Recommendations for 1/72 Intruder kit
    March 2017
Posted by glenva on Wednesday, December 30, 2020 2:30 PM
Anyone got a recommendation?  Best I can tell the only choices are Italeri and Hasegawa.  Very familiar with other Hasegawa kits, but haven't done an Italeri yet.
    May 2009
Posted by Pawel on Wednesday, December 30, 2020 3:14 PM
Hello!
In any case, check out scalemates.com
Now in 1/72 I know Hasegawa is a very old model with poor detail - looking at the instructions it should be avoided.
But there's also the Fujimi kit - I'd recommend it if you can get it, but that's probably not so easy.
Good luck with your modelling projects and have a nice day
Paweł
www.vietnam.net.pl
Posted by gregbale on Wednesday, December 30, 2020 4:15 PM
Pawel
Enthusiastic ditto to the exquisite Fujimi kit if you can possibly find it. An absolutely splendid bit of the moldmaker's art.
Greg
George Lewis:
    March 2017
Posted by glenva on Wednesday, December 30, 2020 4:25 PM
Pawel
Hello!
Paweł
Pawel
Hello!
Paweł
Pawel
p
[quote user="Pawel"]
Hello!
Paweł
Thanks, will look for  it....
    March 2008
Posted by mic53mlb on Wednesday, December 30, 2020 4:26 PM
FYI there are several 1/72 Fujimi Intruders on Ebay for less than $30.00, hope this helps
    March 2017
Posted by glenva on Wednesday, December 30, 2020 5:56 PM
Thanks.  Will check Ebay.
    November 2008
Posted by Justinryan215 on Thursday, December 31, 2020 6:26 AM
There is also a Revell kit  available out there, but it is pretty much the same kit as the Hasegawa kit.  BUT, It can be built up to a nice looking display with just a little "elbow grease...
"...failure to do anything because someone else can do better makes us rather dull and lazy..."
Mortal as I am,I know that I am born for a day.  But when I follow at my pleasure the serried multitude of the stars in their circular course, my feet no longer touch the Earth...
    August 2013
Posted by Straycat1911 on Saturday, January 2, 2021 6:31 AM
I've built the Hasegawa and the Italeri; my preference is the Italeri for its better detail and engraved panel lines.
Fit could be better but there's no perfect kit.
    May 2004
Posted by cbaltrin on Saturday, January 2, 2021 7:27 AM
I have several Fujimi A-6 variants in the stash. They look fabulous in the box.
On the Bench: Too Much
    January 2007
Posted by PaulBoyer on Saturday, January 2, 2021 10:12 AM
One quick note about the Fujimi kits. They feature separate leading-edge flaps that you can pose in the dropped position. On the real Intruders, these leading-edge devices work in conjunction with the trailing edge flaps, so when the LE are down, the TE are down. The kit does NOT provide separate trailing-edge flaps, so you'd have to do extensive surgery and some extra detailing to drop them. So, to be accurate, install the LE flaps UP.
