Plamodel/Marusan Aichi E13 Jake FINISHED.
    October 2016
Posted by DasBeav on Friday, June 22, 2018 4:45 PM
Another fit problem. Tab A(wing) will not fit into slot B(fuselage). The wing tab is a least 1/32 to thick to fit into fuselage. Not even going to use my mini-file and going with my wood file.
And have decided to just glue flaps into place like the rudder. The way the parts are designed they really don't move, they just sort of wiggle.Smile
I have counted at least a dozen sink marks so I will just be putty/ sanding/repeat all weekend. Supposed to rain all anyway.
 Sooner Born...Buckeye Bred.
    October 2016
Posted by DasBeav on Sunday, July 22, 2018 11:51 AM
After a brief hiatus of posting because of 4th, relatives visiting, golf, gardening,etc. I am making progress. The pontoons needed alot of work, with some more to go. I did make the mistake of not putting the struts in when gluing the pontoon halves. The struts had a lip around them which now has to be cut off.  Actually worked out for the better for PSR and when it comes to painting. Blind Squirrel!
    October 2016
Posted by DasBeav on Sunday, July 22, 2018 11:59 AM
It took some work to get the wings to fit this well on the top. Being a modelling "hack", my techniques are probably "Cringeworhty" to the skilled modeller. I left the wings foldable because gluing them in place would have required ALOT of effort I am just not willing to put in. And was not certain that it would look any better.
    October 2016
Posted by DasBeav on Sunday, July 22, 2018 12:12 PM
The bottom looks horrendous and the wingroots need work. I am going to put in some "shims" to fill the gaps. Probably should have done that before I glued, but have never done it before. When is all said and done the "jake" should turn out OK, but this is the "Wonkiest" model I have ever built. And after seeing photo of the back wings, they need fixed.Sad
    March 2015
Posted by Toshi on Sunday, July 22, 2018 12:41 PM
DasBeav
Dasbeav, you are the man to build something like this, your build looks better and better.  I look forward to your next installment!  fantastc job.
Your freind, Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    July 2004
Posted by stikpusher on Sunday, July 22, 2018 4:12 PM
Better to have those gaps in the bottom where:1, they are less visible, and 2, the flat surrounding areas are easier to work with for filling and sanding.
And you’re doing a fine job of whipping this beast into shape!
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    October 2016
Posted by DasBeav on Sunday, July 22, 2018 8:44 PM
Toshi
DasBeav
Your freind, Toshi
Thanks, Toshi! Means alot. Did get the seams on the bottom fixed but have technical issues so no pics today.
    October 2016
Posted by DasBeav on Sunday, July 22, 2018 8:50 PM
stikpusher
Thanks, Stick! I definitely "erred" to make the gaps be on the bottom. I have a little more PSR to do to the wings. At least I don't have to worry about raised panel lines anymore.
    October 2016
Posted by DasBeav on Thursday, December 13, 2018 1:41 PM
...And after a 5 month break from modelling, the Weekend Madness GB has pulled me from the modelling funk. I have finally started back to my "Jake" ssllooowww WIP. I got back to it last week but like others, I haven't been able to log on. I did a horrendous job of masking. Rushed through it because I really hate masking. Should turn out...meh...with a little help from Goo Gone. When I went to glue on the canopies I ran into a problem. Because I had cut out the pit tub and built my own, the glass had nothing to sit on. I had to add some little tabs which left some serious gaps. If anybody else builds this kit(DON'T DO IT) and replaces the pit, you'll have to make a little "shelf" around the tub for the canopy to rest. If that makes any sense. I got it primed, with Rustoleum Painters Touch in a spray can. Kind of like the stuff. Cheap and looks pretty nice. We'll see how good it is soon. Did a little preshading which turned out terrible. AB apparently was not cleaned out very good. But it's preshading and thankfully it doesn't have to be a work of art.
    October 2016
Posted by DasBeav on Thursday, January 3, 2019 10:31 AM
Slowly, finishing up this WIP. Almost done with the painting. I have a few touch-ups on the bottom because even with all the precautions there was some paint lifting on a rear flap. Must of missed a spot. The photo does not do justice to the pretty color VJMA Olive Green!!! Through all the trials and tribulations of putting this plane together, the dolly turned out great!!Big Smile
Posted by Gamera on Thursday, January 3, 2019 11:37 AM
Ohhhhhhh.......... love her!!! Looking forward to more.
    July 2004
Posted by stikpusher on Thursday, January 3, 2019 10:59 PM
Lighting... lighting... lighting...
i look forward to seeing the topside green more properly...
seriously though, it looks like you’re not too far from the finish line here!
       - Plankton
LSM
    October 2016
Posted by DasBeav on Friday, January 4, 2019 7:32 AM
stikpusher
Ooopsie. Sorry Stick. Took the picture quickly with the phone. Not an Annie Liebowitz or an Ansel Adams to begin with.(Only famous photographers I can think of)
Next ones will be better!
