Visible P-51
    November 2014
Visible P-51
Posted by home_planit on Friday, February 13, 2015 4:49 PM
What would be the best glue for all of the clear parts on the visible P-51.  Most canopy glues aren't too strong, so something stronger and crystal clear would be much preferred
Thanks.
    May 2014
Posted by SubarooMike on Friday, February 13, 2015 5:06 PM
I built one (Monograms Phantom Mustang) with Tamiya Extra Thin.   The other I built with MM glue (with the metal tip) when I was little
    February 2011
Posted by Raualduke on Friday, February 13, 2015 6:41 PM
I saw that kit in the last squadron flyer,anybody built it?
    January 2015
Posted by GreenStyrene48 on Friday, February 13, 2015 8:40 PM
If you coat the clear parts with future you could use super glue without causing hazing.
    September 2012
Posted by GMorrison on Friday, February 13, 2015 11:10 PM
Yes, and it's a good model. Believe it or not it was the only 1/32 Mustang D for a long time.
    July 2014
Posted by modelcrazy on Friday, February 13, 2015 11:17 PM
I would use CA, but then again, I always use CA.
If you building a Stang, why don't you consider joining my Mustang Build. Just follow the link below.
Steve
    January 2014
Posted by Silver on Saturday, February 14, 2015 8:28 AM
Try the regular Tamiya liquid cement.Tac it on at major points then work your way up for final seal.Overall seal the model w/non-spar varnish w/overnight during time.The model is ment to display the internal parts and working ability .
Posted by Don Stauffer on Saturday, February 14, 2015 8:54 AM
Epoxy is also an old standby for gluing transparent materials- no fogging.
    February 2011
Posted by Raualduke on Saturday, February 14, 2015 5:43 PM
I kinda wanna build that kit,but gluing clear plastic without fogging  scares me
    September 2005
Posted by Sprue-ce Goose on Saturday, February 14, 2015 6:41 PM
What ever happened to the technique of coating clear canopies with Future floor wax to prevent fogging by CA.
No longer valid or not practical for an entire kit in 1/32 ?
    January 2003
Posted by bigfoot01 on Saturday, February 14, 2015 9:13 PM
I used good old fashioned Testors tube glue on mine. Just use it sparingly and be careful not to get it on your fingers. I would NOT use CA, especially with a setting agent as it will almost certainly craze the plastic
John
