1/32 Tamiya Mosquito FB Mk. VI, 235 Sqdn, Overlord (Complete)
    August 2015
Posted by crown r n7 on Wednesday, December 23, 2020 10:05 AM
Beautiful work on those little details does that kit have removable access panels held with magnets ?
 Nick.
    June 2018
Posted by DRUMS01 on Wednesday, December 23, 2020 11:27 AM
You are presenting an exceptional build with great modeling skills and photos.
Keep up the wonderful work....
Ben
"Everyones the normal until you get to know them" (Unknown)
LAST COMPLETED:
1/35 Churchill Mk IV AVRE with bridge - DONE
NEXT PROJECT:
1/35 CH-54A Tarhe Helicopter
    February 2012
Posted by lawdog114 on Saturday, December 26, 2020 1:18 AM
Incredible work Hoss.  Work of art.  It's my understanding you use Flory for your washes.  It's quite convincing.
    November 2003
Posted by tempestjohnny on Saturday, December 26, 2020 3:36 AM
Absolute museum quality work
    July 2019
Posted by Hoss WA on Monday, December 28, 2020 4:24 PM
crown r n7
Thanks Crown. Yes, the kit has removeable panels for the engines and the nose MG's. The fit is pretty good. I'm painting the panels separately to avoid paint getting in the gaps between the panels since I have one of the engines detailed.
    July 2019
DRUMS01
Ben
Thanks Ben. I'm making slow progress.
    July 2019
Posted by Hoss WA on Monday, December 28, 2020 4:26 PM
lawdog114
Thanks Lawdog. Very much appreciated. Yes, I'm pretty happy with Flory washes -- so much so that I'm haven't found a reason to try anything else at this point.
    July 2019
Posted by Hoss WA on Monday, December 28, 2020 4:27 PM
tempestjohnny
Thanks Tempest. Much appreciated.
    July 2019
Posted by Hoss WA on Monday, December 28, 2020 4:37 PM
The main painting and large markings are now complete. All the paints for this stage were MRP.
I tried a different sequence for the stripes, masks and main painting. I started with MRP primer, which worked fine. Then I painted the white areas for the invasion stripes and markings. The markings were next using Maketar masks, which have worked well so far. After masking the markings and the white stripes, I painted the black stripes and masked them.
Sky on the underside was next followed by Extra Dark Sea Grey on the top, including all the miles of masking tape used for this big bird. I faded and shaded the main colors to show some variation across the large surfaces and left the metal panels slightly lighter than the wood surfaces for a little subtle contrast.
After removing the masks I found the inevitable touch up areas, including a couple of spots on the fin flash where the paint lifted when the masks were removed.
Minor markings and weathering are next.
    January 2014
Posted by KrisYYC on Tuesday, December 29, 2020 9:50 PM
Amazing detail and realism!
    July 2019
Posted by Hoss WA on Wednesday, December 30, 2020 8:09 PM
KrisYYC
Thanks Kris.
    July 2019
Posted by Hoss WA on Wednesday, January 6, 2021 8:43 AM
Happy New Year! The Mossie is now complete. Since the last update, stencils were applied to the non-invasion stripe areas, weathering to the exterior was applied and the landing gear, doors and various doodads were attached. The canopy was also cleaned up.
The kit decals were used for the stencils and they worked well. Maketar included the crosses on the wing radiators in their mask set so I used those instead of the decals to avoid dealing with the large film area. The masks actually worked perfectly. I only applied gloss clear to areas receiving the decals.
For the panel lines, I used a fine pencil for the underside and heavily thinned Tamiya X-18 black as a pin wash for the topside. Panel lines are sparse on the wooden wonder.
A thinned Tamiya Red Brown and Flat Black mix was airbrushed onto panel lines and in the engine and exhaust areas.  Photos show major exhaust grubbiness and I tried to replicate the effect. The engine areas received an extra treatment of oil and exhaust stains by brush. Chipping and scratches on metal areas were applied with colored pencils. Alclad Matte was the final flat coat.
As for final thoughts on the Mosquito, it's an impressive plane and looks great in the Coastal Command livery. Speed, firepower and payload are certainly on display when looking at the completed beast.
Regarding the kit, Tamiya simply did a fantastic job. Everything is out of the box except a few decals and the masks for the markings. The engineering of the various assemblies is thoughtful and precise. One weak area in my view is that the fit of the snap-on and magnetic engine covers is a bit sketchy. I was not able to get them perfectly oriented without them falling off or shifting position. You'll see some gaps in the photos. It's not an issue of course for those that want to display both engines.
