Avia S.199 - 1/48 Hobbycraft kit - complete
Posted by VanceCrozier on Friday, January 23, 2015 7:35 AM
Still a few things I wasn't happy with, so it's no show-stopper but I'm happy with it.  Smile  1/48 Hobbycraft kit (and yes, those are the kit decals, helped along with a good coating of Microscale Liquid Decal Film!) with Aries resin for the cockpit. That was a great little piece of AM, fit like a glove. Detail & internal painting was mostly Humbrol enamels, exterior colour is a secret formula, available in the Krylon Camo paint line. (but you didn't hear that from me)
Finished pics, I'll throw the WIPs in here as well. Thanks for looking!
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
Posted by VanceCrozier on Friday, January 23, 2015 7:36 AM
Posted by VanceCrozier on Friday, January 23, 2015 7:38 AM
Kit decals look fine:
Posted Image
The sprues:
Posted Image
Posted Image
Posted Image
Glass is actually better than I remember, but not perfect. With all that resin going into the cockpit I'll be leaving the canopy open anyway...
Posted Image
Cannon gondolas - have soft detail & one barrel has already snapped.  Most pics I've seen show these installed but I'll look around some more. I may see if I can scavenge replacements from that Academy kit I have.
Posted Image
Posted by VanceCrozier on Friday, January 23, 2015 7:39 AM
So, the cockpit situation:
Posted Image
Posted Image
Decent raised detail.
Posted Image
Hey, I've seen worse.
Posted Image
BUT, the Aires set:
Posted Image
PLUS all sorts of PE bits, AND acetate instrument dials.
Posted by VanceCrozier on Friday, January 23, 2015 7:40 AM
WHY did I do a wash on sidewall details that I will need to scrape out to make room for the Aires detail set?
Posted Image
Cuz I was bored but too tired to do anything else, that's why. (I'm also thinking this will actually give me a better shot of getting my detail removal down to a consistent level.)
Posted by VanceCrozier on Friday, January 23, 2015 7:42 AM
Wing unit assembled after a dry-fit reveals that it's a near-perfect fit. Various attachment point holes have been drilled out, BUT I realized after the fact that I didn't cut out what appears to be a landing light in the wing? I was NOT looking for that on this Czech-built bird.
Posted Image
Dipped the clear parts in a bath of Future cut with isopropyl alcohol… VERY nice result, smoother than usual & super-clear. (I've been using the same bottle of Future for at least a decade. I only open the big bottle long enough to re-stock my small bottle, so it hasn't gone off, but I suppose, inevitably, it has gotten a little thicker?)
Posted Image
So, the cannon gondolas… barrels were separated from the pod while on the sprue, the only parts damage I came across.
Posted Image
I may be able to steal a fresh pair from an Academy kit I have in the stash, orrrrr, cut/slice/drill out...
Posted Image
and prep some brass tubing. Slightly thicker than the styrene, but it'll have the tube cross-section.
Posted Image
Posted Image
Cockpit assembly, mostly assembled.
Posted Image
Assembled & washed, a few touchups to do & need to add a little paintwork to the fuel line.
Posted Image
    July 2014
Posted by modelcrazy on Friday, January 23, 2015 7:43 AM
Vance,
I couldn't get my  tail strips to adhere and conform like you did.  Good job, I just finished one OTB for the 109 build.  Yours looks better.
Steve
Posted by VanceCrozier on Friday, January 23, 2015 7:44 AM
Internal fiddlybits gathered up. Gave the cockpit a little more weathering/dust before tucking it into the fuselage, but:
Posted Image
~BAMM!!!~
Posted Image
Took me an inordinate amount of time to get alignments confirmed & commit to the superglue, but, happy with the final result.
Posted Image
Glad I put the work into it - in 1/48 that cockpit set is visible.
Posted Image
Guns not quite done, was more concerned with alignments at the time. Now in place & set up, need to add a little more CA or putty, smooth out that shape around the barrel before priming.
Posted Image
Dry-fit...
Posted Image
Posted Image
Posted by VanceCrozier on Friday, January 23, 2015 7:45 AM
Inspection time - paint shade is approved by Agent 003.
Posted Image
The tail area got another light coat last night, a couple of touchups at the leading edge wingroots too. Landing gear tires were hit with another darker coat of "rubber", much better now. Cannon gondolas were also painted, think they need a little touchup at the cannon barrel though.
Posted by VanceCrozier on Friday, January 23, 2015 7:46 AM
So, dropped by ANOTHER dollar store last night looking for the elusive cheap plastic toothbrush. No luck. Started wandering around looking for tooth-pick-ish options and found....
