WIP: Is Maple Syrup A Finish Coat?
    September 2011
Posted by Tom Hering on Friday, June 14, 2019 10:21 AM
Canopies assembled and test fitted. The XF5U-1's canopy was a simple job. The V-173's windshield needed careful sanding on its bottom edge to make the whole unit of three pieces fit tight to the wing/fuselage. The V-shaped locating ridge behind the pilot's seat was sanded off first.
"A little more persistence, a little more effort, and what seemed hopeless failure may turn to glorious success" - Elbert Hubbard
"Perfect is the enemy of good" - attributed to Voltaire
Posted by Gamera on Friday, June 14, 2019 11:28 AM
Looking really good!!! Yes
Checked my old kit and it is the Sword version. Guess I've built enough Classic Airframes kits by now that I call every limited run model that brand...
    September 2011
Posted by Tom Hering on Friday, June 14, 2019 3:01 PM
Gamera
Thanks Gamera!
The Special Hobby V-173 Flying Pancake is labeled "Limited Edition."
    September 2011
Posted by Tom Hering on Tuesday, June 18, 2019 5:17 PM
Don Stauffer
Tom Hering
jeaton01
Look up Charles Zimmerman, the concept was his.
https://en.wikipedia.org/wiki/Charles_H._Zimmerman
The Flying Pancake was also known as "Zimmer's Skimmer." Here's something I just discovered yesterday: the plane that inspired Zimmerman, Cloyd Snyder's Arup S-2. It first flew in 1933, and was demonstrated around the country. (Zimmerman's V-173 flew from 1942 to 1947. The XF5U-1 never flew.) I'm no expert, but the S-2 appears to address the issue of tip vortices in its own way. Mr. Stauffer?
The Arup S-2 looks like something that Williams Bros. should produce a 1/48 kit of. It would look great next to their PCA-2 Autogiro.
Obviously there are no props at the tips to counter the vortices.  Winglets are the modern way to do it- the winglets are slightly canted outwards to create small vortices of their own to cancel the wing vortices.
If that tab-like thing on the tip were at a negative angle of attack, I could see how it might reduce wing vortices.  However, that view makes it look like the tabs are at a positive angle of attack, and hence strengthen the wing vortices. I assume those tabs take the place of ailerons.  I would think this low aspect flying wing would have very poor aero efficiency.  Looks like a lot of wing area, however, so landing and takeoff speeds may be quite low.
I noticed a patent drawing for an aircraft designed by Zimmerman, on page 3 of Ginter's book about the Pancakes. Dated 1938, it's an earlier aircraft design than the V-173, and it appears to owe a lot to Snyder's Arup S-2. Those tab-like things on the S-2 are also present on Zimmerman's 1938 design, and are designated by him as "floating wing-tip ailerons." Their function(s) is described in the patent. Here's the link:
http://www.freepatentsonline.com/2108093.html
    September 2011
Posted by Tom Hering on Wednesday, June 26, 2019 5:25 PM
Changing horses in midstream.
I originally planned to make the XF5U-1 a whiffer, and the Kitty Hawk kit provides parts and decals to do that. Then I decided that what I really wanted was a model of the plane that actually existed - prototype #2. But the kit doesn't give you this option, straight out of the box. You have to perform a few mods.
I removed the bomb racks I had already installed, and filled in the channels for the tail hook mechanism - located on top of the plane. The channels and covers for the tail hook mechanism don't appear in photos of the two prototypes (as far as I can tell), so it's likely the tail hook was never installed - though the Vought engineers had produced drawings of it.
The Kitty Hawk decal sheet doesn't provide tail markings for prototype #2 ("Navy, 33958, XF5U-1"). Propagteam used to offer a decal sheet for the KH kit, and it included the tail markings, but I'll be darned if I can find one anywhere. No luck, either, finding waterslide alphabets and numerals that will work (I've never had good results using dry transfers). And my graphics program doesn't have a typeface that's close enough (the "9s" and "5s" and "8s" are all way off) so I can't go the custom route. Hmmm ... interesting problem. Stay tuned.
Posted by Gamera on Thursday, June 27, 2019 1:19 PM
Oh gee, good luck with your modifications. Looks cool so far.
BTW: Have you checked the model railroad section of the hobby shop for the letters and numbers? You might also look in a regular craft store too.
    September 2011
Posted by Tom Hering on Thursday, June 27, 2019 10:08 PM
Gamera
Thanks Gamera. I think I'll be using the custom decal service from Bedlam Creations. All they require is a photo(s) of the real plane.
Posted by jeaton01 on Friday, June 28, 2019 12:34 AM
Here is another Arup with a different control configuration.
John
To see build logs for my models:  http://goldeneramodel.com/mymodels/mymodels.htm
Posted by jeaton01 on Friday, June 28, 2019 12:47 AM
It sure looks like Amarillo to me, here's a jpg.  I can send you a dxf file as well.
John
    September 2011
Posted by Tom Hering on Friday, June 28, 2019 5:31 AM
jeaton01
That's the Arup S-4, with the S-2 behind it. The Wikipedia article about the S-4 says the plane was scrapped during WWII, but then also says it went to a museum in Texas in the 1970s. ???
    September 2011
Posted by Tom Hering on Friday, June 28, 2019 5:34 AM
jeaton01
Thanks! I believe you're right. It looks like Amarillo to me as well, though the character spacing in "NAVY" is tighter in the photo below.
Posted by Gamera on Friday, June 28, 2019 7:46 AM
Sorry, guess I wasn't much help. Great to see that with John's help you're on the right track now though!
    September 2011
Posted by Tom Hering on Friday, June 28, 2019 12:19 PM
Gamera
You were indeed being helpful. Thanks!
