IDF group build 2019/2020
    April 2019
Posted by John 3:16 KJV on Sunday, September 8, 2019 10:05 PM
Installment Three - More Assembly
Fixed well enough-
Main gun -
I drilled the hole as seen below with my modeling knife...; and, no, I didn’t assemble the main gun to the cupola area...Wink
Main body-
     “For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
     For God sent not his Son into the world to condemn the world; but that the world through him might be saved.”  - John 3:16-17
    April 2010
Posted by Theuns on Sunday, September 8, 2019 11:35 PM
Nice progress on that, interesting that the hole for the turret is solid.
I have been adding "stuff" to my hull and it seems to not make a dent in the sprue count LOL
Mach1 welcome
Theuns
    April 2019
Posted by John 3:16 KJV on Monday, September 9, 2019 12:15 PM
Thank you, Theuns. The copyright on the plastic was dated in the sixties. I don’t have to deal with an overload of pieces; but yours probably is better quality. Big Smile
By the way, what color will you use to prime your tank?
    April 2010
Posted by Theuns on Monday, September 9, 2019 11:35 PM
I saw a vid of a guy building this model of mine and he sprayed the whole thing black, then white over the areas he wanted to lighten up. The IDF grey then went over it with the black and white being the preshading basically.
I usually preshade only the areas I want dark but in this case there are ao many little areas one might have a hard to time to shade I will follow his idea.
I will use a grey on the sudae and bottom instead of the white to modlate the paint a little more.
As for weathering, I will do some light paint chipping and very light rust and maybe some streaking of the dust but I still need to figure out most of these things as I go.
Theuns
    April 2010
Posted by Theuns on Tuesday, September 10, 2019 10:48 AM
As an interesting sidenote, I was visiting someone is a nearby hanger to where I work and saw he was working on a super cub. He told me it actually was an ex Israeli L-21 that served in the IAF :-)
Theuns
    April 2019
Posted by John 3:16 KJV on Tuesday, September 10, 2019 3:29 PM
     Sweet! Big Smile Actually, the last model I completed was a Piper L4 Cub, not Israeli, though. An IAF Cub would probably make for a nice model!
     For priming generally, I‘ve got a Flat Light Aircraft Gray, but I’ve got to figure out preshading (what precise areas to preshade for one thing).
Installment 4 - Turret rails!
My kit didn’t provide pieces for the turret rails (Is that the correct name for them?). So, I scratchbuilt some rails out of metal (.025 music wire). Maybe they’re not perfect; but they’ve got to be better than the plastic extensions that had been molded onto the turret which I cut and sanded down. Here are some pics:
    April 2010
Posted by Theuns on Tuesday, September 10, 2019 11:37 PM
Those look way more convincing than the plastic rails I am sure ;-)
My project is still in the box the way I left it over the weekend....I come hyome when the light is not  good anymore and after a whole day of "real work" models are not high up on my wish list LOL
I cant build fine detail with artificial light anymore so tend to wait till weekends to build.
As for the pre shading, I think the idea of doing the whole thing in black ad then white highlights is because it will be very hard to try and preshade only the "reccesses" being so deep in some areas without getting loads of paint in the wrong places, highlighting the areas you want light seems easier
Sone buildes do this on aircraft but I find it easy to access aircraft areas I want to shade. This tank on the other hand is more tricky so will do it in reverse order.
There are loads of vids on the interweb showing this "black base" idea.
Theuns
    April 2019
Posted by John 3:16 KJV on Wednesday, September 11, 2019 11:26 PM
Thx, Theuns. :)
Work....Why can’t folks get paid for every model built?Wink
Installment Five - Turret Rail Assembly / Primer
So, I put on the turret rails (pictures three and four); and I went ahead with preshading the way you said - black first, then white (rather, in my case, that gray I had).  I did a little work by hand, too.
Here are the pictures:
    April 2010
Posted by Theuns on Thursday, September 12, 2019 11:04 AM
I got primer on and then a black basecoat over all , this will be lightened in some areas to give "shade" effect when the colour goes on.
