...NOSE WEIGHTS
The main landing gear is located under engines two and three. There is a whole lot of plane behing the landing gear, so a lot of weight is required to keep the plane from being a tail sitter...
First I added weights to the underside of the cockpit floor. There really is not a lot of space for weights under the floor, so I decided to add weight in the flight engineer's area behind the pilots (outlined in blue). Once the fuselage is assembled this area is hidden from view...
Next I filled the bag with white glue to keep the shot from moving around. I placed the bag into the model and noticed that the bag was visible through the opening in the wall behind the pilots and the flight engineer. Now what? I could paint it black, but I didn't like that solution. I looked on line for a photo of the wall behind the flight engineer. I printed the picture, cut out the image and glued it behind the opening. Problem solved...
