OTS 2015 (One True Scale or 1/72)
    April 2006
Posted by waynec on Friday, August 21, 2015 9:35 PM
DUKE hope you feel better.
got some more done. i put the control section together and had to work on outside seam. sanded promed repainted and didn't feather enough so resanded and reprimed and painted. another lesson learned. there is a decaled instrument panel in the compartment. obviously wheel wells aren't going to be seen so my rough fillls and sanding were good enough. decided to paint chassis black. wheels are fit tight, no glue.
saw this little bogger i missed. since i might have missile in launch mode, grabbed some styrene from the stash, cut, promed and painted. it is sand, i used white to show what i was doing.
also got the Elevator and Launcher assembled. had to take a deep breathe and easily pry the rear of the glued and painted Elevator to fit the Launcher.  also had st scrap down the Elevation piston and ream out the cylinder on the Transporter sop they would fit. this kit has some nicely fitting parts. kneeling dragon gunner shows size.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    January 2013
Posted by jibber on Sunday, August 23, 2015 8:59 AM
Wayne I have a ton of 1/72 so count me in on something. I'll have to wait to see how its going and I'll pick something out.
Terry
    July 2014
Posted by modelcrazy on Wednesday, August 26, 2015 4:12 PM
Wayne,
Could you please remove the F-14 from the roster? I will just be doing the Sd Kfz 7/1....soon.
Steve
    July 2004
Posted by Aussie747 on Wednesday, August 26, 2015 5:06 PM
Hey guys, I'd like to join with a Hasegawa NP-3D if that is OK?
Ray
    April 2006
Posted by waynec on Wednesday, August 26, 2015 6:03 PM
Something I started a while back but screwed up the base coat. base coat is desert sand which has a tan hue. i modulated it with desert tan, pin washes with oil burnt umber and overspray with ComArt soft dirt.
    April 2006
Posted by waynec on Wednesday, August 26, 2015 6:12 PM
and now the SCUD. this is an unusual build for me because i know it will be on a base so some of the underside isn't even painted. the front cab fender wells had the same mold "holes" but this time i didn't even bother to fill them. the cab is a bit tricky. You build each side, glue one side to the engine cover, glue that to frame, glue other side and rear panel. Acetate windows were ok. I did scan them in so i could make new ones. bumper is tiht but i had a gap on the sides, my fault and easily filled in with 101 size. styrene. overall the front is a tad rougher than the rest. missile is just sitting there. i think i will paint parts of it a bit darker and other parts a bit lighter.
    July 2004
Posted by Aussie747 on Wednesday, August 26, 2015 9:24 PM
Both look great Wayne. Is the LAV the Trumpeter kit? I did not know there was a 1/72 SCUD launcher/transporter kit around, who's is it?
Ray
    April 2006
Posted by waynec on Wednesday, August 26, 2015 10:21 PM
AUSSIE 747 will watch your build. i do JGSDF stuff which is how i got into OTS have the JGSDF {atriot, tank transporter, Type 74, Type 90, 8x8 Recon vehicle. not to mention the 1/35 stuff..
Trumpeter LAV
Toxso SCUD-B i have a more extensive WIP in armor. This thing is in 3 GBs, OTS, Gulf War I, Artillery. makes me want to cash in some stocks and buy the Trumpeter 1/35 but instead will get Trumpeter Patriot, HEMMT tractor, and SA-8. andi have the 1/35 SS-23 in the stash.
    July 2004
Posted by Aussie747 on Thursday, August 27, 2015 5:44 AM
Nice! Would love to get my hands on 1/35 Patriot set up as well. Will see what it retails for down this way and then see.
Ray
    April 2006
Posted by waynec on Thursday, August 27, 2015 9:02 AM
Aussie747
Dragon is coming out with one soon. think it's a black label kit. Trumpeter will probably cost twice as much as their Patriot is 2 kits: trailer/launcher and radar are one kit, HEMMT tractor is a separate kit. but, given how much better the Trumpeter K-5 RR gun is compared to the Dragon kit, the price is probably worth it.
    April 2010
Posted by Theuns on Friday, August 28, 2015 10:10 AM
Here are some of the colors on my "Spammy" as they were called in the SAAF
It will be in the scheme of a display team I work for "Cell C" celular service
Theuns
    March 2006
Posted by simpilot34 on Tuesday, September 1, 2015 3:39 AM
Theuns that looks great! Looking forward to seeing the full scheme applied!!Yes
All builds look fantastic!
Wayne I would like to join up if I may? I have signed up for the Desert Storm build as well with my 1/72 Italeri Strike Eagle. So two birds with one stone, might try for three in the Boeing build Whistling
Cheers, Lt. Cmdr. Richie "To be prepared for war, is one of the most effectual means of preserving the peace."-George Washington
    April 2006
Posted by waynec on Tuesday, September 1, 2015 9:26 AM
simpilot34
welcome. i crossover a lot. i think i have a 4some ready to start, JGSDF PATRIOT 3: OTS, Boeing, Japanese IV, Artillery
    April 2010
Posted by Theuns on Tuesday, September 1, 2015 10:26 AM
Hi Wayne, please replace my TU 128 witt this 1/72 Airfix DH 82.
ha
I will not have the time to get to the TU any time soon.
Thanx
Theuns
    March 2006
Posted by simpilot34 on Wednesday, September 2, 2015 4:53 AM
Ok, I will be doing the Italeri F-15E Strike Eagle. I have the Hobbyboss kit but it lacks accuracy. Having worked on them at depot level seeing them stripped to carcuses you notice things on kits lol. Anyway here are the current pics of the proverbials and my progress so far. The parts tag is from one I worked on which wa a 49 mission vet of Desert Storm. 88-1683. If you are wondering, the stamping machine they used only had spaces for what you see lol.
