World at War 1939-1940 Group Build
    September 2003
Posted by checkmateking02 on Saturday, January 2, 2016 9:48 AM
You're making great progress already, Brandon! Nice to see! That's a pretty decent looking PE set, too, By the look of things, you've developed some impressive bending skills!
    August 2005
Posted by fjs3 on Sunday, January 3, 2016 6:06 PM
Neat Group Build!!  I'm in with the new tool,  Airfix 1:48 scale , Hawker Hurricane Mk-I.
Here are a couple pictures of what I have done so far, which is basically the cockpit.  I have been doing some test fitting of the fuselage, and see a potential problem with fit, at the wing root.  Nothing crazy, it just means work and sanding, and I hate sanding a LOT!!
I got more done over the last few days.  The fuselage and tail are together, and the wings have been joined as well.  Once things dry, I'll post more pictures.
Thanks for looking, and have a great evening!
Regards,
Freddie from LI
"I'm gonna build all these models one kit at a time!
    September 2003
Posted by checkmateking02 on Sunday, January 3, 2016 6:25 PM
Welcome to the GB, Freddie. Glad you could join up. That's a great looking cockpit you've put together. I really like the metallic finish you achieved with it. I've updated the front page and added you to the roster. Thanks for your participation!
    January 2016
Posted by PanzerCommander on Sunday, January 3, 2016 8:08 PM
Is it too late to join? Working on a 1/72 Hurricane.
John McLaughlin
    September 2003
Posted by checkmateking02 on Monday, January 4, 2016 12:41 PM
Nope, John, not too late. The running time will go on until the 75th anniversary of the V-days--so anyone can join up at any time, and still build a kit for each year of the war. Bish has indicated that he is then planning some 80th anniversary GB's. Is your 1/72 Hurricane produced by Airfix? I don't know of anyone else currently offering an early Hurricane. Let me know, please, and I will update the front page. Glad to have you joining up, and I look forward to seeing your progress.
Posted by Bish on Monday, January 4, 2016 12:54 PM
Some nice work on that pit Freddie.
    May 2011
Posted by armor86 on Monday, January 4, 2016 11:55 PM
Some photos to share on build progress - German Field Kitchen (Gulaschkanone).  Base paint - German Grey (Vallejo) - wheel - spokes old wood with oil paint. Metal parts base painted and apply some oil wash for rusting. Next up some washes to german grey base paint.
Looks very clean for a field kitchen that gets pulled by horses on dirt roads. That will change once washes are completed. Using some AK weathering - washes - dusting effects. Start work on (kitchen help) figures soon. Uniforms during May-June 1940 period. Armor86
Cool
Dan
    January 2015
Posted by BrandonD on Tuesday, January 5, 2016 12:05 AM
Freddie - looking good! I built that kit and ran into a minor filling issue on the underside of the fuselage where it joined the wings. Glad to see you caught it early.
Armor - I like how that's coming along. Can't wait to see more.
-BD-
    January 2015
Well, I got some work done on the floats. These things have huge panel lines that you could hide a 1/48 rifle in. All my reference photos show them being pretty smooth, with rivets more than panel lines. So I decided to slather the putty on them, fill them, then run my new ponce wheel over the putty.
I was more than a bit heavy-handed in applying the Perfect Plastic Putty.
But after sanding and the ponce wheel treatment, they came out like this. They're currently drying after being sprayed with primer.
The floats are bare aluminum, so I will most likely need to do a little more seam cleanup on top, since they were a little rough.
-BD-
    August 2005
Posted by fjs3 on Tuesday, January 5, 2016 10:11 AM
Thank you Brandon.  Yeah, there are a few little bugaboos, (Port side wing root to name one) but all in all, a beautiful kit!
Regards,
Freddie from LI
    September 2003
Posted by checkmateking02 on Tuesday, January 5, 2016 5:07 PM
Very nice work on the field kitchen, Dan. That is a very neat paint job, so I suppose some grease and spilled sauerkraut would be helpful. I tend not to really know how to do weathering, myself.
    September 2003
Posted by checkmateking02 on Tuesday, January 5, 2016 5:09 PM
Looks like you managed a really good re-make of the pontoons, Brandon. There's a day-and-night difference there. Nice job!
    August 2005
Posted by fjs3 on Tuesday, January 5, 2016 10:34 PM
Here are a few progress pictures of the 1:48 Airfix, Hawker Hurricane.
I love the kit.  It has some VERY nice surface detail, and the interior of the cockpit and the wheel wells is freakin terrific.
I found that there are a few things that you will need to watch out for, should you decide to take a crack at this kit.  The only major issue I found, is with the fuselage to wing join.
  On my kit, there is a gap on the port fuselage to wing, right below the cockpit.  There is also a pronounced step at the front-lower-wing to fuselage join.  The same issue can be found at where the fuselage joins the rear of the lower wing, although not as bad.  All can be cleaned up with a little TLC, but the plastic is soft, and you'd better be more careful than I.
If you look close at the pictures, you can see where those issues come up at the front and rear of where the lower wing, meets the fuselage.  Still a little more I need to do there, but she's coming along really well.  I hope to get some paint on her within the coming week.
Thanks again for reading my post.  As always, comments and questions are welcome!
Regards,
Freddie from LI
    August 2005
Posted by fjs3 on Tuesday, January 5, 2016 10:36 PM
That looks really great!  Can not wait to seeing it finished!!
Freddie from LI
    September 2003
Posted by checkmateking02 on Wednesday, January 6, 2016 9:31 AM
Nice work, Freddie. From the photos, it looks like you're dealing with the fit issues very effectively.
