Esci 1/48 Ground Support Set (a sort of WIP)
    July 2004
Posted by stikpusher on Wednesday, July 19, 2017 11:57 PM
BK, I think the biggest thing is the optempo today. We have been at war for almost 16 years. Peacetime military usually has some downtime for all the appearance stuff. Even when you throw in the occasional short wars like Desert Storm, Deliberate Force, Allied Force, etc. Not to mention the current budget caps for the past five years or so...
I was looking at railroad decals and think I found some that will work. Or at least look close enough.
Rich, thanks for that manual link. That will come in handy for this project. I know US Army markings extremely well, but I know absolutely zip about USAF vehicle markings.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    September 2005
Posted by richs26 on Thursday, July 20, 2017 12:26 AM
Stik, notice the USAF registration numbers.  The first is the FY designator followed by two spaces, the vehicle class letter, and then the serial number.  Your AGE tractor would be like 74  D1215.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    July 2004
Posted by stikpusher on Thursday, July 20, 2017 12:58 AM
Ok, that sounds good. I am just in the beginning of the manual. I found that I did use the correct green, FS# 34052 On the tractor and tow bar. I will top coat it in semi gloss to get the 24052 appearance. I have plenty of black numerals I can used to fudge serials and such.
       - Plankton
LSM
    March 2005
Posted by Devil Dawg on Saturday, July 22, 2017 2:07 AM
Dang it, guys!! Just when I thought I had enough stuff to build, now ya'll go and make me wanna go and buy all the GSE to go with my kits!! AAAARRRRRGGGGGHHHHH!!!
Stick out tongue Propeller
Seriously though, great jobs on all the work you folks are putting into that GSE (ground support equipment for those of you that didn't know).
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
Posted by Bish on Saturday, July 22, 2017 4:40 AM
Devil Dawg
If it means we get more diorama's, it will be worth it Wink
    July 2004
Posted by stikpusher on Saturday, July 22, 2017 9:28 AM
Bish
Devil Dawg
i don't know about full blown dioramas, but I plan on more vignettes like this...
       - Plankton
LSM
    June 2014
Posted by BrandonK on Saturday, July 22, 2017 10:50 AM
This is the M32-60A, or -60 as we called it. It is a turbine generator that has a turbine the size of a man. It is used to provide air for aircraft engine startup and generates power for AC maintanence. It is VERY LOUD. It was by far my favorite piece of equipment to work on. The box on top of the unit is the exhaust that points straight up. It idles at a constant 48000 rpm. Impressive little unit.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    July 2004
Posted by stikpusher on Saturday, July 22, 2017 1:17 PM
Is that the item on the left that comes in this Hasegawa set?
I plan on picking up this set in the near future
       - Plankton
LSM
    June 2014
Posted by BrandonK on Saturday, July 22, 2017 1:46 PM
Yes Sir, that is the one. Although it is displayed with the towbar down. That can't be done as those are spring loaded. When up the apply the unit brakes, when pulled down to tow they release the brakes. So it's not possible to have it disconnected and laying down. The same with most of the units. The hydraulic test mule on the right is also down, which is wrong. And I've never seen the bleed air hose yellow. They were always off white to cream with a black rubber coated cable wrapped around it. Other than that, they look the part.
BK
Some one needs to do up a crew chief giving his salute to the plane when it taxied away and a thumps up for good luck.
On the bench:
                         14 / 5 / 2
                              Tongue Tied
Posted by Bish on Saturday, July 22, 2017 2:37 PM
BK, nice info there, thanks. I have the 72nd Hase sets, so will have to remember that about the towbar.
I altered a 72nd figure to have his hand coming up into the salute in an F-16 dio, couldn't figure why no one had done a figure like that.
Is that SOP for all US groundcrew.
    June 2014
Posted by BrandonK on Saturday, July 22, 2017 4:45 PM
I believe all the branches salute the pilot. The crew chief is enlisted and the pilots are commissioned, so the salute is always done. The rest of the crew doesn't salute unless they approach or are approached by the officer. Otherwise, there really is little to no contact between pilot and ground crew, mostly just the crew chief since he/she is responsible for that AC. Many cheifs will also touch the plane and give a thumbs up as a offer of good luck and safe return. A bit of a superstition, but cool to watch.
And ALL ground crew, no matter their role, if on the flight line wear a reflective high vis belt in either yellow, red or blue depending on what section you are assigned to. SO, if you are doing figures for stateside AC all the ground personel on the flightline will wear those belts and be colored according to each section.
This kit of stuff isn't all that uncommon to be honest, but they always salute.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
Posted by Bish on Saturday, July 22, 2017 5:08 PM
Ye, seen those reflective belts at Lakenheath. Didn't add that to my figure as i didn't know when i did that one, but will be sure to next time.
You might like this one.
Our guys don't usually salute, but as they don't wear head dress, it would not be appropriate.
    June 2014
Posted by BrandonK on Saturday, July 22, 2017 5:25 PM
LOL, there is always one guy, that guy that's always a clown.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    July 2004
Posted by stikpusher on Saturday, July 22, 2017 6:39 PM
these guys were supposed to be doing the "wave"... 1991
       - Plankton
LSM
    March 2005
Posted by Devil Dawg on Saturday, July 22, 2017 7:11 PM
Bish
That is hilarious!! That wouldn't be YOU in the video, would it, Bish??
Devil Dawg
Posted by Bish on Sunday, July 23, 2017 1:33 AM
Devil Dawg
Bish
LOL, no way, they wouldn't let me lose on one of those. Though i was trained as a helicopter handler.
Posted by Bish on Sunday, July 23, 2017 1:34 AM
stikpusher
Now there's an idea for a build Big Smile
    June 2014
Posted by BrandonK on Sunday, July 23, 2017 10:22 AM
"Goofy Marshalling GB" LOL.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    July 2004
Posted by stikpusher on Sunday, July 23, 2017 3:57 PM
That is just not right...
       - Plankton
LSM
    July 2004
Posted by stikpusher on Tuesday, July 25, 2017 10:17 PM
BrandonK
I forgot to mention. Since most of the AGE equipment spent time on or near the flightline and was moved around day and night, they all had reflective tape all over them so they would show up at night.
Well I found the decal sheet for this stuff last nite. It has all the reflector tape for the loader and tractor. Plus various stencils and the instrument gauge dials. So I'm in business!
Did the tow bars have reflective tape on them?
       - Plankton
LSM
    June 2014
Posted by BrandonK on Wednesday, July 26, 2017 9:04 AM
Please give us a link or info on those. I am keen to look into that stuff. It would be fun to build up some of those pieces I used to work on.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
