1/48 Eduard P-51D 55th FG “The Millie” (Finished)
    February 2012
Posted by lawdog114 on Thursday, September 26, 2019 12:20 AM
Josh_the_painter
lawdog114
Josh_the_painter
Your quality of work constantly astounds me Lawdog. And the kit is great.
The first kit I ever built was a P51D big beautiful doll and after the curret builds it's something I want to revisit so this would be a perfect kit. Thanks for the opportunity to watch yours come together.
Josh
Thanks Josh.  You'll definitely want to revisit Doll with this kit.
Im in my shed supposed to be prepping 38 buick parts for paint but instead I find myself pulling the trigger on 2 of these through hobbylink japan. Your a bad influence lawdog!
Nice work on the checkers. I was interested in the tamiya tape? It looks like a rice paper tape in the photo? Generally I just mask with vinyl tape/ fine line as I have rolls of it sitting around and am no stranger to having to achieve fine masking. I like to stay open minded however for products that I can use for work as well.
Josh
Indeed, I'm a bad influence.  I have the early version pre-ordered as well.  It will hit my bench immediately as well.
Tamiya tape is wonderful.
    February 2012
Posted by lawdog114 on Thursday, September 26, 2019 12:21 AM
TREYZX10R
Joe great looking office as always! Nice clean masking on those nose checkers too!
Thanks Trey
    February 2012
Posted by lawdog114 on Thursday, September 26, 2019 1:07 AM
I left off at the checkered nose.  I taped that area off then got to the quite interesting scheme.  The Millie G, as with most 55 FG D model Mustangs, had a green or olive drab fuselage and the rest was NMF.  I found this page in the instructions which shows the areas that were sprayed alumnum lacquer, which I found interesting.  I used Extreme Metal Dark Aluminum for this. This stuff sprays nice and smooth but I apparently forgot how long it takes to dry.  I waited about a half hour and taped it off to spray other areas.  Big mistake. The Tamiya tape stuck to it and left residue.  I had to sand it off and start over.  I was pissed.  I think I'll stick with Alclad for stuff that requires taping.
I painted the rest according to my reference.  I started with the lower fuselage invasion stripes then moved to the fuselage stars and bars.  I used Montex for these.  Next I added the wing insignias.  I had no issues and the Montec performed perfect.   Again, we don't need no stinkin' decals (yet).
I decided on Olive Drab, mostly because I just got the AK Real Colors Olive Drab 41.  Its the best I've seen thus far, better than Gunze. Perfect shade of brownish green and sprays like a dream.  Barracuda Decals provided the markings for Millie.  They showed that this plane had a red stripe that separates the NMF with the drab on the fuselage in a gradual curve....fun!. Fortunately they provided decals for this feature, yellow and red.  Since I would be using the red, I carefully cut out the yellow ones and used them for reference on getting the curve right.  I used Tamiya flexible (white) tape to it tape it off before I sprayed the OD.  It worked great.
I added the flaps.  I painted in the red no step warning.  The instructions showed it only went on the port side.
I gave everything a postshade to dirty it up a bit.
I gave it a coat of X-22 mixed with Mr. Leveling Thinner.  Once dry, I added the needed decals for Millie G.  I had no issues.  Barracuda decals are always fantastic.
The prop hub yellow stripe came from an old 357th FG Eagle Strike sheet. Again, I cannot paint these on for the life of me.  They always come out lopsided.
I hope to be wrapping this turkey up soon.
    September 2012
Posted by GMorrison on Thursday, September 26, 2019 1:14 AM
That has to be the nicest Pony to come along in a long time.
    February 2012
Posted by lawdog114 on Thursday, September 26, 2019 1:29 AM
GMorrison
Thanks G
    January 2017
Posted by damouav on Thursday, September 26, 2019 3:33 AM
How did I not see this build early... another sensational build.
Well done that man, well done.
In Progress
1/48 Tamiya P47-D Bubbletop
1/48 Hobby Boss TBF-1C Avenger (on hold)
Pending
1/48 Roden S.E.5a
1/48 Airfix Walrus
    February 2012
Posted by lawdog114 on Thursday, September 26, 2019 4:42 AM
damouav
Thanks Damian
    July 2019
Posted by Hoss WA on Thursday, September 26, 2019 10:57 AM
Sensational! That’s inspirational work on a really cool scheme.
    April 2015
Posted by Mopar Madness on Thursday, September 26, 2019 11:35 AM
I still haven't created anything with a metallic finish but I will definitely use this one as my template!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    March 2015
Posted by JohnnyK on Thursday, September 26, 2019 2:36 PM
Great  looking paint job. I love the cockpit.