Here's what needs to be done to turn the Kitty Hawk kit into prototype #2.
1. Don't use the tailhook, bombs, bomb racks, and armor glass provided in the kit.
2. Fill in the channels for the tailhook mechanism. (I did this with sheet styrene, but if I were to do it again, I'd use epoxy putty - though the added weight might make it necessary to use the metal landing gear set from Scale Aircraft Conversions).
3. Pose the exhaust flaps for engine cooling air (parts D15, D17, D24, D26) in the open position - the way they're most often seen in photos.
4. Replace the kit's thick, ribbed, landing gear canisters (parts C27) with thinner, plain, styrene rod.
5. Make a square headrest for the pilot's seat.
6. Make wheel bulges for the outer main gear doors.
7. Remove the ribbing on the rudders.
8. Fill in the six gun ports.
9. Use just one national insignia decal - on the upper port side.
10. Place the decals representing taped-on walk/work panels OVER the national insignia. (The kit instructions and box art show the panels UNDER the insignia!)
11. Place the oval logo decals on the front side of the port propeller, and the back side of the starboard propeller.
12. Create custom decals for the vertical fin and rudder markings, as well as the propeller tracking diamonds.
    September 2011
Posted by Tom Hering on Saturday, June 29, 2019 4:27 PM
Canopies painted. Three methods were used.
The V-173's canopy was done with a combination of masking/spraying and decal stripes. Paint is Testors 1214 and 1114 Gloss Yellow. The decal stripes are Print Scale CAMO-035. The yellow of the decals doesn't quite match the Testors paint, but I'm happy with the overall result.
The XF5U-1's canopy was hand painted with Model Master FS15042 Dark Sea Blue, and then cleaned up with a sharpened wood toothpick.
Both canopies were dipped in Future.
    September 2011
Posted by Tom Hering on Monday, July 1, 2019 3:45 PM
Gear for XF5U-1 prototype #2. The kit's brake fluid reservoirs have been replaced with styrene rod - detailed with decal stripes.
Headrest added. Onward to the propellers for both planes!
    September 2011
Posted by Tom Hering on Wednesday, July 3, 2019 2:49 PM
Since I'm building the XF5U-1 as the plane that actually existed, prototype #2 (BuNo 33958), I'm thinking I might include the feature in the photos below (it doesn't appear in all photos of prototype #2). I haven't been able to find any information about it, or any clearer photos, but my guess is that it's a pair of inverted extinguishers, plumbed to the engine compartments for fire supression during tests. Does anyone think this is a possibility? Has anyone seen something similar on other test aircraft of the period?
Posted by jeaton01 on Wednesday, July 3, 2019 6:25 PM
I have no idea what those fixtures might be.  As to the cylinders on the landing gear, usually a reservoir for the brake sysytem will be before the pistons that actuate the brakes.  I would bet those cylinders are related to the oleo struts instead.
Very nice paintwork on everything.
John
    May 2013
Posted by Greg on Wednesday, July 3, 2019 7:34 PM
Nice work on the canopy masking/painting!
Both are very nice, the yellow one is a knockout.
-Greg
    September 2011
Posted by Tom Hering on Wednesday, July 3, 2019 10:28 PM
Thanks John! I like your guess about the landing gear cylinders.
    September 2011
Posted by Tom Hering on Wednesday, July 3, 2019 10:30 PM
Thanks Greg!
Posted by Gamera on Thursday, July 4, 2019 7:31 AM
Sharp work on the landing gear and those canopies turned out great! Fantastic job on masking and painting them!
    September 2011
Posted by Tom Hering on Thursday, July 4, 2019 7:55 AM
Thanks Gamera! Actually, I did very little masking, and only on the yellow one. I'm kind of allergic to masking, but I think I'll have to get used to it if I'm going to build aircraft models. A skill that must be mastered.
Posted by Gamera on Thursday, July 4, 2019 8:02 AM
Ah ok, however you did them they look perfect! Wish I could brush paint that well.
    September 2011
Posted by Tom Hering on Thursday, July 4, 2019 1:38 PM
Gamera
Here's the tutorial I followed to hand paint the Dark Sea Blue canopy. It's an easy technique that doesn't require perfect neatness with a brush.
https://youtu.be/RH7qlFr7iVg
    September 2011
Posted by Tom Hering on Thursday, July 4, 2019 6:43 PM
Woodgrained all the prop blades today.
First coat is a dark yellow acrylic. Second coat is a thinned, burnt umber artist's oil paint - brushed on, then streaked with the cut edge of a sponge (packaging foam). I'll let these dry for a week, then apply a clear gloss coat, tinted to make the blades a little deeper and redder in color. After that, I'll paint cuffs, stripes, and tips. Then apply decals.
    April 2015
Posted by Mopar Madness on Thursday, July 4, 2019 6:53 PM
Looks like beautiful lacquered wood!
Chad
God, Family, Models...
At the plate: 1/144 Revell Snowberry
On deck: 1/48 Tamiya Fw 190A4
In the hole: 1/48 Hasegawa Fw 190A4
Posted by jeaton01 on Thursday, July 4, 2019 7:22 PM
Nice!
John
    September 2011
Posted by Tom Hering on Thursday, July 4, 2019 7:38 PM
Thanks Chad!
    September 2011
Posted by Tom Hering on Thursday, July 4, 2019 7:43 PM
Thanks John!
    September 2011
Posted by Tom Hering on Tuesday, July 9, 2019 5:33 AM
Primer is down on the V-173. Gunze Sangyo Mr. White Base 1000. A few minor flaws in seams were revealed, but that's par for the course.
