Revell 1/48 F/A-18E Super Hornet
Posted by oortiz10 on Thursday, November 22, 2018 2:11 PM
Hey FSM,
Just thought I'd post some pictures of my latest 3-footer. This started as a subject for a group build, but I didn't get it done before the deadline. It's been sitting on my Shelf of Doom for longer than I care to admit. While paint and glue dried on a couple of other projects, I picked and pecked at this one until I got it finished. It's definitely not a contest winner, but it looks cool on my shelf.
I saw this picture online and knew immediately that I had to build this jet. The jet's plastic is straight out of the box. The decals are from Two Bobs. The loadout was collected from multiple boxes of Hasegawa ordnance. The bombs in the picture are modern Mk. 83s. Since I couldn't source a batch of those, I used the old Vietnam-era ones I had access to. I didn't change the fins (too much work), but I did modify the fuse a little. The thermal coating is textured spray paint. It's a bit too much for the scale, but I was going for representation not replication.
MM paints were used exclusively. This was the first time I tried the black-basing method. I like the effect, especially for modern USN schemes, and I may try it again. The kit was weathered with Flory washes and pastels.
Feel free to share your thoughts. Questions, comments, and criticisms are welcome.
Thanks for looking!
Cheers,
-O
-It's Omar, but they call me "O".
    November 2008
Posted by mrmike on Thursday, November 22, 2018 3:05 PM
Beautiful jet, O! You obviously took your time with the paint, and it shows. Happy Thanksgiving!
    September 2018
Posted by satiable on Thursday, November 22, 2018 4:22 PM
Wow amazing work! Details, weathering, everything.
Cheers!
Shawn
    May 2013
Posted by Greg on Thursday, November 22, 2018 7:17 PM
Looks good to me. Yes
    June 2017
Posted by UnwaryPaladin on Thursday, November 22, 2018 8:02 PM
Oh wow, that turned out very nice!
Posted by jeaton01 on Thursday, November 22, 2018 9:06 PM
Nice!
John
Posted by Don Stauffer on Saturday, November 24, 2018 6:51 AM
Looks great- love it!
Posted by keavdog on Saturday, November 24, 2018 9:12 AM
Really like the finish.  The mottling/weatheeong looks great.
Thanks,
John
    January 2015
Posted by TheMongoose on Saturday, December 1, 2018 7:47 AM
O this looks really great. Could you share some of the techniques you used when black basing to get the multiple shades within panels? For instance did you start with the base color and then spray a lightened and darkened shade in the same panel? I’m working on an F-18 now and hope to be practicing on some scrap panels next weekend before i try spraying it.
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
Posted by oortiz10 on Sunday, December 2, 2018 5:22 PM
TheMongoose, this was the first time I've ever tried black-basing or a modern USN scheme. First of all, thanks for the pat on the back. I was hoping that my "experiment" would capture the look of a deployed USN jet.
As far as what I did, it was pretty basic. First, I primed everything in black. (Duh.) Then, I sprayed the lower color, the lighter LGG, first. I thinned the MM enamels to about 50/50 with some laquer thinner. I sprayed it at a low pressure, about 15 psi, with my airbrush pretty close to the surface. The paint was sprayed in a random pattern and the goal was inconsistent coverage. I shot one panel at a time, in a completely random, almost "squiggly" pattern. If I wanted a darker, more mottled look, then the base color was sprayed more haphazardly and the coverage was more inconsistent. If I wanted a "greyer" look, then I made sure the coverage was more consistent and complete. The upper DGG surfaces were approached in the same fashion. Once I was happy with the overall coverage, then I sprayed some DGG "splotches" on the lower lower surfaces, and conversely, some LGG splotches on the upper surafaces. I didn't do any "lightening" of the base colors. It was all about coverage. Besides those two greys, I picked some random greys and shot them in random places and with random coverage to give that beat-up "touched-up" look to my airframe.
I avoided pre-shading the panel lines because, to my eye, I didn't see that "pattern" in reference pictures. If I had to do it again (and I will), I think I'll use thinner paint and a more random spraying to give the modern airframes a more "operational" look. The great thing that I noticed about this techinique is that, if you have to go back and fix any boo-boos, and/or do any spot touch-ups, all of that will add to the overall effect of the paint.
I know my explanation may not be totally clear or explanatory, but if you want to contact me, or  have other questions, please don't hesitate to reach out. I'll do my best to explain or describe my technique.
Cheers,
-O
    January 2015
Posted by TheMongoose on Sunday, December 2, 2018 9:25 PM
Thanks O! I think that will help me alot. Going to try it later this week or next weekend. Will drop you a pm with questions. It’s one of those things where I think I need to give it a go and then ask questions once ive got some experience.
    June 2017
Posted by Chemteacher on Sunday, December 2, 2018 9:51 PM
Hey, that looks awesome! Great job.
On the bench: Revell-USS Arizona; Airfix P-51D in 1/72
    May 2006
Posted by Shipwreck on Tuesday, December 4, 2018 6:23 AM
Oortiz10 thanks for your paint explanation. It was clear enough! That is a really fine job you did on that Revell F-18!
On the Bench:
Revell 1/96 USS Constitution - rigging
Kinetic 1/48 YF-104A 5-2957
Trumpeter 1/350 USS Hornet CV-8
Revell 1/48 B-1B Lancer Prep & Reasearch