    July 2004
Posted by stikpusher on Friday, January 4, 2019 9:15 AM
Lol! No worries Beav. I’m just playing. How about Jimmy Olsen for a famous photographer?
Personally one one of my favorites was Robert Capa, but his best work was not composed at all. It just captured incredible moments.
       - Plankton
LSM
    October 2016
Posted by DasBeav on Friday, January 4, 2019 5:13 PM
stikpusher
I refuse to acknowledge a cub photographer of the Daily Planet as a "Famous Photographer".
Capa, Rosenthal, Bourke-White all had great photos. The back stories are as interesting as the pictures.
    October 2016
Posted by DasBeav on Thursday, January 10, 2019 1:05 PM
The Jake is finished!!! I left it pretty and shiny with very little weathering...and because I took the mask off the canopy. I refuse to re-mask just to put on Matt Varnish. And mainly because this Donkey deserves to look pretty and it was an ugly build.
All in all, I am happy the way it turned out. It is a "turrible" model and would love to see some other company make one. Actually, wouldn't mind another crack at this one again, knowing what to do and not to do.
Just one other thing I haven't metioned in the former posts. The folding wings will split if you put them down in the locked and loaded position. So if anybody decides to make this model in the future the folding mechanisms will need to be filed and sanded down.
    October 2016
Posted by DasBeav on Thursday, January 10, 2019 1:08 PM
Sorry, technical issue....Embarrassed
    October 2016
Posted by DasBeav on Thursday, January 10, 2019 1:11 PM
Where's the "Rising Sun" on the wings...Don't ask!!!
    October 2016
Posted by DasBeav on Thursday, January 10, 2019 1:13 PM
Why such crappy lighting? Don't ask!!!
    October 2016
Posted by DasBeav on Thursday, January 10, 2019 1:15 PM
Chipping effects courtesy of my VJ rust and chipping set...
    October 2016
Posted by DasBeav on Thursday, January 10, 2019 1:20 PM
It looks better in person...seriously. Trust meWink
    October 2016
Posted by DasBeav on Thursday, January 10, 2019 1:22 PM
Very little weathering on the bottom...just a few brush stroke of Tamiya "make-up".
    April 2010
Posted by redraider56 on Thursday, January 10, 2019 1:56 PM
Looks good!  Nice job finishing a tough kit.
-Matt
On The Bench: 1/48 HK B-17G "Man-O-War II"
On Deck: 1/48 Tamiya P-38H, 1/48 Revell PV-1
    September 2006
Posted by the Baron on Thursday, January 10, 2019 2:17 PM
You're building character along with this Jake, Beav Wink
I've got some Nichimo copies of Monogram kits, and the old Tamiya Pete biplane scout in 1/50.  I'm always amused to see the engineering choices these kits show.  On your Jake, I had to ask-why mold the front ends of the floats separately?  Why not just mold left and right halves for each one?  And how does the wing fold work?  It looks like you pull the wing out, and then fold it, and slide it back in, when the wing is deployed.
    July 2004
Posted by stikpusher on Thursday, January 10, 2019 2:52 PM
Yup, she’s fighting you... but you’re fighting back... and winning... I think there are a few folks here who would have thrown this into a one way flight by now.
Keep up the good work!
       - Plankton
LSM
    October 2016
Posted by DasBeav on Thursday, January 10, 2019 3:23 PM
redraider56
Thanks RR. With building Revellogram and other cheap kits, a well-fitting, easy kit might kill me.Smile
    October 2016
Posted by DasBeav on Thursday, January 10, 2019 3:36 PM
the Baron
Thanks, Baron.
I don't think character and my name have ever been used in the same sentence. Might be a first.
On the floats I think they were separate to load with weights. (I did, it's a tail-dragger). They might of mention it in the instructions but I really don't like to read.
The wings do fold and slide into the main part of the wing. The "tab" is thick and split my wing when I pushed it in to paint. That issue did not come up in pre-fit.
Which reminds me of another issue. You know those alignment pins inside the wing halfs, they were to long. When I glued the halves together with my Faller glue from Germany, which bonds really well, the pins melted through the wings. Never had that happen before.
    October 2016
Posted by DasBeav on Thursday, January 10, 2019 3:47 PM
stikpusher
Thank you, Stik!
It was perfect practice for a Mafia GB!
Like I mentioned earlier, if my small stash was not becoming medium-sized, I wouldn't mind having another crack at the Jake.
Posted by Gamera on Friday, January 11, 2019 11:25 AM
Oh wow, the finish looks good! And the canopy must have been a pain to mask.
Ack, about the other issues... I had assumed the wing joints slide up into the wings. That's crazy that the paint made them too thick to fit!
My hat's off to you for finishing her instead of flinging her into the wall...
    October 2016
Posted by DasBeav on Friday, January 11, 2019 12:31 PM
Gamera
Thanks, Gamera. The canopy wasn't that hard to mask, just a bunch of rectangles. I see why people buy AM masks,I just hate masking.
The joints didn't fit before I painted. After handpainting the joints, they definitly don't fit. VJ model air is not good for hand brushing.Smile
