FINISHED AIRFIX P40B 1/48
    January 2015
Posted by M. Brindos on Monday, June 12, 2017 11:50 AM
Those seams should be easy to eliminate. Maybe a touch of putty around the nose, but nothing you can't handle, Piper. :)
- Mike Brindos "Lost Boy"
    November 2016
Posted by iampiper13 on Tuesday, June 13, 2017 10:05 PM
Thanks man, I still stink with putty but am improving some, lol you should see my drywall patches.
Knuckles are on, one went on with very little prep but the other ugh. Need to let the putty cure and should be ready for sanding tomorrow.
    January 2015
Posted by M. Brindos on Tuesday, June 13, 2017 10:53 PM
What brand/type of putty are you using?
    November 2016
Posted by iampiper13 on Wednesday, June 14, 2017 5:52 AM
M. Brindos
Tamiya white
    September 2014
Posted by rooster513 on Wednesday, June 14, 2017 6:02 AM
iampiper13
M. Brindos
Tamiya white
Nice work so far iampiper! You may already know this but mixing Tamiya White putty with their Lacquer thinner makes it a little easier to work with. I've found that it allows more control and can be "painted" on just where you need it.
-Andy
    November 2016
Posted by iampiper13 on Wednesday, June 14, 2017 7:06 AM
Rooster, yeah I learned that last night lol I'll need to pick some up as I use my daughters finger nail polish remover to clean my brushes and not sure I want to use that.
    November 2016
Posted by iampiper13 on Wednesday, June 14, 2017 6:01 PM
The paint scheme for the AVG one calls for light earth and dark green, I have a bottle of dark Earth but not the light earth what I do have is dark Earth, brown and dark tan. Not sure when I can get to any hobby stores and don't feel like ordering online, would any of the colors I mentioned be close enough?
    February 2012
Posted by lawdog114 on Wednesday, June 14, 2017 7:47 PM
Looking great. Try "Perfect Plastic Putty". It cleans up with water and works great. SinceI've discovered it I don't use the lacquer based ones anymore.
    January 2015
Posted by M. Brindos on Wednesday, June 14, 2017 9:11 PM
Use the dark earth and lighten it with white. Its okay to mix your colors in this hobby lol. Maybe a 50/50 mix with your tan would work as well. :)
    November 2016
Posted by iampiper13 on Friday, June 16, 2017 7:08 AM
Bottom is painted, I used MM camouflage grey rattle can. I did mix up some light earth and used it for the prop covers I'll get a picture of that when it dries.
    November 2016
Posted by iampiper13 on Friday, June 16, 2017 5:02 PM
How's this look for light earth?
    January 2015
Posted by M. Brindos on Friday, June 16, 2017 5:55 PM
Looks too light. Add more Dark Earth.
    November 2016
Posted by iampiper13 on Saturday, June 17, 2017 7:27 AM
M. Brindos
Cone is painted with adjusted paint, better? And thanks for your help!
    January 2015
Posted by M. Brindos on Saturday, June 17, 2017 1:40 PM
I believe that will pass. :)
    November 2016
Posted by iampiper13 on Saturday, June 17, 2017 1:51 PM
That's a crappy picture sorry
    March 2015
Posted by Toshi on Sunday, June 18, 2017 4:42 AM
Looking forward to more rounds sir.  Great job so far.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    November 2016
Posted by iampiper13 on Monday, June 19, 2017 7:17 AM
First coat of light earth is on!
    June 2017
Posted by jmoran426 on Monday, June 19, 2017 8:42 AM
Excellent work on the pilot.
jmoran426
    June 2017
Posted by jmoran426 on Monday, June 19, 2017 8:59 AM
Just an "in general" question about using body putty...but is it an accepted practice to use masking tape on either side of a major joining seam to help keep the putty from getting too far from the target area? I did this technique on a 1:48 O-1 with pretty good results. Kept the putty from straying into recessed panel lines and the like, and made finish sanding easier. I'm not sure this is mostly done.
jmoran426
    November 2016
Posted by iampiper13 on Monday, June 19, 2017 12:24 PM
As far as I know its fine, I've doen it before and should have on this....
    November 2016
Posted by iampiper13 on Monday, June 19, 2017 12:47 PM
M. Brindos
If you don't have any Micro Set and Sol you should add those to your future aquisitions list. They help a lot!
MicroSet Setting Solution?
    January 2015
Posted by M. Brindos on Monday, June 19, 2017 2:37 PM
iampiper13
M. Brindos
Yes, that stuff. :)
That light earth looks about the right color in thos pictures. I think you have a very good grasp on this kit, Piper. You're doing really, really well!  :D
    November 2016
Posted by iampiper13 on Wednesday, June 21, 2017 8:19 AM
Final  coat of dark green on, I used MM.
    January 2015
Posted by M. Brindos on Wednesday, June 21, 2017 3:21 PM
Still looking pretty good, Piper. Not bad at all for hand painting.  :)
    November 2016
Posted by iampiper13 on Wednesday, June 21, 2017 4:21 PM
Thanks, I keep thinking of going with an airbrush but can't really afford that right now and hand painting is really enjoyable to me.
So I'm going to try and be lazy lol I know I've seen in other P40 WIPs about the color of the filler caps behind the pit, whats the colors for the AVG model?
    January 2015
Posted by M. Brindos on Wednesday, June 21, 2017 5:08 PM
The filler caps can either be red or black for the fuel cap and yellow or aluminum for the glycol cap. For the AVG I have seen combinations of those. For a regular -B/C they were black and aluminum.
    August 2013
Posted by Jay Jay on Thursday, June 22, 2017 9:25 AM
Man you are an expert at hand brush painting. Looks like an air brush job to me. WELL DONE Mate.Beer
    November 2016
Posted by iampiper13 on Saturday, June 24, 2017 8:04 AM
Canopy is on, I think so far the only complaint I have is that it seems the clear parts are too light/thin but most of that may be that I'm a klutz lol I'm hoping to get the decals on today.
    November 2016
Posted by iampiper13 on Saturday, June 24, 2017 8:38 AM
Jay Jay
Thank you :)
    March 2015
Posted by Toshi on Saturday, June 24, 2017 10:26 AM
I second Uncle Jay Jay!  Looks like you AB the kit.  What a great job you've done.  Looking great!
Toshi
