Now for an update. One of the things I've really considered was learning to create a 3d model, print it, and include it with this model. I realize that this will not be easy but I will attempt it. Toward that end I include this post as I attempt to model the inside of the Sperry Ball Turret. I started by learning about different 3d software available for someone like me at little to no cost. I came up with two, one called Blender, the other called FreeCad.
In my investigations with Blender, I have found that it is a great program but has more options than you can shake a stick at. I will learn it in time but it's a bit overkill for what I'm trying to do at the moment. Now I come to the free program called FreeCAD. This seems to be a free version of AutoCAD and is more used for mechanical type of drawings. That fits more in the area of what I'm trying to do at the moment. YouTube is great for tutorials. I found this one very helpful...
https://youtu.be/3eWlU2Ddl6I
FreeCAD seems to be just what I need to do the mechanical drawing of the inside of this ball turret. Now to get some key measurements of the space I want to fit this in. One of the parts from this kit is the pair of guns that are attached together for this assembly. I can use this as a means of a standard for the rest of the drawing.
First for my model references. These are photos I've gleaned from around the world wide web showing the interior of the ball.
As you can see there are a couple of differences between them but they are relatively the same design.
I could show both guns mounted or, like this last picture, show only one gun and what the seating arrangement looked like. I don't plan to show any crew. Any wiring would have to be scratch built.
Now for the important measurements I need to work with.
Using a caliper, the measurements I get to work with are these:
Inside the ball along the Z axis is .85" or 21.63mm
Inside along the X axis is .77" or 19.56mm
Inside along the Y axis is .47" or 11.94mm. This is from center plain to the front window.
Distance between gun openings is .46" or 11.61mm
Length of the gun receivers is .486" or 12.34mm
Width between gun receivers as originally modeled is .458" or 11.63mm
Height of gun receivers as originally modeled is .127" or 3.22mm
I've spent the last several days working with my printer. Mostly getting it set up properly with the latest firmware and getting the platen adjusted properly and zeroed. I also have learned a few tricks for longer FEP life and habits to form for producing good prints often.
To start with, here is what I'm working with. I'm using the Anycubic Photon S
Technical Specifications:
● Printing Technology: LCD-based SLA 3D Printer
● Light-source : UV integrated light(wavelength 405nm)
● XY DPI : 47um (2560*1440)
● Y axis resolution : 1.25um
● Layer resolution : 25 ~ 100um
● Printing speed : 20mm/h
● Rated Power : 50W
● Printer size: 230mm*200mm*400mm
● Printing volume : 115mm *65mm *165mm (4.52″*2.56″*6.1″)
● Printing material : 405nm photosensitive resin
● Connectivity :USB Port
● Package Weight: 9.5kg
They have two types of resin, both are sensitive to 405nm. One is regular resin which has a nasty smell to it which is why you want to work in a well ventilated area. The other is plant based and the smell is not so strong... Of the first type there are other resins within that have different properties like clear or opaque in different colors as well as a different hardness.
In my studies I have developed rules of thumb to follow when using this printer.
1. Always shake well the resin you are about to use to ensure it is completely mixed. Apparently it settles when left on a shelf for any length of time.
2. Always store resin bottle in a cool dark area. This prolongs the use / shelf life of the resin because they do come with expiration dates.
3. Isopropyl Alcohol used for cleaning up must be 90 to 99% proof.
4. Its a good idea to wear protective glasses as well as a face mask, (same type we all have to wear now with the China Virus). You really don't want to get that resin in your eyes from any splashing that may occur.
5. Periodically relevel the print plate to better ensure a good print.
6. Check your UV lighted print screen before each print to ensure there are not any unlit areas.
7. Don't always print in the same place. It would wear out the FEP film on the bottom of the vat faster.
8. Put three drops of PTFE lubricant onto the FEP film and spread around with a very soft brush. It's ok if it beads, the protection is still there and this will also help increase the life of the FEP film.
9. Clean the resin vat between prints and keep it clean when not in use. Some people leave resin in the vat over night and while this in itself won't harm it, being lazy will eventually cause problems.
10. If you are going to use different kinds of resin, it would be a good idea to have more than one vat to prevent cross contamination.
11. Use a glass scraper to remove resin from the glass print screen surface. But be very careful about it.
12. Use trays to hold equipment to contamination.
13. If possible, put a slight bevel on mount surface of the print so that it would be easier to pop the print off the plate with done.
14. Use, if you can, micro fiber cleaning clothes to clean the FEP film. Cotton and paper will scratch the screen and cause problems later.
Last night I printed my first practice piece while following all my rules of thumb and the print came out perfectly the first time. I used my paint booth to help blow the fumes out and kept the room cool. The smell wasn't that bad when I did that.
I also learned that if I add supports to my STL file in the Chitubox slicer program and save it as an STL, I don't have to use the Photon program to do the same thing. Just save the altered STL file in the Photon as a PW file, while not changing anything, and the printer will work with it.
I also figured out that if I look at my 3d picture upside down and slowly go up with a piece of paper, I can figure out quicker where I need to add supports as nothing should float in free space.
Here are pictures of my first print.
I should mention that there is not direct line from the computer to the printer. Files are loaded on a thumb drive and plugged into the side as you see in the picture above.
I put the print into an ultrasonic cleaner filled with alcohol. Cleaned it really well.
Thanks for following.
