For my 1943 project, I chose PT 109, in 1/700 scale.
This is a resin casting from White Ensign Models. When WEM stopped production, the stock was acquired by Atlantic Models in the UK, owned by Peter Hall. He was a pleasure to deal with; very prompt with communications and delivery.
The kit consists of two resin PT boats and two frets of nice, petite PE parts. That might make you think you could build two PT boats; you can't. WEM only included six torpedos with each two boats. I ordered two of the kits, so the final product will be three PT boats: 109, along with 157 and 162, both present in Blackett Strait when 109 was sunk on 2 August, 1943.
WEM's packaging left something to be desired. All the ventilator tubes were broken or damaged on all the boats, due to them knocking around in the bag. At this scale, I figured it didn't matter, so I removed all of the remaining ones, and sanded the area smooth.
Tiny resin depth charges were also included, but the casting was not very crisp, so I decided to replace them with styrene plastic rod.
That said, the boats themselves are very well done, with sufficient detail. Shapes look good and they are nice representations of the Elco 80' boat.
PT 109 was the seventh boat build in the 80' class, and delivered to the US Navy on 10 July, 1942. She reached the Pacific in August, 1942, and was assigned to Motor Torpedo Boat Squadron Number 2, based at Tulagi, in the Solomon Islands. She participated in combat assignments around Guadalcanal.
On 23 April, 1943, PT 109 was assigned to the command of Lt. (j.g.) John F. Kennedy.
It is believed that the boat was painted in a dark green color once she arrived at Noumea, New Caledonia. Sovereign's Colourcoats paint (formerly WEM paints) offered two options in their range: "MTB Green" and "Tropical Green." Instructions in the kit specified "Tropical Green," but I bought "MTB Green," too, and painted two of the boats in that color. I started off painting the bottom in Colourcoats "Antifouling Red," then applied the upper surface greens.
Thanks for looking in.
