The Official F-4 Phantom II Group Build 2011
    August 2009
Posted by Sparrowhyperion on Monday, June 6, 2011 10:29 PM
Okay.  Here are a few images of the completed cockpit.  I will be doing a tiny bit of touch up work in the morning and doing a dark wash with acrylics to age the bulkheads and lighter surfaces a bit.  I may also do a medium gray wash around the edges of the black instrument panels to simulate worn paint.    Here is the cickpit.
And that just about wraps it up for me and the crew for the night..
A hearty good night from
Rich (The overworked Dad)
Deb  (The Overworked mom and detail painter)
Marissa (Chief in charge of overworking mom and dad.)
Snitch (King Cat)
Abby-Normal (Psychotic Cat)
Spicey (Sweetie Cat)
Raven (House SIuT Cat, and hussy in charge of bugging all the other cats)
And Zilla (7 Lbs of scaly Green Iguana Terror who refuses to do anything but start at us, eat, and go do nasty things in his box)
In the Hangar: 1/48 Hobby Boss F/A-18D RAAF Hornet,
On the Tarmac:  F4U-1D RNZAF Corsair 1/48 Scale.
    June 2009
Posted by jimbot58 on Tuesday, June 7, 2011 12:50 AM
Ok, guys. I need a teeney bit of help here. I'm trying to get this straight in what passes for my brain. I am mounting the gear and doors underneath the "G" and the instructions just aren't totally clear. The big door is attached to the landing gear, I got that part, but the smaller door, if I look at this right, would not only be tilted outward towards the wingtips, but would they also be at an offset angle? Am I making sense? I can't find any really good pics to get the right idea! If I place them even with the edge of the opening, it makes them angled in relation to the centerline of the plane?????
Help!
Here is the best photo I could find:
On my workbench now:
Fujimi F-4K Phantom "Yellow Bird" and Zvezda Su-27SM Flanker
    February 2010
Posted by Bockscar on Tuesday, June 7, 2011 5:15 AM
Jim,
You mentioned "If I place them even with the edge of the opening, it makes them angled in relation to the centerline of the plane?" and from that picture, that seems right. The little door seems hinged with the axis of rotation right at the bottom wing surface. The big door attached to the gear has its axis obviously hinged up inside the bay. There's a tiny little actuator arm running from the strut and hinged just above that red tag, it appears to pull the little door closed as the big door closes.
Given the two different axis points, that little door should get pushed well past normal (90 degrees to the keel), pushed out of the way a few more degrees, looks like an additional 30-40degrees. I.e. when the wheel is partially extended at about 30-40 degrees to the keel, the little door would be pointing straight down at that juncture. That's what I'm seeing in the picture. I'm just guessing myself.
    November 2003
Posted by mississippivol on Tuesday, June 7, 2011 8:24 AM
Jim,
Bocks seems to have the right idea.
Glenn
    August 2009
Posted by Sparrowhyperion on Tuesday, June 7, 2011 9:17 AM
Yup.  That sounds about right.  Good morning all.
Rich
Bockscar
Jim,
    November 2010
Posted by Son Of Medicine Man on Tuesday, June 7, 2011 12:00 PM
jimbot58
Help!
http://img854.imageshack.us/img854/7607/afmf4g22.jpg
Jim,
From all of the photographs I have been able to look at, it looks like if you are standing in front of the aircraft, the end of the door closest to you is angled outward towards the wing tips.  So I would say that they are not inline with the centerline of the aircraft.
Ken
    March 2005
Posted by TarnShip on Tuesday, June 7, 2011 12:33 PM
that camera is actually on a tripod about between the Aux air doors behind the center of the aircraft, so that's the Port landing gear looking forward
the tip and front fins of that HARM are your visual references
I said tripod,,,because it's too clear of a photo to be taken by a man kneeling back there, lol
but, just to verify,,,,you are correct about different angles of the door parts
hope this helped
Rex,,,,,the guy that attracted "unwanted attention" taking F-4N pics at P-Cola, lol
almost gone
    February 2010
Posted by Bockscar on Tuesday, June 7, 2011 3:18 PM
Son Of Medicine Man
 jimbot58:
Help!
Jim,
Ken
I agree, assuming that little outer door is hinged at the outermost edgeline, that line is about 30 degrees off center. It scoops air because that little bastige is a covert airbrake...lol.....
    February 2010
Posted by Bockscar on Tuesday, June 7, 2011 3:22 PM
UUUmmmmm....F-80 Shooting Star as a backdrop?
