painted in a lighter version of gunship gray, or is the top color a different FS number all together?
Last question: the black circled stencil in this photo:
Anyone know what it represents? Is it similar to the Armament stencil above the wing leading edge? There are no specific decal sheets for these birds, but I can't find any aftermarket F-4 sheet with anything close to that stencil, and no other phantom photo of any kind shows this on the nose. All ND ANG phantoms in HIll Gray have it too.
    March 2005
Posted by TarnShip on Saturday, January 17, 2015 8:00 PM
I can only answer the radome part for you.
At the time of the introduction of the F-4D, there was a radome without any IR sensor on it.
These went onto the Iranian F-4Ds, the early F-4Ds in USAF service, and some of the late build F-4Cs.
They also went into the F-4K and F-4M production, and were used on the Blue Angels F-4Js that had no radars in the nose, just ballast weight.  Later on, when other "expansions" were made in the RHAW suites, a fairing was added back into this area, just as a place to fit it.
For model building, you will get better results from using an F-4J radome and slicing off the lower antenna, than you will by "stripping an F-4C, D, B or N" radome,,,,,,,because most of those radomes included some sort of flat spot to mount the IR onto if it is a separate part. If they have this "dip" on your kit, just fill it with putty, etc, and sand it to a uniform shape.
F-4J,K,M radomes in model kits wouldn't have that flat spot on them.
I think the box is the Gross weight box, but, I am not positive on that.
Rex
almost gone
    November 2003
Posted by tempestjohnny on Saturday, January 17, 2015 9:02 PM
I believe that the gunship gray faded rather quickly.  If you look at mothballed hill gray aircraft you can see the fading.  Possibly the lower pic is an older airframe
    March 2010
Posted by Nathan T on Saturday, January 17, 2015 9:20 PM
Thanks Tarn and Commander John. Tarn- Thanks for the background info on the different models and radomes. good info on kits and I am actually using Hasegawa's J model in 1/48 and making it a D, as I don't feel like rescribing the whole old Hase kit. I did do just as you said, and used the J radome. I did cut off the entire D radome to save for future F-4C/D builds that had the IR sensor. The Hase J kit is a great starting point to make a recessed lined C/D model, without shelling out 70 bucks for the new Academy kit.
Hey John, Does it look like the faded D has the light gray undersides, and the top pic has gunship gray undersides? There was some variation like this in the Hill Grays, correct?
    November 2003
Posted by tempestjohnny on Sunday, January 18, 2015 3:30 AM
Yes there was two versions. Hill grey and Egypt one. Can never remember which one is which. One is two tone where gunship grey wraps around to the bottom. The other is light gray on bottom
    November 2003
Posted by tempestjohnny on Sunday, January 18, 2015 3:32 AM
I still can't believe you're building a jet
    March 2010
Posted by Nathan T on Sunday, January 18, 2015 8:09 AM
Ha! You got me! Actually I've built a couple now. An F-4S Navy bird earlier this fall and Eduard's Mig 21 earlier last year. Finishing up an F-100C right now! Lots of Jet A being burnt at the bench now.... thanks for your help.
    July 2004
Posted by stikpusher on Sunday, January 18, 2015 12:11 PM
Part of the gray difference is the lighting in the photo. If you notice in one photo, the sky is overcast, while in the other it appears to be cloudless. The direct sunlight will make a difference versus diffused sunlight, in addition to any fading.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
