Revell 1/32 P-51D-5NA Mustang - Work in progress
    September 2019
Posted by Nikola on Wednesday, September 22, 2021 2:43 AM
Hi gents,
Very slow progress on this one (as I promised). :)
Nothing special done but I just wanted to share a small tip about tackling a slight canopy misalignment with those who are yet to build this one. I am generally not happy with the quality of the clear parts. Among some other issues, the windshield is slightly deformed meaning that it is slightly narrower that the fuselage and shorter by a millimetre. The bubble canopy has deformations within the ''plexiglass'' part (I will post some pics later).
I couldn't avoid the gap between the windshield and the cowling but regarding the joint with the fuselage luckily there is a way to keep filling and sanding to a minimum as there is space to insert a piece of toothpick fixed with CA which will not be seen later and keep the windshield at the proper width until glued to the canopy:
            www.shelfforce.com
    January 2015
Posted by TheMongoose on Wednesday, September 22, 2021 9:27 AM
Cool tip, that looks perfect.
In the pattern: Scale Shipyard's 1/48 Balao Class Sub! leaning out the list...NOT! Ha, added to it again - Viper MkVii, 1/32 THUD & F-15J plus a weekend madness build!
    February 2012
Posted by Modell Aircraft Photography on Wednesday, September 22, 2021 11:12 AM
Hio Guys, concerning Model Photographie.... Please look at my Models in the Air. Model Aircraft Photos by Heinz Johannsen. Most 1/32 and 1/48 and 1/24. If you would like to get infos How I did it, come back to me  Get more out of your Models !!! Make them look real !! Put them in the Air !  stay healthy   Heinz Johannsen
    February 2012
Posted by Modell Aircraft Photography on Wednesday, September 22, 2021 11:15 AM
Hio Guys, concerning Model Photographie.... Please look at my Models in the Air. Model Aircraft Photos by Heinz Johannsen. Most 1/32 and 1/48 and 1/24. If you would like to get infos How I did it, come back to me  Get more out of your Models !!! Make them look real !! Put them in the Air !  stay healthy   Heinz Johannsen Look at Galleries Nr. 5--7--8--13--43--28--38--48--62--63--67--73--77-- on Readers Gallerie.Thanks for reading
    September 2019
Posted by Nikola on Friday, October 1, 2021 9:10 AM
She is finally ready for priming! :)
I had to do some windshield-cowling gap filling, and panel line and tire threads re-scribing, added some rivets where I thought appropriate...
I will go with white Tamiya Liquid Primer or white Mr. Finishing Surfacer 1500, followed by desert yellow shades, my complementary pre-shading using various reds and aluminium where appropriate for future chipping. Then goes the OD base coat. I chose to go with white primer since it will require less coats to achieve good OD coverage without it looking too dark.
Best,
Nikola
            www.shelfforce.com
    January 2015
Posted by TheMongoose on Friday, October 1, 2021 12:23 PM
Looks like you blended that canopy in really nice! Definitely on the way to being a beautiful Mustang
    September 2019
Posted by Nikola on Saturday, October 2, 2021 1:24 PM
Hi gents,
White primer and complementary pre-shading done :)
            www.shelfforce.com
    September 2019
Posted by Nikola on Saturday, October 9, 2021 4:29 AM
Well, here is some contradictory information for you:
The painting instructions say that the checkered pattern only goes to the front end of the exhaust stack:
The decal disagrees since it has a cutout to go around the stack past the front end of it:
And if I see it correctly the truth is somewhere in the middle as the pattern only slightly goes past the stack front end:
So, I painted the nose yellow and will either bite the bullet and paint the damn thing or cut out only the red squares of the decal and apply them to the painted yellow (this should make the decal easier to conform to the shape as well. I'll see.
            www.shelfforce.com
    September 2019
Posted by Nikola on Monday, October 11, 2021 9:24 AM
Neutral Grey base over blue pre-shading on the belly finished. I try to keep the pre-shading effect very subtle initially and then modify where required with post-shading afterwards.
            www.shelfforce.com
    September 2019
Posted by Nikola on Wednesday, October 13, 2021 8:32 AM
OD finished.
My phone camera and the dining room light bulb just can't capture the subtle differences and tonal variations that well, but they are there, trust me. Big Smile
Oh well, pics below. :)
            www.shelfforce.com
    July 2021
Posted by Flight Line Media on Thursday, October 14, 2021 7:16 AM
Wow! That looks great!. Awesome work, Nicola!
Andrew
www.flightlinemedia.co
Follow us on Instagram: from.the.ariel.view
    September 2014
Posted by rooster513 on Thursday, October 14, 2021 8:05 AM
I can see some of the variation in paint you've built in, looks great!
-Andy
    September 2019
Posted by Nikola on Saturday, October 16, 2021 4:04 PM
And a few more where the effect of complementary pre-shading can be seen slightly better:
Best,
Nikola
            www.shelfforce.com
    April 2015
Posted by Mopar Madness on Saturday, October 16, 2021 5:34 PM
Now I can see it better. I sure do like an olive drab Mustang.
