Tamiya 1:48 Sturmovik Completed
    April 2013
Posted by Greatmaker on Thursday, February 5, 2015 1:35 PM
I've been building airplane models for a little over two years and I'm constantly amazed by the work I've seen on this site.  I'm currently working on a Sturmovik and I have some basic questions.  I've had a great deal of trouble with primers and I've used a stores worth of different brands.  I like the krylon primers but their gray is so dark that it makes pre-shading useless.  I've tried Model master, Tamiya, Rustoleum...which makes model master BTW, Velspar and various assorted no  name brands.  I airbrush model master acrylics...yeah I know..but its the only paint that's available locally.  Any suggestions on a good primer for acrylic?  The krylon white doesn't seem to work so well for me.  I seems to take a lot and doesn't want to dry. Another question I have is about gluing painted pieces.  I generally put as much of the plane together as I can before priming.  That means I end up hand painting the wheel wells, struts and covers.  I've tried airbrushing them first but when I glue them on it makes a big mess....even with scraping off the paint.  What do you guys use for glue?  Next up canopies.  I've tried masking but with the acrylics i usually have a chipping problem.  I've found what works the best for me is to prime, paint and over spray with dullcoat and remove the masks while the paint is still rubbery.  Otherwise its hand painting and dipping in future which makes the frames glossy. Because I have to remove the masks quickly I do all the painting off the plane. This makes it hard to get a continuity of finish. Any ideas on the masking.  I use elmers white glue to glue them to the plane.  Last question.  Whats a good wash to use over acrylic.  I've tried thinning acrylic black and dark gray but the results are spotty at best.  Thanks in advance
    March 2010
Posted by Nathan T on Thursday, February 5, 2015 2:59 PM
Hmmm....Try Gunze Mr. Surfacer, bottle or spray can. 1200 or 1500. Tamiya Super fine primer in the spray can is awesome. Not sure why it isn't working for you? Use a liquid cement like Tamiya extra thin. Try thinning your MM acrylics with a custom mix of 50% distilled water and 50% ISO alcohol, and a few drops of Liquitex retarder. It adheres better. Make sure you are using Tamiya tape for all your masking, especially for canopies!!! Or, buy Eduard pre cut masks. I wont explain this stuff much further, just use google or the forum search here and you will find discussions on all these products.
    February 2014
Posted by CN Spots on Thursday, February 5, 2015 3:16 PM
I feel your pain on the lifting acrylic.  That stuff needs more R&D.
Primer:  I prefer Tamiya's Fine primer in a rattle can.  Duplicolor auto primer would be second.
Glue: Tamiya thin cement or Zap CA.
Canopy: Glue to plane, Mask with Frog tape (yellow) or Eduard's canopy masks, paint along with plane, lightly run a sharp knife around the edges before removal.
Wash over acrylics:  I use oil paint thinned with Ronsonol (lighter fluid).
    April 2013
Posted by Greatmaker on Thursday, February 5, 2015 5:49 PM
Thanks for the replies.  This model Is a gem and I want to do it credit.  I do use tamiya tape for the canopies.  I've tried various mixes of ISO to water for thinner but it seems to plug my aztek airbrush. Plus I get orange peel. I had a lengthy discussion with the testor aka rustoleum folks and they recommended either their thinner or distilled water in a 7:3 ratio.  It took some time to get used to but with plain water I get a much smoother finish.  Do you use the tamiya extra thn cement to glue on painted parts or just the CA? Are any of the premade wastes any good? I've also done the sharp knife on the edges of the mask thing. I guess I can't cut a straight line because I always muck that up.  I'm gonna try something new with the hand painting. I find with acrylics it's very hard to thin it correctly to get a nice even coat.  Too thin and it runs all over and multiple coats tend to get "gloppy" for me.  I tried using a embossing tool instead of a brush to apply unthinned paint. I did this on a practice canopy and it covered extremely well and I was able to burnish the paint around.  Only drawback was that like brushed paint it was glossy. I also used a darker paint so I don't know how it would do with lighter ones.