Still have to add pilot keepers and paint the firing handle locations.
    June 2003
Posted by Duke Maddog on Wednesday, September 2, 2015 1:22 PM
Very nice. I'll be enjoying this build.
I also got a little work done on mine, once I have enough done to show in pics, I'll post. Hopefully tomorrow.
    July 2004
Posted by Aussie747 on Thursday, September 3, 2015 6:24 AM
Managed a start on the NP-3D. Just got the basics going, cockpit installed, fuselage buttoned up and wings together with a couple of nacelles glued. Also dipped the windscreen in some future as it was replaced on another build when I got glue on it. I polished it up best I could and am getting it ready to install.
Ray
    April 2006
Posted by waynec on Friday, September 4, 2015 9:52 PM
that;s coming along nicely. i was looking at my AH-6. the doors are separate on the left side but molded on the right which means i have to cut them out. fortunately i don't have to preserve them. rocket pods and i will have to find some 1/72 pilots and build the fast rope hooks and side benches. meanwhile i started on a neubaru-fahrzeug 2 german multi turret tank.
my frau's contract is over so, after holiday, i will be able to paint all day and finish up the SCUD.
    July 2014
Posted by modelcrazy on Saturday, September 5, 2015 12:33 AM
OK Wayne, I started the Sd Kfz 7/1. It looks like quite a little kit with amazing detail. Any here it is.
Steve
Steve
    April 2014
Posted by B_one fixer on Saturday, September 5, 2015 3:12 AM
Got Crackin on the AWACS, Trying to juggle this and another couple group builds
I did the normal gluing the halves together and adding the wings. I filled the seams with putty to hallow them out because they were rather deep. I added the side array antennas, nose and tail sensors which I purchased thru Contrails models. I had to sand and shape the side antennas to match closer the profile of the real deal. It will look much better once paint is applied. I am in the process of sealing gaps and working the flaps and slats.
    July 2014
Posted by modelcrazy on Saturday, September 5, 2015 11:34 PM
I have an update on the halftrack. I have completed everything except the gun. I have to say, I am very impressed with this kit. Who knew? If you are looking for a 1/72 Sd Kfz, don’t overlook the ROG kit. It’s going together like a Hase kit.
Steve
Steve
    April 2010
Posted by Theuns on Sunday, September 6, 2015 10:35 AM
This little DH-82 will be interesting for me as I need to do the final painting (like box art) before final assembly can begin.
It does however all line up nicely with the new style of struts.
THeuns
    April 2010
Posted by Theuns on Monday, September 7, 2015 8:02 AM
Painting done, assembly next....stay tuned!
Theuns
    July 2004
Posted by Aussie747 on Monday, September 7, 2015 6:19 PM
Wings installed on the NP-3D  Starting to think about the colours for this one. I would really like to do the current scheme which means making my own decals
Ray
    March 2006
Posted by simpilot34 on Wednesday, September 9, 2015 7:57 PM
MC,Theuns and Ozzie those builds are looking great!!! Got a bit of progress on the Mud Hen to show. Got the bang seats done and installed, office finished and installed on lower fuse. So wanted to button up the fuse but was getting late, so will do that in a couple days. Then bring out the bog and chisels lol. Hopefully a little careful assembly will aleviate some filling and sanding though. Anyway here's the pics.Toast
Sidepanels aren't spot on just painted to look busy.
    April 2010
Posted by Theuns on Sunday, September 13, 2015 7:26 AM
Well, paint is still not perfect but atleast a little better than round 1.
Decals to follow next.
Theuns
    February 2010
Posted by 68GT on Sunday, September 13, 2015 10:36 AM
Going to building this ESCI 1/72 A-7E as soon as I wrap up some builds on the bench.
Decals willl be AirDoc VA-72, AC-405 on board the USS JFK, January 1991.
http://www.dstorm.eu/pictures/decals/airdoc72013_1.jpg
On Ed's bench, ???
    April 2006
Posted by waynec on Sunday, September 13, 2015 1:06 PM
it's starting to look like an airplane. i picked up a BdW LUCHS A2 and a Toxso SK -18 105 cannon. almost got another helo.
i would be interested in reading your technique for doing decals as i may have to make some OTS omes too. not the graphics so much as i do that, more the printing and attaching aspects.
PS i can do graphics and decals for anyone here and send them to you as a graphics file.
    March 2006
Posted by simpilot34 on Sunday, September 13, 2015 6:55 PM
waynec
Theuns that lil birdie is looking great!!  I will keep your very kind and generous offer for the decals in mind! Hehehe the gears are ticking on that. Saw a pic on facebook of what looked like a C-160 painted up as a Macaw! I just thoughthow beautiful it looked and what a wow factor it would have on a contest table.
Here's my update on the dirt dobber. Got the fuse buttoned up and parts off sprue for next step cleaned up and ready for attachment. A few seams to take care of but not as bad as I thought it would be. Fit was pretty fair actually. here's how she sits at the moment. Hope to get a bit more progress tonight.Toast
    April 2010
Posted by Theuns on Sunday, September 20, 2015 2:30 AM
Arrgh!! the rigging on this little DH 82 is driving me mad, I tried streched sprue but is was to slack. Now I am busy with EZ line but without holes for it to go into it is rather difficult to bond to the model. Atleast the decals on the T6 went on very well. Will post pix soon. Theuns