    November 2010
Posted by Son Of Medicine Man on Tuesday, June 7, 2011 8:37 PM
Hi Everyone!
Well tonight I got another idea of how to tackle those rudder pedals.  I put each pedal in "The Bug" photo etch bending tool and bent up the metal around the bottom of the wire.  This gives more area to work with which seemed to do the trick.  I got one pedal attached.  I want to let it dry before I start on another one.  If I only get one pedal on a night that will be okay with me since it will still be progress.  I think it looks pretty good.  Here is a picture:
Ken
    November 2010
Posted by Son Of Medicine Man on Tuesday, June 7, 2011 8:38 PM
Hi Berny,
Did not see any posts from you today.  How are you feeling?
Ken
    August 2009
Posted by Sparrowhyperion on Tuesday, June 7, 2011 10:40 PM
Okay.  I installed the cockpit and buttoned up the fuselage.  One casualty, well 2.  Minor ones.  The tail Pitot tube and Fuel dump nozzles got snapped by an elastic that broke.  I'll just snip some off of one of my other F4 kits.  either that or make a metal pitot tube...  Does anyone know if the diameter of the pitot tube is that different from the metal tube in a bottle of Model masters cement? Hmmmmmmm...  Anyways, here are some images.  I don't do the finish sanding and fit and finish until it's completely dried so it looks a bit rough.
I think the experience I got from installing the resin intakes on my now dead FGR.2 made these come out a lot better.  The bottom fit is a LOT better and I won't have to nearly as much sanding.  Let me know what you think.
Rich
    April 2005
Posted by Thunderbolt379 on Tuesday, June 7, 2011 11:00 PM
I think it looks GOOD -- those resin suckers really make a difference!
M/TB379
http://worldinminiature.blogspot.com/
    July 2003
Posted by sidure on Wednesday, June 8, 2011 1:19 AM
I agree those intakes look great the difference is very noticable.
I have been out of the loop lately due to an ilness that had me sidelined but have managed a few hours here and there. I will post some progress pics very soon.
I do have one question that has always confused me on some F-4s.  I have never trusted the colour callouts for the Tamiys kit and this is one of those questions. I am building a Marine F-4j and was wondering about the colour of the edges of the interior gear doors and if they should have the red trip around them like all modern aircraft do. I spent 6 years around the F-4J when I was in the Marines and I have a lot of good reference photos and going through them I have found that most of the birds are painted all white gear doors but I have found a few that had the edges trimmed in red. So was there a time frame when they used to be all white and at some time the regs said to trim them red. I know the reason for the red trim was for safety and a clear visuall if the doors were closed all the way etc. I know the flaps are trimmed in red but what about the gear doors in circa 1975.
Steve
    April 2005
Posted by Thunderbolt379 on Wednesday, June 8, 2011 1:27 AM
Excellent question Steve -- sounds like one for Rex? I have at least two birds on the bench that would benefit from this clarrification...
M/TB379
    March 2005
Posted by TarnShip on Wednesday, June 8, 2011 2:01 AM
Steve, I thought that was a simple question,,,,,but, then I thought, nawww, better go look so I can give some references so you might be able to look and see yourself (that's how I like to do it)
so, now,,,,,lol,,,,,I see them on early F4H-1/F-4A,,,,,sometimes on B's and then they come and go, even up to the F-4S in TPS, some of those have red doors
so,,,,if you can give me the tail code, modex, BuNo and squadron or year,,,,,,I might be able to point to a "known photo" for you
fully 2/3 of the pics I have don't show red doors,,,,,and I only used "good" color shots to base that on
Semper Fi
Rex
almost gone
    June 2009
Posted by jimbot58 on Wednesday, June 8, 2011 3:08 AM
jimbot58
Help!
Hey thanks everyone for your input! The eyes aren't what they used to be and it helped to have some extra eyes to look at the photo and determine if what I was seeing was correct. My first thought when I looked at this configuration was that having those doors at an angle would add a lot of drag! Then I slapped my forehead and thought about hanging a huge chunk of metal with a wheel and tire at the end of it under the aircraft probably adds a bit more drag than that little door!
Those intakes look great! I don't know that I would want to do that kind of surgery even if anything was available in my scale!
    June 2009
Posted by jimbot58 on Wednesday, June 8, 2011 3:11 AM
Hey check out the work this member is doing on his Rhino!
