Canopy and painting
Canopy and painting
Posted by Anonymous on Friday, May 9, 2003 10:50 AM
Hey all, I'm getting close to time to prime my first model aircraft and i'm wondering if i should attach the canopy (and nose/propellers for that matter) before priming and just mask it or if i should leave the canopy off (mask the cockpit of course)and attach it after priming/painting. Thanks in advance for any advice!
merideth
Posted by berny13 on Friday, May 9, 2003 2:06 PM
If the cockpit is all finished and the canopy will be closed, go ahead and mask it and paint. If you are going to have an open cockpit, paint then install the canopy. Leave the props off till after painting as it is hard to mask around them without damaging something.
Berny
 Phormer Phantom Phixer
On the bench
Posted by Anonymous on Friday, May 9, 2003 3:03 PM
thanks so much Berny, that's just what i needed to know!
Posted by gregers on Saturday, May 10, 2003 8:10 PM
For masking the canopy i use crepe masking tape. It sticks well and conforms well to the curves. Best of luck with the P38 not an easy first kit...Gregers
Why torture yourself when life will do it for you?
