Airfix 1/72nd Gloster Gladiator Mk II Completed
Posted by Bish on Monday, November 4, 2019 2:18 PM
Thanks guys. baron, it is, its a great kit.
''I am a Norfolk man and i glory in being so''
On the bench: Academy 1/35th Warrior FV511
    July 2019
Posted by Hoss WA on Monday, November 4, 2019 5:06 PM
Very cool!  Nice job.
Posted by Bish on Tuesday, November 5, 2019 2:03 AM
Thanks Hoss.
    February 2007
Posted by Buckeye on Tuesday, November 5, 2019 9:11 AM
One fine build!  The rigging is amazing in that scale!  How did you do it?  Pre-drill holes for the ends then shrink the line?
Nice presentation too.Cool
Posted by Bish on Tuesday, November 5, 2019 9:15 AM
Thanks Mike.
I just partly drilled holes in the upper wing and then drilled right throw the lower. Inserted the line through the lower hole and secured it in the upper wing and let dry. Then stretched it night and glued the other end. Useing CA i only needed to leave each bit to dry for 10 mins, but took a couple of evenings.
    May 2013
Posted by Greg on Tuesday, November 5, 2019 9:19 AM
Outstanding, Bish! YesYesYes
I've never done a biplane but dogone it, this one has my attention. And I agree, it does have a more rugged and capable look than a lot of bipes I've seen.
Not sure how I missed this.
-Greg
    June 2014
Posted by BrandonK on Tuesday, November 5, 2019 9:30 AM
Excellent work, Bish. You make the scale look lifelike. I totally jellous.
BK
On the bench: Alot !
On Deck: Alot more !
Posted by Bish on Tuesday, November 5, 2019 1:47 PM
Cheers guys.
This has made me less concerned about rigging, i was worried about it, but was much easier than i had expected. The plan Airfix provides really helped.
    January 2015
Posted by PFJN on Tuesday, November 5, 2019 1:52 PM
Bish
Thanks Mike.
Hi,
Your build looks great.  Thanks for posting your info.
I have a couple older A/C models (a Vickers Vimy Commercial and a Curtiss Condor) that I have been putting off for a while until I figured out how to address the rigging.  I will definitely give the method you noted above a look.
Pat
1st Group BuildSP
Posted by Bish on Tuesday, November 5, 2019 1:55 PM
Thanks Pat. I hope it works for you and look forward to seeing the results.
    February 2007
Posted by Buckeye on Tuesday, November 5, 2019 2:41 PM
Bish
Thanks for the info!  Have always been a little intimidated by a biplanes rigging.
Posted by Bish on Tuesday, November 5, 2019 3:05 PM
Me to Mike.
    June 2017
Posted by UnwaryPaladin on Tuesday, November 5, 2019 4:05 PM
Looks fantastic! The rigging turned out really nice. Your bases and figures always add that "spark" of life to your models
    August 2009
Posted by TREYZX10R on Wednesday, November 6, 2019 4:46 PM
Wow You are cranking out the quality builds Bish! Very nicely done Sir!
Posted by Bish on Thursday, November 7, 2019 3:07 AM
Thanks guys.
    November 2010
Posted by Eagle90 on Thursday, November 7, 2019 5:54 AM
WOW!  I really like the build!  The base is awesome as usual, but there is just something about this build...it pops!  The pilot maybe, but again..brilliant build my friend!
Posted by Bish on Thursday, November 7, 2019 6:18 AM
Cheers buddy.