/forums/t/133637.aspx?PageIndex=1
    August 2009
Posted by Sparrowhyperion on Wednesday, June 8, 2011 11:18 AM
Yeh they do.  I had a heck of a time finding a set of the actual older KMC ones..
Thunderbolt379
M/TB379
    July 2003
Posted by sidure on Wednesday, June 8, 2011 12:28 PM
Hey Rex, thanks for the help in trying to find that out for me. I am also goleling everything I can think of to get a clear decision. So here is some info for you and I hope I dont make it too confusing on ya.
Firstly the kit. Its the Tamiya 1/32 offering of the J and I am doing the VMFA-451 scheme. Bu # 155821 modex # 211. This kit was already done in this GB by ElTano I think and the time fram of the plane is 1975 to 1976 in bicentenial colours.
Now for the confusion. While I was in Beaufort all my pics I have have the doors in all white. VMFA-333, 312 and 235 and that was in 1979. While I was stationed in Japan and Korea we had a lot of squadrons comming and going for all the different operation we did like the annual bear hunt exercise. While there VMFA-312 was a low vis scheme and all doors were white and flaps trim was in red.
VMFA-235 was stilla Hi vis scheme and the gear doors are clearly trimmed in red
VMFA-333 still in Hi vis scheme now had its gear doors trimmed in red
Then I found a pic I didnt remember and it was actually of a VMFA-451 bird in 1983 that landed in Kadena AFB to refuele and its in low vis and the doors are trimmed in red. My friend was a refueler and I always joined him on the flightline to get around the aircraft to take pics etc. Additionally during my 6 years every A-4 and A-6 I was around from 1979 to 1986 had a red trim on the inside of the gear doors. Very confusing I know but I just dont know if there was a time when the regs changed to trim the doors in red. If im not mistaked just about all the Navy F-4s had the red trim. Any help would be very appreciated
Steve
    November 2003
Posted by mississippivol on Wednesday, June 8, 2011 1:15 PM
jimbot58
Wow!
    March 2005
Posted by TarnShip on Wednesday, June 8, 2011 1:53 PM
I'm going to return the favor Steve, and make this "clear as mud" for you,,,,,,,great topic by the way, I wouldn't have given it a though if you hadn't brought it up.
I have a color pic of -451 at Beaufort in 1979 of an early F-4J, no color on the doors, and no DECM on the intake shoulders,,,,,,,,  and quite a few VF-161 F-4Js with colors on the doors in 1976
there is a color pic in the -451 section of Spirit in the Skies,,,,,,of another jet, but the right date,,,it's late F-4J BuNo 153776. AA-201,,,,,,in that pic, I can just see the color on the front of the open large nose gear door, and the small door, and the right main door have the tell tale "gray look" that means that it's not white (if you get my meaning)
so, I'd say you could go either way,,,,,,,but,,,,,,it's a show bird for a celebration,,,,tempting to say do it in red
this is one of those deals where you could slap a stack of photos down and say "It's Red",,,,,,,and the other guy could slap a stack down and say "It's White",,,,,lol
I need more Phantom photo books, lol,,,,,,,,and I need to start buying photos from the guys that sell prints,,,,,,,all the ones I and my uncle took are mostly B+W with a 110 or 126,,,,,and also most of the Phantom Photos are of  -314
hope I was of some help
Rex
almost gone
    July 2003
Posted by sidure on Wednesday, June 8, 2011 3:20 PM
Thanks a lot Rex, its what I was leaning toward and I was just wondering if anyone had a clear answer as to why some do and some dont. Like I said in my photo album that spans 6 years it all depends on the squadron. Its funny seeing a flight line with one squadron that has them and the other dosent. I have built some hasegawa kits that say they had red trim and in some of the tamiya kits I know their colour callouts are not always accurate. For the sake of it being a show bird and also because I am leaning toward doing the red edges, that is what I am going to do. At the end of the day its what I want it to look like anyway. Just didnt want to stray too far off accuracy
Steve
    November 2010
Posted by Son Of Medicine Man on Wednesday, June 8, 2011 8:18 PM
Hi Everyone,
Well, the rudder pedals are in.  The front cockpit's pedals look nice.  Here is a picture:
Tomorrow I will paint them and that will be done!  The rear cockpit didn't fair so well.  But they are on and I am betting that you probably won't even be able to see them once the cockpit is completely assembled.  If they are, well then that is just the way it goes.  I have fought with them too long.  The instructions are nonexistent and I gave it a lot of effort.  Here is what they look like:
Tomorrow I will give them a coat of flat black and add some detail paint to the controls.  That should make it look real nice.