    August 2009
Posted by TREYZX10R on Thursday, September 26, 2019 3:13 PM
Paint work is super crisp and clean as always ! I have trouble getting the pointed bits painted and not being lopsided ,but found this helpful the last time I had to do one
    February 2012
Posted by lawdog114 on Thursday, September 26, 2019 10:02 PM
Hoss WA
Thanks Hoss
    February 2012
Posted by lawdog114 on Thursday, September 26, 2019 10:04 PM
Mopar Madness
Use Alclad.  Alot less aggravation.....
    February 2012
JohnnyK
Thanks Johnny
    February 2012
Posted by lawdog114 on Thursday, September 26, 2019 10:07 PM
TREYZX10R
This is genius Trey! I'm not sure why I never thought of this.  So you basically cut the appropriate circle out of the template so its smaller and easier to work with?  Thank you nery much bud!
Posted by keavdog on Thursday, September 26, 2019 10:32 PM
Looks great so far.  On the home streatch.   Too bad about to fit issues.  I have seen a lot of these around the web.
Thanks,
John
    February 2012
Posted by lawdog114 on Friday, September 27, 2019 12:24 AM
keavdog
Thanks.  I'm pretty sure most were my own doing though
    June 2014
Posted by BrandonK on Friday, September 27, 2019 9:49 AM
Beautiful work, Joe. This scheme and Big Beautiful Doll are the best looking Mustangs, impo, off all time. Super good looking build.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    February 2012
Posted by lawdog114 on Tuesday, October 1, 2019 10:32 PM
BrandonK
BK
Thanks Brandon.  Like I said, the scheme has certainly grown on me.
    February 2012
Posted by lawdog114 on Sunday, October 6, 2019 12:47 AM
I went ahead and got this turkey done.  To recap, it's the new Eduard P-51D in the 55th FG markings of Eduard Giller's "The Millie G".  Giller scored three kills with one being an Me 262.  Aside from the markings, it's built out of the box. I used AK Extreme Metals for the NMF and AK Real Colors for the drab. Main markings are Montex masks. I did plumb the drop tanks and gear legs.
I said I would compare it to the others.  Truthfully, there is no comparison. Eduard did a nice job on this turkey. It's definitely the best in 1/48.  I had a few issues, but I'm pretty sure they were my own ineptness.  My only gripes are the missing Dzus fasteners along the top cowl and the drop tank installation. The tanks don't seem to fit onto the pylons and you have to use these crappy PE strip pieces that simulate the anchors. After I lost two of them I gave up. I ended up just gluing them to the pylon.
Thats about all I can think of.  I have the filletless D-5 version coming and will also be building that immediately, mostly because I wanna see if he issues I had were my own doing.
    February 2005
Posted by RadMax8 on Sunday, October 6, 2019 1:36 AM
Looks pretty good to me, buddy! Can’t wait to get my greasy little mitts on one of these. You’ve set the bar very high.
    February 2013
Posted by tomwatkins45 on Sunday, October 6, 2019 7:46 AM
Beautiful, as always. I continue to be amazed at both the quantity of your output and the quality of your work. I learn something from each of your builds.
Thanks,
Tom
    May 2013
Posted by Greg on Sunday, October 6, 2019 10:09 AM
RadMax8
Well said, hard to say it better.
Beautiful Mustang, Joe. You did great. YesYesYes
    April 2015
Posted by Mopar Madness on Sunday, October 6, 2019 10:51 AM
Beautiful work as always LD!
Chad
On deck: Who knows!
    June 2014
Posted by BrandonK on Sunday, October 6, 2019 11:28 AM
I echo the above statements. Looks like just the right amount of weathering for theater use. Very nice.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
    March 2013
Posted by patrick206 on Sunday, October 6, 2019 12:48 PM
Hi, Joe - Once again, thanks for showing us what a completed model should look like. Very realistic, looks like a war horse that has seen some action, but still well cared for by the crew. A beauty.
Patrick
    August 2019
Posted by Josh_the_painter on Monday, October 7, 2019 12:23 AM
Just speechless really. Im so impressed by this and if I manage half the quality on my own I will be happy. Your weathering, as usual, really nails it to give that illusion of realism.
My 2 kits arrived today from hobbylink. I just need to get the doll decals on their way. Im not sure how available to me the AK colours will be however are they your suggestion for the NMF and aluminium lacquer?
Josh
    February 2012
Posted by lawdog114 on Monday, October 7, 2019 12:42 AM
RadMax8
Thanks Max
    February 2012
Posted by lawdog114 on Monday, October 7, 2019 12:44 AM
tomwatkins45
Thanks,
Tom
Thanks Tom
    February 2012
Posted by lawdog114 on Monday, October 7, 2019 12:45 AM
Greg
RadMax8
Thanks Greg