    June 2013
Posted by RobGroot4 on Thursday, February 5, 2015 7:25 PM
For the canopies, you could always use a method that works and gives you a glossy finish then brush on some acrylic flat coat (MM makes one).
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    February 2014
Posted by CN Spots on Thursday, February 5, 2015 7:51 PM
Glues like the Tamiya thin need to be applied to bare plastic.  It melts it rather than glueing two pieces together.  Being very thin it will flow into tiny gaps like seam lines  even when they are pressed together and leaves little to no residue.  Very handy stuff.
    March 2010
Posted by Nathan T on Thursday, February 5, 2015 7:58 PM
You need a retarder such as liquitex with MM acrylics. Tough paint to get along with if u ask me. I ditched them Long ago.
    November 2003
Posted by tempestjohnny on Friday, February 6, 2015 5:59 AM
I agree with Nathan. MM acrylics are very difficult to work with
    January 2015
Posted by BlackTulip109 on Tuesday, February 10, 2015 10:58 PM
From what I saw on "Alex Modeling" on U-Tube he uses Vallejo Weathering washes and wow did it look nice on his models haven't tried it yet but maybe someone on Forum might comment
    April 2013
Posted by Greatmaker on Wednesday, February 11, 2015 12:26 PM
Well I'm still plugging away on this one. I've pretty much given up on keeping the little doohickey on the top of the tail intact. I tried re-enforcing it with superglue numerous times but it always seems to be a casualty of war. Last nights project was pre-shading and painting the underside. I used the tamyia primer instead of the darker gray krylon so I could actually pre-shade. I was also amazed at how much less paint was needed for coverage. Unfortunately I had a crash landing so the tail wheel needed some repair. One thing about the tamyia primer. It has an atrocious smell. I used it in my basement and by the time I finished I had a whopper of a headache and the whole house stunk...even using a mask. I did buy some Walmart home shades primer. It had nearly the same color but without the smell. Plus it was dirt cheap. I've only tried it on some scrap plastic so the jury is still out. Have any of you guys used this? Thanks
    September 2003
Posted by blkhwkmatt on Thursday, February 12, 2015 7:57 PM
I use Tamiya primer, it does smell horrible, but is amazing.  I have not had any problems with MM Acrylic paint over this, but it is a tricky paint to work with.
For landing gear, doors and all the other little bits, I normally paint them seperately and then add at the appropriate time with either super glue (CA) or something like tenax 7R with a touch and flow applicator.
For my canopies, I dip in future and let cure first, then mask, prime, paint as needed, etc.  Only once the weathering and dull coats are on do I peel off the tape.  For the longest time I was loathe to by the tamiya tape due to cost, but I have found it to be well worth the money.
For weathering and washes I use artists oil paints mixed in white turpentine after a good gloss coat is on over the decals.  The gloss coat makes the oil paints flow farely well and since one is acrylic ( I use future for my clear coats) and the oil is enamel based there is not much of a reaction.  Once I am finished with the weathering I seal up the paint with an acrylic flat coat and remove all the masks.
Hope that this helps.
<Matt
Quidquid latine dictum sit, altum videtur!!! - Anything said in Latin sounds profound!
    April 2013
Posted by Greatmaker on Friday, February 13, 2015 7:59 AM
Thanks Matt I found out last night how well Tamiya primer works.  I used the wrong green paint so I figured I could just strip it off with windex or alcohol since I had just applied it.  I did get some off but I ended up repainting  in neutral gray to start over.  Since I've thinned MM with just water it's worked a ton better.  I thought about switching to Tamiya paints but I noticed they don't have RLM colors. I'm going to look into some flow enhancer
    April 2013
Posted by Greatmaker on Monday, February 16, 2015 6:43 PM
Well I finally finished the model.  It was an excellent kit  I'm gonna try and post some pics
    January 2015
Posted by BlackTulip109 on Monday, February 16, 2015 10:52 PM
I too have been watching Alex Modeling and a couple other guys and they all use "Vallejo".
Someone told me Hobby Lobby has them but only limited colors.
I have a lot of built and unpainted kits my 11 year old son built and thought we could use them as the "guinee pigs" to experiment on.