Ken
    February 2010
Posted by Bockscar on Wednesday, June 8, 2011 8:34 PM
sidure
Steve
Hah!!!....yesterday, Rex forgot more that i know......lol.....
    February 2010
Posted by Bockscar on Wednesday, June 8, 2011 8:50 PM
Ken:
http://i1143.photobucket.com/albums/n625/Fooser_Ken/100_4515.jpg
The right pedal, man, better work on that, my computer scanner says it is about 0.0000000006th of an inch out, and even Oprah is already tweating about it, uhhhh....sorry man.....Wink
Oh yeah, where'ld you get the 'disco' floor????....man lit up from underneath, ..........okay, Olivia Newton John, or was that Fara Newton Fawcet, uuuhhhh.....thank GAHshanks we do lose our memory with time.....lol.....
    November 2010
Posted by Son Of Medicine Man on Wednesday, June 8, 2011 9:06 PM
Bockscar
Ken:
Dom, I swear you make me laugh more than anyone I know!  Big Smile
Ken
    March 2005
Posted by TarnShip on Wednesday, June 8, 2011 9:43 PM
lol Bockscar,,,,,,in regards to "yesterday Rex forgot",,,,,,,have a little tale to tell ya (It's sort of about Phantoms, lol)
back on Memorial day, I was with the ole Gunny,  we were talking about friends we'd served with or ran into through the years,,,,got to talking about this one kid of one of the Sgts we both knew,,,,,his mom had nicknamed him Hawkman,,,,,,cute little kid we knew from age 2 to 6 or so,,,,,we're scratching our heads, and trying to think of this Sgts name,,,,no luck,,,,,,,my aunt walks by and gets all disgusted at us,,,,,,and blurts out "It was Sgt Hawk, you dumb grunts",,,,,yeah, his mom nicknamed him for his last name
oh well, back to trying to figure out why the prop on the lawn mower doesn't pull the thing down into the dirt
Rex
almost gone
    November 2010
Posted by Son Of Medicine Man on Thursday, June 9, 2011 6:11 PM
berny13
Here is how the two pods will look.  The top picture is of the AN/ALQ-87 ECM pods and the second is the AN/ALQ101 ECM pod.
http://i22.photobucket.com/albums/b309/berny13/7212-1219846994-ecm_pods.jpg
http://i22.photobucket.com/albums/b309/berny13/ALQ-101-6.jpg
http://i22.photobucket.com/albums/b309/berny13/ALQ101.jpg
Hi Berny,
I had already ordered the AN/ALQ-101 pod from Flightpath (David J. Parkins) when you posted this.  But there was no real way of knowing what version I was going to receive since there were no pictures on his website.  It finally arrived today and here is what it looks like:
After seeing your reply to Rich about the version I know that this is a newer version than what you used.  In fact from what information I could find, I am assuming that the AN/ALQ-101 you were using at the time in Vietnam was a prototype.
Anyway, you had offered to send me the correct one.  I know you sent one to Rich so I don't know if that offer is still good.  Anyway, if it is, I would appreciate it.
Ken
Posted by berny13 on Thursday, June 9, 2011 8:23 PM
Son Of Medicine Man
 berny13:
Hi Berny,
http://i1143.photobucket.com/albums/n625/Fooser_Ken/100_4516.jpg
Ken
This is the type you need.  The AN/ALQ-101 ECM pod was just entering the Air Force inventory.  They were not a prototype but the first generation ALQ-101 pods put in production.  Later ALQ-101 pods were improved by adding more receivers, transmitters and processors which resulted in the pod growing in size and having more gondolas added.
A lot of talking heads and experts will tell you the AN/ALQ-119 ECM pod is an AN/ALQ-101 ECM pod with additional space in a larger gondola.  The truth is the AN/ALQ-101 ECM pod was air cooled with air ducts added on later versions.  The AN/ALQ-119 ECM pod was a complete redesigned pod which was much larger, lighter, and was cooled by freon gas.  There were four radaiators built on the side with two having the intake facing forward and the two back ones had the discharge facing aft.  The AN/ALQ-101 pod was a deception pod and the AN/ALQ-119 pod was a programmable noise and deception pod able to operate in both the training mode and combat mode with just a flip of a switch.
Give me a couple of days to get the pod packaged up and in the mail.
Berny
 Phormer Phantom Phixer
On the bench