 IMG_20190912_161148 by Theunis van Vuuren, on Flickr
 IMG_20190912_173806 by Theunis van Vuuren, on Flickr
This is my "day job" since I cant build models for a living LOL
 IMG_20190911_090523 by Theunis van Vuuren, on Flickr
 IMG_20190910_113952 by Theunis van Vuuren, on Flickr
Theuns
    April 2019
Posted by John 3:16 KJV on Thursday, September 12, 2019 3:39 PM
What kind of plane is that one? Big Smile
Do you think I used too much gray and covered up too much preshading on my model?
    April 2010
Posted by Theuns on Thursday, September 12, 2019 11:33 PM
The wing is a topwing of a Pitts S2b I am completing today if the weather is good and the plane being masked is a Super Decthlon I hope to have flying very soon.
Theuns
    April 2010
Posted by Theuns on Friday, September 13, 2019 11:06 AM
As an experiment I looked at Humbrol yellow sand but was to "yellow to me" so I tried Tamiya 74 enamels.
Here is the base with the highlights on it
 IMG_20190913_141724 by Theunis van Vuuren, on Flickr
Then I sht the tamiya over it in thin coats till I got an even look with shadows just showing through, the sides and bottom O added a drop of black to look like it is bleached a little less.
This is an interesting colour indeed, in bright sun it looks very grey
 IMG_20190913_144230 by Theunis van Vuuren, on Flickr
But indoors where it will be viewed mostly the clopor changes to a more tan.
 IMG_20190913_171529 by Theunis van Vuuren, on Flickr
 IMG_20190913_171553 by Theunis van Vuuren, on Flickr
Now I need to weather it a little and complete the hull.
Theuns
    April 2019
Posted by John 3:16 KJV on Friday, September 13, 2019 10:33 PM
Comin’ along, Theuns! Lighting sure does things. :)
    April 2010
Posted by Theuns on Friday, September 13, 2019 11:14 PM
I did mess up the turret by trying chipping of the paint, will have to repaint the turret and maybe just go for a factory new tank.
    April 2010
Posted by Theuns on Saturday, September 14, 2019 5:45 AM
This time Im hapy with the colour. I ysed my Tamiya buff and added about 25% humbrol green 155. Ths gave a nice sand with a subttle green heu to it in shade and a grey /sand in sunlight.
 IMG_20190914_122247 by Theunis van Vuuren, on Flickr
 IMG_20190914_122307 by Theunis van Vuuren, on Flickr
 IMG_20190914_120702 by Theunis van Vuuren, on Flickr
Theuns
    April 2010
Posted by Theuns on Sunday, September 15, 2019 9:50 AM
Looking at loads of magach pix I tried my habd at doing the dust weathering using a mix of different chalk pastles and the "wear surface" I used a graphite pencle to look like bare steel.
The tracks I had to tie together with cotton thread as onlt one set of the pins reached the holes but kept comming off, lucky the sideskirts will hide this
 IMG_20190915_150253 by Theunis van Vuuren, on Flickr
 IMG_20190915_150204 by Theunis van Vuuren, on Flickr
 IMG_20190915_144505 by Theunis van Vuuren, on Flickr
Theuns
    April 2019
Posted by John 3:16 KJV on Sunday, September 15, 2019 10:23 PM
Good paint job on the tank, Theuns. Yes
    April 2010
Posted by Theuns on Sunday, September 15, 2019 11:24 PM
Thanx, pity you cant really get the effect of the modulation where the green has 'faded" into a green/brown as my camera in direct sunlight makes it all to bright.
When I mixed the green, I used tamiya buff and added hunbrol green with a little grey aswell.
I sprayed the bottom of the tank with this mox that looked nce and green, I planned to lighten to top sides with some white but I saw that the paint has settled a little into a lighter green/brown shade....dumb luck LOL
I have seen that faded green had a slight brown heu to it and it just happen to work out well.The tonal differences are ther but seems to blend well as it is the same basic paint
Theuns
    February 2011
Posted by GreySnake on Wednesday, September 18, 2019 5:10 PM
Theuns and John both of your builds look to be progressing nicely. The paint on the Magach came out good Theuns.
I’ve been slowly chipping away at my build for the past couple weeks. It’s cold off a little in Arizona so I’ve been doing a lot of yard work which hasn’t left me with much time to work on models. But I have gotten the Merkava close to the painting stage.
The wheels and suspension pieces had some pretty nasty seams so clean up took awhile.