    September 2007
Posted by Trabi on Wednesday, January 6, 2016 4:40 PM
Hi guys!
checkmateking02, Thank You for changing the end date! Now I could finnish this in time :-)
Gee, eight months since my last post! I have had bit busy with my work. My plan was to finnish Fokker during Christmas when I was off work. But that turned to work my *** off. We have four premiers in a row in week and half time. So...
But anyway. Now it´s ready.
Today, 6.1., is 76th anniversary when Sarvanto nailed six bombers in four minutes.
My presentation of the Ace:
And with his plane:
Not perfect, but I cout it ready!
"Space may be the final frontier, but it´s made in Hollywood basement." RHCP, Californication
    January 2015
Posted by BrandonD on Wednesday, January 6, 2016 8:22 PM
Trabi - Nice Fokker and pilot combo! And even on the anniversary of that attack. I like it, especially since you don't seea lot of those.
-BD-
    January 2015
I was working on the Lublin last night and got the floats where I wanted them to be, primed them and went to add the braces. There were some minor fit issues, and one problem with the rear bracing being warped.
I decided to cut the struts and re-glue them. I used solvent glue to melt them together, then super glue to strengthen the joint. Test fitting the the fuselage looks good at this point. Some cleanup will be needed on the lower attachment points, but hopefully not too bad.
Next up was finishing the cockpit. These had wooden floors, and I've never painted one before. I painted the whle thing Tamiya buff, then came back with Tamiya flat brown brushed on really thin, leaving brush strokes to hopefully simulate wood grain. I'm ok with where it is, but it's no work of art or anything.
I have to say, switching to Micro Kristal Klear as an adhesive to PE changed my life. This cockpit went together really easily. The Part PE fret didn't include belts, but I am assuming there was some sort of lap belts on these, so I added some from an Eduard set I have.
Now all that's left in the pit is mounting the instrument panel and putting it in the fuselage.
-BD-
    April 2006
Posted by jgeratic on Wednesday, January 6, 2016 10:38 PM
Trabi, interesting story and subject - good job with it! Yes
regards,
Jack
    August 2005
Posted by fjs3 on Wednesday, January 6, 2016 10:49 PM
That looks fantastic!!  Love the cockpit and your work on those floats is spot on Sir...
    August 2005
Posted by fjs3 on Wednesday, January 6, 2016 10:52 PM
Bish
Thank you Bish, Sir.  I hope to do her honor.
    September 2003
Posted by checkmateking02 on Wednesday, January 6, 2016 11:03 PM
Excellent, Trabi! Great work on both machine and man. I'll update the front page. Do you have a choice of photo?
    September 2003
Posted by checkmateking02 on Wednesday, January 6, 2016 11:04 PM
That is some fine and detailed work, Brandon. Very admirable!
    February 2006
Posted by DantheMan85 on Thursday, January 7, 2016 10:16 AM
Thanks Checkmateking.
Lostagain: Nice three tone camouflage, your wash really brings out the detail. I know what you mean about paint pealing off the tracks when you fit them on, that seems to happen to every Tamiya tank I've built with rubber tracks. I think your 7TP has turned out excellent.
BrandonD: Nice start to your floatplane, the photo etch sheet will bring some good detail. Those floats are lookin' great.
Fis3: Great interior work on your Hurricane. I also hate that when you have to sand a grind parts to fit.
Armor86: Nice looking field kitchen.
Trabi: Great job on finishing your Fokker.
Iron Annie is really taking shape, yesterday I glued on the main landing gear and covers. Started to paint the tail wheel, finishing up on touching up the paint. The leading edge's where RLM 70 & 71 meet RLM 65 needs touch up. As a size comparison I got out my 1/48 Bf 109. After all painting is done, I'll attach the three engines, bottom antenna, top rear gunner.
On my Work Bench: Tamiya Ford GT 1/24
Up Coming: ?
    September 2003
Posted by checkmateking02 on Thursday, January 7, 2016 10:20 AM
That head-on, close-up view is particularly impressive; imposing and even menacing.  Nice work, Dan.
    October 2004
Posted by ygmodeler4 on Thursday, January 7, 2016 11:55 AM
Hey Checkmate, is this build only 1 SEP 1939 and after? Or would the Nomonhan incident (known by the Japanese) or Battle of Khalkhin Gol (as it is known by the Russians) be able to qualify for this gb? The battle lasted from from May until about mid September of 1939 but the specific model/diorama I'm thinking about doing would be in August.
-Josiah
    September 2003
Posted by checkmateking02 on Thursday, January 7, 2016 3:09 PM
Hi, Josiah.
Oh, I don't think I want to be too inflexible on this.  There was a lot of fighting going on in Asia before the Polish invasion, which kind of melded into the Second World War.
And since the flighting went on at Khalkhin Gol into September, I think we can accomodate you.  When you're ready with some more information about scale/kit/subject, I'll add you to the front page.  Please let us know!
    September 2007
Posted by Trabi on Thursday, January 7, 2016 3:09 PM
Thanks guys for your nice words!
checkmateking02
checkmateking02, I think that first one of whole plane and pilot would be the best.
    September 2003
Posted by checkmateking02 on Thursday, January 7, 2016 3:12 PM
I thought so, too, Trabi, since both are part of the project.
Thanks for another contribution, and for being part of the build.  It's been a pleasure having you involved.
Front page is now updated.
    October 2004
Posted by ygmodeler4 on Monday, January 11, 2016 6:46 PM
checkmateking02
Hi, Josiah.
I wholeheartedly agree, while 1 September may be a good official start for the war in Europe, Japan had been conducting war for years before that. I have a bit more research to do on a small diorama idea I have, but since this thing will be going on for awhile I'll have plenty of time to jump in. I'll let you know once that research is done.
-Josiah