I haven't used my airbrush yet as we are deep into winter and can't use the garage or outside because of the frigid weather.
SO
I have been teaching my son to handpaint. Yesterday and today we painted 3 of his aircraft using the Vallejo paints. All I can say is WOW I can't believe how the job looks after the paint drys!!!
It lays down very nicely! Looks great!!
Did I prime?
Yes!!
I used the Rust-O-leum(R-O-L) spray can paint that says says safe on plastic. I used the light grey, I also have the white and a few others. The Hunter Green looks really nice too.
I very lightly dusted the R-O-L first let it dry overnight and tonight handpainted with the Vallejo. I am pretty impressed. Can't wait to see how it looks airbrushed!!
    June 2014
Posted by VN750 on Monday, February 16, 2015 11:05 PM
I was at Hobby Lobby today and they sell Testors and Model Master paints.  Could be a regional market thing.  Those folks don't even use scanners at checkout.  Everything is punched in by hand.
I'm assuming that Valljo is not an acrylic.  Thanks for the ROL tip.  I'm guinea pigging with a couple of models at present.  Stripped an old Lindberg 262 to repaint.  Gives me practice on the German paint schemes.
    June 2014
Posted by VN750 on Tuesday, February 17, 2015 10:21 AM
I may have to correct myself on the Vallejo paints at Hobby Lobby.  I went online and realized that Vallejo paints come with nondescript labeling and I believe I did see them at the local HL.
    April 2013
Posted by Greatmaker on Tuesday, February 17, 2015 11:59 AM
Finally figured out how to make the pics show up.  So far this is the best fitted kit I've done.  Even the rocket fins fit the to rocket body was seamless.  My only issue was the little doohickey on the tail fin.  despite my best efforts and re-enforcing with superglue.  I busted it off multiple times. First time for me with a premade canopy mask that worked slick
Posted by Gamera on Tuesday, February 17, 2015 2:13 PM
Glad you got the photos working- she turned out great! Congrads!
    February 2015
Posted by GoatPants on Tuesday, February 17, 2015 4:02 PM
Very nice! Love that bird.
cnq
    March 2013
Posted by cnq on Wednesday, February 18, 2015 7:33 AM
Greatmaker, very  nice finished. It's the best 1/48 kit out there for this plane. I built the same kit last year.
    April 2013
Posted by Greatmaker on Wednesday, February 18, 2015 9:04 AM
Thanks for your replies. Cnq your build is amazing. Thanks for sharing.  I'm kinda leery to post pics of my models as they are no where near the quality of the ones I've seen on this site.
    February 2012
Posted by lawdog114 on Wednesday, February 18, 2015 7:34 PM
Nice work.
Joe
    June 2014
Posted by BrandonK on Wednesday, February 18, 2015 11:26 PM
Super job.
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    August 2010
Posted by flyinyak on Saturday, February 21, 2015 10:14 PM
Great build. I built the 1/72 version - that kit is just gem too. So much detail for a small kit, but it went together great.
    April 2013
Posted by Greatmaker on Monday, February 23, 2015 1:13 PM
Thanks flyinyak.  That's good to know.  I think I should have chosen 1/72 instead of 1/48.  I'm running out of room fast.  Gotta love airwolf
    January 2013
Posted by BlackSheepTwoOneFour on Monday, February 23, 2015 9:19 PM
Vallejo is acrylic paint
    January 2013
Posted by BlackSheepTwoOneFour on Monday, February 23, 2015 9:21 PM
The IL-2 is on my wish list but boy, oh boy is it pricey...
    January 2015
Posted by BlackTulip109 on Tuesday, February 24, 2015 9:45 PM
Don't feel reluctant to post any of your work on this FORUM.
I am finding folks VERY encouraging andhelpful.
That model IL-2 you built does look great.
I have the 1/48 Accurate Minitures kit  which I plan to build. The guy who founded A.M. used to be a member of the model club I had belonged to when I was living in Chicago!!!
He was extemely precise in his modeling outstanding modeler!! He would scratch build in 1/32 scale ALL his models were works of art!! Great guy would help anybody with model questions NEVER "Big Leagued" anyone.
