Academy P-39
Academy P-39
Posted by Bossman on Wednesday, February 18, 2015 8:24 PM
Hello all,
Here's my most recent completion.  I did some experimentation with panel line washes and adding various little bits of color variation to break up the olive drab.  I'm pretty pleased with the results although you can't really see the color variation very well in these pics.  I need a better lighting arrangement - or simply MORE LIGHT !
This is the 1/72 Academy P-39.  Built outta the box, with kit decals, masking tape harness, and various barrels drilled out with small drill bits.  After taking the photos I just noticed that the exhaust pipes weren't drilled out - but I don't know if I have a drill bit that tiny.  The only build issue I had was the fit of the 2 canopy parts.  If I had taken more time with dry fitting I probably could have corrected this fairly easily.  All-in-all, a pleasant kit to work with, nice detail, and low cost.
Criticism Welcome !
Thanks for looking,
Chris
    November 2003
Posted by mississippivol on Wednesday, February 18, 2015 9:02 PM
Hey, that's boss!....man....
Very nice, indeed.
    March 2005
Posted by Devil Dawg on Wednesday, February 18, 2015 10:53 PM
Great job!
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
    August 2013
Posted by Jay Jay on Thursday, February 19, 2015 10:42 AM
Very ,very nice job.  You're experimentation with the panel line washes looks real good, not too overpowering, nice and subtle. I'd like to know what you did if I may ask.
    February 2007
Posted by Buckeye on Thursday, February 19, 2015 11:09 AM
Mighty fine work there!
Posted by midnightprowler on Thursday, February 19, 2015 4:54 PM
Beautiful! I built this one as well as the AM  1/48 .
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by Gamera on Friday, February 20, 2015 11:41 AM
She looks beautiful!
Nice seeing a P-39, a plane that got too much bad press but did pretty well as what it was designed for- ground attack.
Posted by Bossman on Sunday, February 22, 2015 7:26 PM
Thanks for your kind words guys !
Jay Jay -   I would be happy to telI you my method.  I brush paint with MM acrylics.  Most of the time I will dilute them a bit with a little water so that they are just slightly runnier than straight out of the bottle.  I used a slightly lightened olive drab as the base.  (OD + abt 5% light aircraft grey).   I only brush the paint when the paint is wet.  That sounds kinda stupid - but the paint thickens up and starts to dry pretty quickly.  As soon as it starts getting a bit more viscous, I just leave it alone so I don't get brush marks.  If I have any puddles on the surface, I soak them up with a relatively dry brush.  A second coat can be applied about 5 minutes after it is dry. Better to do more coats than try to apply it too heavy and "work" it with the paintbrush - you're sure to get brush marks then.
Then I mixed a small puddle (about the size of a dime - in some really small containers) of the lightened OD with a drop or two of red and another small puddle with a couple more drops of light grey.  These very slight variations were diluted with a bit more water and I just painted them on in various places to give either a grimy appearance (red) or a kindof faded appearance (lt grey).  They were used sparingly.  They were brushed on "in the direction of airflow" as best as I could determine.
For darkening recessed panel lines I used MM "Marine Green" which is a dark shade of green.   It was diluted with water to make it a little thinner and runnier, and applied with a very fine brush.  I like the way the marine green isn't quite as dark as a black, and overtop the OD, it is even more subtle.  If the darker shade goes on a little heavy in spots - I go back later with the base color and "erase" it by simply painting out the parts I don't like.
On the underside, I used the same panel highlighting - but with a dark grey instead of marine green.
Its a kindof slow, pains-taking method  -  but I guess I'm into pains-taking  -  I'm a plastic modeller !
Model On !
Chris
Posted by Bossman on Sunday, February 22, 2015 7:34 PM
Gamera,
Yeah - I don't see many P-39's modeled.  I guess that's part of the reason I wanted to build it.  That, and it's kindof unique with the engine mounted in the middle.
Chris
    August 2009
Posted by TREYZX10R on Sunday, February 22, 2015 9:44 PM
Chris great color modulation and panel line work. That looks more like a 1/48 than 72 ,very nicely done Sir!
    February 2013
Posted by Chanter on Monday, February 23, 2015 11:01 AM
Fantastic job and a great scheme choice.
I really like the look of those New Guinea birds.
Allen
ButcherbirdBadgesmall_zps1d50c6bb1944 GB