It's definitely the best engineered and most-detailed kit I've attempted and I'm very happy with how it came out. It was by far the longest build I've done and I'm ready to return to 1/48 scale for a while.
Enjoy the photos!
    January 2015
Posted by TheMongoose on Wednesday, January 6, 2021 11:03 AM
Hass, Wow that looks just sublime! The paint tones and variation in combo with the weathering make a great show piece!
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
Posted by jeaton01 on Wednesday, January 6, 2021 11:07 AM
Simply Gorgeous!
John
    November 2020
Posted by Buckeye2 on Wednesday, January 6, 2021 11:15 AM
You did a superb job with an awesome kit!  Outstanding!Bow Down
    March 2013
Posted by patrick206 on Thursday, January 7, 2021 1:05 PM
Well, Hoss, that's just among the best examples of fine craftsmanship I've seen here at FSM. A truly excellent build, I spent quite a long time over the length of the project, just enjoying watching your efforts proceed and then turn this beauty out.
Very well done, thanks for the posts, details and photos.
Patrick
    August 2015
Posted by crown r n7 on Thursday, January 7, 2021 1:54 PM
fantastic job, that build must have some heft to it.
 Nick.
    July 2019
Posted by Hoss WA on Friday, January 8, 2021 9:02 PM
TheMongoose
Thanks Mongoose. I put quite a bit of time into fading and shading during the main painting steps as well as weathering. I tried a few new techniques -- one being adding light and dark areas with sponges -- to add some variation to the color and texture. I also sanded and buffed each layer of paint to a smooth finish before applying the next layer. I also did not apply a general gloss coat over the entire airframe, which kept the paint layers to a minimum. I'm happy with the way it came out.
    July 2019
Posted by Hoss WA on Friday, January 8, 2021 9:03 PM
jeaton01
Simply Gorgeous!
Thanks John
    May 2006
Posted by Shipwreck on Saturday, January 9, 2021 12:51 PM
Hoss WA, that is really a fine job you did on that bug. When I look at your photos the only things that might be a bit off are the invasion stripes. The grays are very well modulated, but the whites and blacks of the stripes look like they were just painted a hour ago! I might have to give you an A instead of an A+. Thanks for sharing.
On the Bench:
Revell 1/96 USS Constitution - rigging
Kinetic 1/48 YF-104A 5+2957
Trumpeter 1/350 USS Hornet CV-8
Revell 1/48 B-1B Lancer Prep & Reasearch
Posted by keavdog on Saturday, January 9, 2021 12:57 PM
Magnificent!  Love the engine detail.
Thanks,
John
    January 2015
Posted by Aggieman on Saturday, January 9, 2021 1:54 PM
That is fantastic work.  Your paint job is top notch, as is the weathering.
    April 2015
Posted by Mopar Madness on Saturday, January 9, 2021 2:14 PM
Wow that is seriously nice!
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    July 2019
Posted by Hoss WA on Saturday, January 9, 2021 8:44 PM
patrick206
Patrick
Patrick, Thanks for the comments. Very much appreciated. This was a fun project and I'm glad you liked the updates and finish. Thanks again.
    July 2019
Buckeye2
Thanks Mike
    July 2019
Posted by Hoss WA on Saturday, January 9, 2021 8:47 PM
crown r n7
Thanks crown. Yes, it has so much heft I don't have a good place to display it. Tamiya actually did a great job -- the wings are held together with screws and the landing gear is very robust.
    July 2019
Posted by Hoss WA on Saturday, January 9, 2021 8:55 PM
Shipwreck
Thanks shipwreck. I intentionally avoided weathering the invasion stripes since they would be newer than the rest of the camo. However, I agree with your point. I should have made them a little more organic. Without at least some basic weathering they are too stark. Also, for my next invasion stripes build I'm going to paint the stripes on after the camo instead of before as I did on this one. That would help give a more painted on vs a factory look.  Thanks for the feedback.
    July 2019
Posted by Hoss WA on Saturday, January 9, 2021 8:57 PM
keavdog
Thanks keavdog!
    July 2019
Aggieman
Thanks Aggieman
    July 2019
Posted by Hoss WA on Saturday, January 9, 2021 8:58 PM
Mopar Madness
Thanks Mopar.