Chad
God, Family, Models...
At the plate: 1/48 Airfix Bf109 & 1/35 Tamiya Famo
On deck: Who knows!
    September 2019
Posted by Nikola on Sunday, October 17, 2021 2:41 AM
Mopar Madness
The hardest part for me now is judging how much to cover initially knowing that weathering and subsequent coats will affect it. It's just like regular pre-shading only more difficult because if it is with black, no risk of too much of it showing through since it only gives a darker tone of the base color with no hue modulation. Still long way to go until I master this one.
In reality, the red is more subtle but it's very hard to get it right with phone camera and regular room lighting conditions so you guys can see it properly. I'll keep trying to take better shots without all the fancy setup. :)
Best,
Nikola
            www.shelfforce.com
    September 2019
Posted by Nikola on Monday, October 18, 2021 2:47 AM
This is I think as close to reality as I could get with phone camera. I guess we'll have to wait until proper photos in the end. :)
            www.shelfforce.com
    February 2012
Posted by lawdog114 on Wednesday, October 20, 2021 11:47 PM
Coming along nicely Nikola. Interesting preshading color choices. Are you planning on painting on the red nose checkers?
    September 2019
Posted by Nikola on Thursday, October 21, 2021 5:09 AM
lawdog114
Thanks LD! Glad you like it so far. Yes, I am planning on painting the checkers. It's going to be a b#&ch but nowhere near as complicated as you had it on your P47. :)
Any tips for that?
As for my pre-shading, I started experimenting with complementary colours some time ago. If you are interested here is the link to the thread that I started in 2019:
http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/18/t/183439.aspx
Best,
Nikola
            www.shelfforce.com
Posted by Gamera on Thursday, October 21, 2021 10:24 AM
I love how she's coming along!
    July 2009
Posted by Back to the bench on Thursday, October 21, 2021 12:43 PM
That's a nice looking Mustang you have going!
Also apologies for not chiming in on your complimentary color preshading technique that you have been developing in the other forum. I have found it very interesting and it has made me realize I need to start learning some basics about how color works. Looking forward to your next photos.
Gil
    September 2019
Posted by Nikola on Saturday, October 30, 2021 4:29 AM
Back to the bench
Thank you! Appreciated. Glad that you like it so far. :)
Colours are very fun for me to work and experiment with in any medium, especially in scale modelling. :)
Best,
Nikola
            www.shelfforce.com
    September 2019
Posted by Nikola on Saturday, October 30, 2021 4:34 AM
I know that I might be boring you but as this is a very slow progress I am posting every little step.  :)
Invasion fuselage stripes done. Next are the wing and horizontal stabilizer white stripes. Then the clear coat and on to the decals. Yay!
Ah, yes, and the red checkers on the yellow...
            www.shelfforce.com
    July 2019
Posted by Hoss WA on Saturday, October 30, 2021 6:27 PM
Looking great.  Starting to come to life!  Love the invasion stripes.
    September 2019
Posted by Nikola on Monday, November 8, 2021 3:17 AM
All invasion stripes done, with some test weathering just for fun at the wing and horizontal stabilizer tips. :)
            www.shelfforce.com
    January 2015
Posted by TheMongoose on Monday, November 8, 2021 11:43 AM
"I know that I might be boring you but as this is a very slow progress I am posting every little step.  :)"
I follow a similar approach. Gives me a chance to stopand look at what ive done, slow down a little and see what the critical eye of the camera shows. Have found a number of goofs that i could fix easier during the build rather than after. The other thing I like is thinking about where to go next when i post a wip. Post away Nikola we all enjoy it I bet!
    September 2019
Posted by Nikola on Tuesday, April 26, 2022 2:15 AM
Hi gents,
Finally got some free time (when I am not too tired) to continue working on the pony.
My first checkerboard pattern masking and painting done. I screwed up in one place but it's an easy fix.
Next is painting the exhausts, then a gloss coat and then decals.
Best,
Nikola
            www.shelfforce.com
    January 2015
Posted by TheMongoose on Tuesday, April 26, 2022 6:09 AM
Nikola
Hi gents,
Best,
Nikola
THAT is an awesome looking checkerboard. Sooo awesome it deserved to be quoted and shown again!
    September 2019
Posted by Nikola on Friday, May 13, 2022 3:56 AM
Hi gents,
Gloss coat on.
Exhausts painted with the first and main weathering pass complete.
Apologies for s%#ty photos.
Finally on to the decals
Best,
Nikola
            www.shelfforce.com
    September 2019
Posted by Nikola on Friday, May 13, 2022 4:13 AM
TheMongoose
Thank you Mongoose. Appreciated. Glad you like it. :)
Best,
Nikola
            www.shelfforce.com
    February 2018
Posted by Model Monkey on Friday, May 13, 2022 7:44 PM
Одлично! Заиста уживам у вашим објавама и фотографијама.
