Scale differences between model manufacturers.
    June 2014
Posted by VN750 on Sunday, March 22, 2015 6:14 PM
I have two Dauntless SBDs.  One is a Hasegawa SBD-3 the other a Monogram SBD, both 1/48.  Due to a decal problem (yellowing) with one I looked at the decal sheet of the other for a solution.  Immediately I noticed a difference in the physical size of the two.  The Monogram was smaller by about a .3 inch on the wing span. I checked out a wiki on the SBD and a cursory reading said nothing about a change in wing span with its variants.
I've seen some threads on FSM where modelers use parts from other brands to fill in a need for some variation in the model which can be useful but the seem to require a little modification.
Using an engineering scale I measured the two models and found the Hasegawa to be a close 1/48 and the Monogram to be more on the order of a 1/50 or smaller.
How much variation is there between model manufacturers?
    July 2004
Posted by stikpusher on Sunday, March 22, 2015 6:29 PM
It all depends upon the age of the kit and the accuracy of the plans used by the model companies to make their molds. But there can be a serious amount of variance in kits. Lest just start with figures and take it from there...
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    June 2014
Posted by VN750 on Sunday, March 22, 2015 6:53 PM
Taking today as a starting point, are manufactures consistent in their scale representations?
    August 2005
Posted by Phil_H on Sunday, March 22, 2015 7:00 PM
Sometimes I just have to laugh at the variance in size/shape of Sidewinder missiles between different kits, sometimes from the same manufacturer. (Different variant of missile notwithstanding)
Mij
    September 2014
Posted by Mij on Sunday, March 22, 2015 8:26 PM
Even using today as a starting point kit makers still get easy stuff wrong. The Trumpeter and Wolfpack 1:48 T-38s have a noticable difference in fuselage length and these are relatively new tool kits. If I remember correctly the conclusion I read was the Trump was too long and the WP was too short. The Hasegawa 1:48 F-22 has ridges on the fuselage and wings that are inaccurate and look terrible. I believe while most kit makers do improve their research and acuracy on sequential kits they still get stuff wrong.
On the bench
1:48 Testors SPAD XIII
1:48 Revell P-47D Razorback
1:48 Hasegawa Bf 109E Galland
    September 2005
Posted by richs26 on Sunday, March 22, 2015 10:12 PM
Another good example is Valom's 1/72 original B-26's which are very portly and long compared with the other B-26's like the Mono Snaptite and the Airfix B-26B.  The Snaptite is considered almost an accurate representation of an early B-26.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    June 2014
Posted by VN750 on Sunday, March 22, 2015 10:19 PM
FWIW,  the Monogram copyright is '88 on the instructions, '90 on the box.   The  Hasegawa is '94 box and instructions.   I think the experienced modeler out there knows the pitfalls better than I do but how else do you learn other than by buying the stuff.  Short cut to knowledge:  buy on ebay.
    June 2014
Posted by VN750 on Sunday, March 22, 2015 10:25 PM
Know nothing about Snaptite but can you get a decent model from it?
    September 2005
Posted by richs26 on Sunday, March 22, 2015 11:32 PM
From several modeler's reviews, yes you can.  Google for Monogram Snaptite B-26 and you can read several reviews on the early B-26 which is what Kermit Week's and MAP's is.  The tail position glass is available from Squadron which has had it for many years.  Also google for the site, Flat Spins and Milkruns, where the author is building one.
Posted by Don Stauffer on Monday, March 23, 2015 9:18 AM
It is more than just scale variations.  Kits often have many other glaring inaccuracies.  Some kits are better than others, and I do think in general model companies are getting better.  And yes, some brands are better than others as well.  I think in these days of easy contact of mfgs, we do need to complain to companies. It is one thing to vote with your pocketbook, but even more effect is to vote with pocketbook but let mfgs know your unhappiness with offerings that are too bad in scale or details or whatever.
    January 2007
Posted by PaulBoyer on Monday, March 23, 2015 10:07 AM
While dimensions may vary among manufacturers even today, a lot of the older Monogram kits (and the SBD first came out in the late '50s-early '60s) were roughly 1/4" scale. I don't think the kit designers were fanatical about getting the dimension exactly 1/48 scale, and several of the Monogram kits labeled 1/4" scale are actually a bit smaller - the T-28 Trojan comes to mind - but it didn't really matter much to the buyers back then. The "scale" gave them a rough idea of the size of the finished model. Most Monogram WWII kits and Lindberg jets of that era were " 1/4" scale" which was big enough to have rudimentary working parts (retractible landing gear, dropping bombs, folding wings, etc.) and passable, if not fantastic (in the classical sense) detail.
