You have to remember that what appear to be gun barrels on P-47 kits are actually cylindrical protective covers, with significantly larger diameters than the gun barrels themselves - say 1" extenal diameters on the real thing.
http://www.aircraftresourcecenter.com/AWA1/301-400/walk384_P-47/images_Holger_Papke/p1010040.jpg
I'd go for tubing with an external diameter of 0.5mm or 1/50".
Cheers,
Chris.
You may already have a ton of pictures of a full scale P-47, but just in case, here are some that I took. I hope they help:
http://s169.photobucket.com/albums/u221/rwright142/P-47
Now that's what I call a Gun Fighter!
What'a honk'n lethal, slugger of an airplane!
Flying is a thrill #2 known to mankind. Landing is #1.
http://www.rwd-6.org
On the Bench: Too Much
The simplest solution is to use tubing that is approximately the size of the barrel shrouds
you remove. If it looks right to you, that's close enough for all but the pickiest contest
judge or rivet counter. Enjoy your build...
Ray
