Revell 1/144 C-17A Globemaster - Progress
    March 2017
Posted by theflyingdutchman on Thursday, August 8, 2019 4:00 AM
This is the very first build that I have been working on quite a while now, but now all I have left is to put on the clear coat as well the decals after that
Also, I didn't realize till now that she was a tail sitter - so now it has to rest a paint bottle.
Any suggestions or words of advice will be much appreciated as I am trying to get better at this hobby!
Tags: C-17 , Revell , USAF
    March 2007
Posted by armornut on Thursday, August 8, 2019 4:14 AM
Nice looking build FD, thanks for the unfortunate heads up about adding "ballast" to the nose. To remedy the problem I try, if I remember, to add a few ounces of weight as far forward as I can, usually a few pennies, some steel shot, or best of all LEAD like fishing weights. Do use caution while handling lead though as some one said you will grow a third eye and another arm LOL.
    For your situation if your going to close the back ramp perhaps create a "pallet" of load out and push it almost all the way forward in the cargo bay. Just alittle forward of the main gear should do the trick.
    Nice build. Happy modeling.
we're modelers it's what we do
Posted by Tojo72 on Thursday, August 8, 2019 5:24 AM
Thats a very impressive bird,looks great so far.
Posted by Don Stauffer on Thursday, August 8, 2019 9:06 AM
Looking good so far!
Posted by keavdog on Thursday, August 8, 2019 10:58 AM
Cool.  Looks good.  Ah the tail sittters...  sometimes I'll make a stand from clear sprue.  How was the kit?
Thanks,
John
    March 2017
Posted by theflyingdutchman on Thursday, August 8, 2019 12:16 PM
keavdog
Keavdog- It looks like I will have to build a permanent stand for it as well. As for the build, it was fun and very straightforward, although I did have to use a fair amount of putty to fill the fuselage line and other gaps. The overall color I used for the aircraft was Tamiya XF-53 Neutral Gray.
    April 2015
Posted by Mopar Madness on Thursday, August 8, 2019 5:25 PM
I like it! Even in 1/144 scale it’s a big bird.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Ju87 B2 Stuka
On deck:
In the hole:
    August 2009
Posted by TREYZX10R on Thursday, August 8, 2019 6:14 PM
Thats impressive even in 1/144!  It looks really nice , if I may add a suggestion it could use just a touch more filler on the seam just aft of the nose wheel. Really sharp looking build!
    March 2015
Posted by JohnnyK on Thursday, August 8, 2019 7:44 PM
This is what I do regarding weights. On the inside of the fuselage up at the nose I use a fat magic marker and write "WEIGHTS" on both sides of the fuselage. That way I don't forget the weights.
    November 2003
Posted by mississippivol on Thursday, August 8, 2019 7:56 PM
I built mine with the ramp down, it never occurred to me to add weight.
    August 2016
Posted by Keyda81 on Sunday, August 11, 2019 8:03 AM
keavdog
I've built this kit twice.  Once when I first started building, and again after that to replace the first one, lol.  It's not a kit for beginners if you ask me.  Some things are difficult to line up, getting the fuse closed can also be a challenge.  The assembely of the landing gear can also be a bit tricky.  Filler and sanding is a requirement as well.  If you put the time into it can come out looking nice.
Nice job on yours so far dutchman!