After adding a few parts to the upper hull it was done.
The gun barrel cleaned up nicely with a little careful sanding.
In a previous post I noted the fit on the turret wasn’t great and this was the worst area by far. A little putty and sanding took care of the issue.
Added most of the parts to the turret and here is where I am at. Still need to clean up the machine gun mounts and glue those on. The gun barrel and mantlet cover haven’t been glued on yet. As the mantlet cover is khaki it’s easier to paint separately.
    April 2010
Posted by Theuns on Wednesday, September 18, 2019 11:35 PM
That looks really nice, it is interesting to see that the Merkava has a mush "cleaner" hull than my Megach that has bobs and bits/boxes welded on all over the place....clearly a retro fit :-)
I have almost completed my tank, I dusted the hull and turret with my chalk pastels and it now really looks "used" maybe a little to much as some of the nice paint modulation has been lost in places but I am learning still LOL
Theuns
    July 2008
Posted by castelnuovo on Friday, September 20, 2019 1:32 PM
Some good progress here. My Merkva is also progressing nicely, turett is done the wheels are instaled. Unfortunately, about 10 days ago my computer decided that it is beyond outdated and packed it in. It does not recognize the wi fi or the cammera. So I bought a new computer but it will not be here for another week or so. So the WIP pics will be posted with much delay.
 Cheers...
    April 2019
Posted by John 3:16 KJV on Friday, September 20, 2019 4:30 PM
Hi, all; and thank you, Greysnake! I’m finally gonna post installment six.
Installment 6-
Got milk?
Chocolate milk that is...; for my tank ended up a chocolate milk-like color which in other lighting struck me as somewhat pinkish; but, hey, Testors Flat Tan was what the instructions recommended. Wink
So, what do y’all think? What‘s next? Can anyone tell me how to get a paint color like the color in the illustration below? (I prefer enamels and I would prefer not to mix, but I may have to compromise somewhere...so, I invite all options.)
    September 2012
Posted by GMorrison on Friday, September 20, 2019 5:14 PM
I think it looks good. After I scanned through your post I looked at MM paint chips. I'd forgotten what you tried, but I came up with....Flat Tan. It's probably a good base to start building up lighter areas against, mixing with drop or two of EDIT: light gray at a time.
    April 2019
Posted by John 3:16 KJV on Friday, September 20, 2019 7:55 PM
Thanks, GM. :) The paint seems, though, to have a pink undertone.
    April 2010
Posted by Theuns on Saturday, September 21, 2019 8:53 AM
I dont think a pink undertone is a bad thing, paint in the desert fades into totally odd colours. Here in South Africa green fades into a strange brown tone.
What you can try maybe is a filter to alter the tone a little but still leave the basic colour. I did this with very thined water colour , look at the slight difference between the front (filtered) panel of the LH side skirt and the rest of it/
 Academy 1/35 Magach 7 by Theunis van Vuuren, on Flickr
To me it looks like a repainted or replaces part that has weathered at a different rate.
Im caling this one dune, was a fun build, came out better than I expected.
Theuns
    April 2019
Posted by John 3:16 KJV on Saturday, September 21, 2019 3:21 PM
Good job, Thuens! Congrats! Big Smile
    April 2010
Posted by Theuns on Sunday, September 22, 2019 12:15 AM
Thanx :-)
    February 2011
Posted by GreySnake on Sunday, September 22, 2019 4:42 PM
Thank you Theuns! The Magach turned out great!
John, the paint looks good as is to me.
I’ve been working on painting the Merkava for the past few days. Started out with Tamiya’s NATO black to do some pre shading and then moved onto the base color, using a 1:1 mix of Tamiya Medium Grey and Buff.  Here is how it looks so far.
Here is one picture taken in direct sunlight gives it a different look.
Next up will be painting the rubber on the road wheels. The misses is going to be gone for a week visting family so I’ll have a lot of time to work.
    April 2010
Posted by Theuns on Monday, September 23, 2019 4:21 AM
Nice work on the Merkava, I see you also got the same effect of the colour changing from a grey to grey/green as the light changes :-)
Theuns
    April 2019
Posted by John 3:16 KJV on Monday, September 23, 2019 11:07 AM
Thanks, Greysnake. :)
You’ve done a great job!
