On the teeth patterns- you are right, gulfstreamV. Another thing a few hours of research showed was that the teeth patterns varied a bit too.
I'm thinking that (short of finding a color photo of high quality) if I fade the earth color and add just a hint of reddish tent, that will cover the brown (or green faded to a brownish color), and then fade out the RAF dark green quite a bit, that will cover the upper surfaces.
The lower surfaces I guess will just be a tossup. Maybe I'll see what happens if I mix 1/3 sky, 1/3 gray, and 1/3 azure? LOL
This page has several good articles by R.T. SMith, Disck Rossi and Erik Schilling, as well as others.
And in confused me even more.
Though little is said of the coloring, one article (the one referenced above by Brews), where Erik Shilling writes his feelings about sitting in a restored P-40, he states "
When I arrived, there in front of the hangar sat a beautiful P-40C
perfect in every detail." The aircraft in the photos there is most definetly a close cousin of RAF earth. Should be gospel right?
Well, in the forum reference above (in my post), someone identified as Erik Shilling says "
it is illogical for you who
have never seen the P-40B, which the Flying Tigers flew, argue with
those of us who have either flown or worked on them, because your only
source of information in making your decision is wrong. It is obvious
that your decision had to have been made by comparing a bunch of faded
60 year old color photgraphs. Since these pictures can be your only
source of information, you therefore haven't the vagues idea as to the
true camouglage coloring of the Flying Tiger's airplanes.
I
challenge those of you who think you are in a better position to
dispute the claims Tex,Chuck and I have made concerning the true colors
of the AVG's P-40,, and give us your source of information which you
based you decision upon when you say we are wrong."
And the color scheme he was referring to was a green on green.
LOL.
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