Posted Image
Tips have a point of course, there are some other shapes that can be hacked off of these as well. Could be useful after all.
Posted Image
Certainly hope it works, because I've gone & sliced up the wingtips.
Posted Image
LOVE that Humbrol flat red enamel.
Posted Image
Wheels need a few washes & weathering etc., but pretty close now.
Posted Image
Posted by VanceCrozier on Friday, January 23, 2015 7:47 AM
Decal issues! Test decal broke up last night, so out came the Microscale liquid decal film. Gave it a coat & let it sit overnight. First two this morning went alright, third (topside wing) cracked in two. Super Angry Anchored the larger piece while keeping the smaller piece wet, then slid that smaller piece into place & quickly set it.
Second round of decal film has been applied.
Posted Image
Posted Image
Posted by VanceCrozier on Friday, January 23, 2015 7:48 AM
So the prop needed a bit of work. Hobbycraft provides a spindle with several ridges in it. You are supposed to trap one end of it between the fuselage halves, then assemble the prop hub around the other end, so it'll spin? The holes were too big on both ends of that equation. So I used those holes as a starting point & opened them up to match a length of styrene tube.
Posted Image
Annnnnd a little progress was made last night with the last of the fiddlybits, as I watched the big hockey game. Looks like I managed to open up the hole on the fuselage a little too much though. A quick wrap of masking tape on the rod will snug it up some.
Posted Image
A few more panel line wash sessions over the past few days, did some dot-filtering this morning too. (craft acrylics cut with dish soap, not oils) Subtle, but you CAN see a little difference in person. May show better in properly-lit final pics, but figured I'd snap these now as I was headed out for coffee +wifi anyway...
Posted Image
Posted Image
Posted by VanceCrozier on Friday, January 23, 2015 7:49 AM
So the drinky-swords are a little awkward to deal with, shape-wise. I think next time I might try to get that 90º corner by sanding instead of slicing? Anyway, coloured lights are in place, need to sand & shape them tonight.
Posted Image
Posted Image
Funny, how HUGE that notch looks when you take a chunk out of the wing with an Exacto knife, but the lights seem so tiny when trying to place them!
Side note - just for kicks I tried the ol' sprue-stretching method on these hunks of plastic - it works, super-easy. I'm thinking, nav lights for 1/72 could use a piece of the stretched version as the "bulb", then have a drop of CA or Future added on top?
Posted by VanceCrozier on Friday, January 23, 2015 7:50 AM
Armour plate section one… 5PE parts
Posted Image
How small ARE these parts? The little brackets with the "fingers" on them:
[img]http://i1012.photobucket.com/albums/af250/VanceCrozier/Avia%20S199/IMG_8974sm_zpscbxhrers.jpg[img]
Posted Image
I managed to bungle up the fold on those lower connection points so they've been omitted in favour of more CA along the bottom of the plate!
Posted Image
Posted by VanceCrozier on Friday, January 23, 2015 7:55 AM
modelcrazy
Vance,
Modelcrazy!! Thanks man. Did you use the box decals as well? I needed a couple layers of Liquid Decal Film just to make sure they didn't break up to start with. Then I did one side of the rudder on one night, using MicroSol on it, and spent a fair amount of time pushing the over-hanging edges into place. Once that was done & set & dry, I actually used some sandpaper to get rid of the overhanging piece of the decal, then sealed it up with white glue. Two days later, I repeated the process. And after THAT was done, I did some touchups with red and white paint!
Whistling
Posted by Texgunner on Friday, January 23, 2015 8:25 AM
I like it a lot Vance!  Neat subject too, early Israeli airpower was certainly interesting...and sometimes somewhat ironic too. Wink   You did a great job on this kit!Yes
Gary
"All you mugs need to get busy building, and post pics!"
    July 2014
Posted by modelcrazy on Friday, January 23, 2015 9:18 AM
VanceCrozier
Whistling
Mine way over hung the rudder, and just came apart as I was maneuvering them. I was going to paint the stripes, but I figured, what the heck, the only people who will know the deference are the ones familiar with the subject. This does not include anybody at my home where it will be displayed. The rest of the decals gave me fits but started to behave after several coats of MicroSol.
Steve
    September 2005
Posted by Sprue-ce Goose on Friday, January 23, 2015 12:42 PM
Additional kudos for that build, Vance !!
Would be a good reason to celebrate by opening a fresh bottle of Manischewitz wine.Toast
.....and maybe some catnip for Agent 003Whistling
Posted by VanceCrozier on Friday, January 23, 2015 4:23 PM
I can guarantee the catnip.... I may swap the Manischewitz for a good cup of coffee though.  ;)
